Go Back   HeliFreak > R/C Helicopter Support > Beam > BEAM E6
BEAM E6 BEAM E6 Factory Support Forum
Old 11-18-2012, 03:33 AM   #1
lowey79
Default Show us your Avantgarde
Every other heli has a pic and vid thread so lets see those Avantgardes.
(pic of mine to follow as soon as its finished)
lowey79 is offline        Reply With Quote
Old 11-20-2012, 01:49 AM   #2
Dally7
i'll place pct of mine too
Dally7 is offline        Reply With Quote
Old 11-22-2012, 02:53 AM   #3
tiogus
Default Happy owner Beam 600
This is my Beam 600 . Perfect machine!!
Uploaded with ImageShack.us
tiogus is offline        Reply With Quote
Old 01-03-2013, 08:30 AM   #4
lowey79
Here's mine!
Old 01-03-2013, 08:04 PM   #5
Luigi_tuga
Nice
This is one of my favourites 600 class helis, i would like to be able to get one in the future.
One detail on your Beam caught my eye, Lowey.
The gyro orientation could be stressing the cables or forcing to break the adhesive?
Logo 480, Warp 360 , Sport 360
T500 AP
PZ StrykerQ DX8
Luigi_tuga is offline        Reply With Quote
Old 01-04-2013, 07:44 AM   #6
lowey79
It is a beautiful machine to fly! I'm not at the 3D stage yet, but it behaves perfectly in sport flying!
That picture angle makes it look worse than it is... But i have been meaning to split the wiring evenly out each side of the frames.
That said, my beam is the most locked in heli ive ever flown!
Old 01-09-2013, 05:45 PM   #7
wadders248
There's not much to see yet, I just built the head in my lunch hour! I've been pleased with the small amount I've done so far.
Kasama UK Team Pilot | Bavarian Demon
wadders248 is online now        Reply With Quote
Old 01-10-2013, 07:48 AM   #8
lowey79
Looking good wadders!
It really is an under rated heli that goes together well! And it's a dream to fly. Just hope we can get a parts supply soon!
Old 01-10-2013, 07:06 PM   #9
wadders248
Thanks Lowey!
I thought I'd just build the tail section today, next thing I know and it's almost finished, apart from electrics.
Old 01-13-2013, 01:22 AM   #10
lowey79
I know what you mean. It just goes together very quickly, and the fit and finish of the parts is first rate!
Old 01-15-2013, 06:19 AM   #11
lowey79
So kits and parts are back in stock, so come on people... lets see those BEAM pics!
Old 01-18-2013, 01:34 PM   #12
wadders248
The servo's are in... I think my kit has a v1 OWB, so good to hear that parts are plentiful as that will get replaced before I try and fly it.
ID:	385342   Click image for larger version
Old 01-19-2013, 06:40 PM   #13
lowey79
Looking good! Does the OWB run directly on the main shaft? The V2 has a sleeve that mounts to the shaft and a larger (stronger) OWB.
Old 01-20-2013, 06:04 AM   #14
wadders248
Mine is definitely a v1 then, I don't want to risk running it! Thanks for the description...
Old 01-22-2013, 06:11 AM   #15
lowey79
There's no reason you can't run the V1 set-up, just don't push it too hard with high headspeed and smack 3D.
I've put 10-15 flights through mine without issue.
Old 02-15-2013, 03:26 AM   #16
wadders248
Most of the places I fly from are launched off grass and 95mm tail blades are pretty close to the ground. So I've had enough of cleaning the grass off the tail blades and stone chips. I've added a wedge between the rear landing gear and the frame to give it a bit more rake!
I know this is usless for doing any FBL unit setup, though I can always remove the wedge. I had originally planned to bend the landing gear, though it would be harder to get the heli level again.
Old 02-21-2013, 11:24 PM   #17
lowey79
I feel your pain! I'm contemplating doing the same thing!
Old 02-22-2013, 08:50 AM   #18
wadders248
After the disaster of the stock landing gear disintegrating, I've moved to something a bit sturdier, which need the shim adding to increase the rake! I've also swapped to 92mm tails, which give a bit more clearance. Hopefully they'll have the same hold. After playing with the governor gain and Beastx settings, I was getting perfect hold with 14 of pitch
I'm also in the process of swapping to a carbon control rod for the tail. The stock tail rod kept rattling, which I was mistaking for the belt being too loose. I meant to order the Align 600E rod, though thought I'd get the 600N rod and cut it to suit, though you can't just cut and re-apply the metal end. I bet the 600E set would have been just perfect. Anyway, I've got some Quick UK rod ends coming. The boom guide will just need slotting a bit rather than the round hole it has now, then it should perfect.
I also added some quick release canopy buttons on slightly wider mounts to push the canopy out a bit more around the batteries. The buttons work really well, though they're a pain to fit. The canopy holes have to be opened and file down the thickness of the fiberglass to fit the grommets.
Old 02-23-2013, 07:50 AM   #19
Kalle75
Hi Wadder,
nice you got your bird finished to take off again.
Landing skids are the Align now ?
I was wondering about another thing :
When i position my esc on the left frameside (under the maingear) the connectors to batterie go just next to the motor. Could be a bit nasty when they get in contact during flight.
Because of this i put my esc under the frame. Was going bad as i had to autorotate and it smacked hard onto the esc as the skid broke -> have to return the esc to service now.
Could you guys post a pic with connected esc to batterie ?
THX
Kalle
Kalle75 is offline        Reply With Quote
Old 02-23-2013, 01:43 PM   #20
wadders248
Wink
Originally Posted by Kalle75 View Post
Hi Wadder,
THX
Kalle
Sad to hear another failed landing gear! My new ones aren't Align, they're more like the Gorilla skids. The heli is at work, so I'll get you details of the gear and a pic of the ESC on Monday. I've rotated the ESC so the cables aren't near the motor.
Was it cold when the skids failed? I think mine failed because the cold made them brittle. My flying buddy looked at me in disbelief when I landed then the blades started a dust storm!
