| Hurricane 425 Discussion and support of the Gaui Hurricane 425 |
probably been asked alot but....any recomendations on servo's would be appreciated.
I'm looking at spektrum 6010's but anything cheaper that get's it done? |
That is a lot of torque. I think you need one with a bit more speed and not so much torque. I could be wrong.
This is what Align throws on the 500. From what I understand what Align puts on it's super combos is a good starting place. DS510 ●Stall torque: 3.7kg.cm (51.38 oz. in.) @ 4.8V 4.6kg.cm (63.88 oz. in) @ 6.0V ●Motion speed: 0.13sec/60° @ 4.8V 0.11sec/60° @ 6.0V
Gaui Hurricane 425 FBL with Robird G31 500 Class Rocks! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. EFlight Blade 450 3D, Walkera Super CP Walkera Devo 10 w/ Deviation |
I have built 4 Gauis and bought used or ones pulled from TX kits, Spektrum DS821's for all of them right here on the Freak!
Good enough speed wise and BULLET PROOF! Use Hyperion DS20 GMD's on the tail....GY401, GY520.
Gaui 500 / Tarot Quad 450 KK2.0LCD/ X525 (2X) DC 450 FPV 500mw 5.8 / SC10 AMA 953414 |
#4 | |
If you want something cheaper you could consider this one.
Its a new servo, made by Henge. Being cheap and new it is a bit of a gamble if they last over time, but if the gear-train is anything like the faster one i have here on the bench it should be a great budget servo for the swash. It is one size smaller than standard servos, so you need the adapter plates that come in the hurricane kit. I have both my hurries fully equipped and flying well, otherwise i would have taken the plunge and make a review on them.
MSH Mini PROTOS <==> Clone 250/450 +night rig <==> GAUI Hurricane EP 425 FBL + 520 FB Complete fleet equipped with Tarot ZYX Quote:
I second the 821's on cyclic. These have worked great and are low cost, even new. I'm using an Align 620 on the tail with an align 750 gyro. Low budget but works for my flying skill.
#6 |
Thank you for the advice. I have a futaba gy520 and servo for the tail.
this is my first build, Blade 400 previous, so I'm stumbling my way thru it Have neighbor that will be a big help to set it up, He flys nitro helis and very well so..... |
#7 | |
and I can assure you that the grin on your face after the first hover will last for one whole day ![]()
Jörg To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. * fly fast - live slow * |
