Go Back   HeliFreak > R/C Helicopter Support > Mikado Logo Helicopters > Mikado Logo 700 Xxtreme
Mikado Logo 700 Xxtreme Mikado Logo 700 Xxtreme Helicopters Discussion
Old 12-03-2012, 11:58 AM   #21
Mathias
Hm, maybe Shawn up in Canada has anything to add? That's just to bad.
Mathias
Mikado Logo 700 Xxtreme | Blade 130 X | JR XG8 & Spektrum DX8
Mathias is offline        Reply With Quote
Old 12-08-2012, 10:26 AM   #22
Mathias
Might be a tad off topic, but oh well... I am getting some new hex drivers from PB Swiss Tools to prepare for my 700 build. Are round ball ends considered to be any good? The design enables you to use the hex at an angle up to 30 degrees from the center axis. What I am concerned about is the grip.
Thanks,
Mathias
Old 12-08-2012, 10:41 AM   #23
rcmarty
I've found the rounded ones to not have alot of grip on the socket. Good for tight spots but not for tighteneing.
I use the century helicopters set of drivers for standard length , and for the long reach stuff i found some turnigy hobby king ones with the carbon handles.
On another note i didn't require any odd angled screwes in the logo 800 build , i'd assume the 700 is the same but shrunk a bit. I'll know better once mine arrives
Martin
Logo XXtreme 8917 / 256HV
Logo XXtreme 700 8917 / 256HV
Logo 600 : bls451/ 9256 , V-bar , QUK tail , Edge 623FBL , Scorpion 4035-500
Logo 600se : bls 451/251, QUK tail , Edge 693/105 , Scorp 5020-450 for sale
rcmarty is offline        Reply With Quote
Old 12-08-2012, 11:44 AM   #24
taoY
I use 4 mm hex ball driver. The only complaint I have is they don't sit in the socket head as the straight one does. Extra care is needed when working on the feather shaft with two hex driver at both ends.
None of the bolts need to work at an angle.
Cheater
taoY is online now        Reply With Quote
Old 12-08-2012, 12:39 PM   #25
Mathias
Okay, going with the standard hex drivers then.
While I'm at it... Could any of you 700 owners be so kind to check some dimensions on the 700 for me? I am thinking about getting this carrying bag for my 700, but since I am currently stuck in an air force base, I am not able to verify that the bag will fit. The measurements are: 1500 mm (length) x 320 mm (width) x 490 mm (height).
Much appreciated,
Mathias
Old 12-08-2012, 08:10 PM   #26
rcmarty
I was reading another thread talking about size/weight.
Mikado labels it as a 700 to keep with there traditional theme of labels, in todays standards it's more like a 750 so i'm going to vote no on the 700 sized bag.
Of course i could be wrong
Martin
Old 12-09-2012, 05:39 AM   #27
Mathias
On the ReadyHeli page, it says 139 cm in length. Is that the span from the front of the canopy to the rear of the tail? In that case, it will fit length wise. On height I am not sure, but I do remember reading something about it being 40 cm high. If that is correct, it will fit there too.
Could anyone verify this please?
Mathias
Old 12-09-2012, 09:08 AM   #28
Luisito
On the bag issue, I agree you may want to find one that can hold a 750 since the XXTreme 700 can swing 753mm blades. I have both the Heli Guard and the Align 700 and neither will hold the XXtreme.
The Heli Guard comes really close, which is what I'm using to carry it now, but the tips of the tail fin stick out. I just zip up from the front all the way to the back leaving the fin exposed.
The Align bag carries my Logo 600SE just fine.
Luis
Logo 700 XXtreme, SAB Goblin 700, SAB 770: Logo 600SE Carbon Fiber Frame 12S: Pyro 700-45, Kontronik 120 Heli Jive, 11T Pinion, Full Size V-Bar 5.3, 693/105 Blades Align 550E: Pyro 600-12, CC100, 17T Pinion, Full Size V-Bar 5.3, 553/86 Blades
Luisito is offline        Reply With Quote
Old 12-09-2012, 09:48 AM   #29
Mathias
So I checked the dimensions of The Heli Guard 700. The dimensions are 138 mm (length) x 210 mm (width) x 440 mm (height) compared to the measurements of the Fast Lad one - 1500 mm (length) x 320 mm (width) x 490 mm (height).
Luis, do you still think it wont fit with the additional 22 cm added in length, 11 cm in width and 5 cm in height?
Thanks,
Mathias
Old 12-09-2012, 10:02 AM   #30
Luisito
I may be headed out to the field to fly in a few hours. I'll take a picture and a measurement on how far the fins are exposed...
Old 12-09-2012, 10:06 AM   #31
Mathias
Sounds great! How is the space for the 700 Xx as far as width and height goes?
Mathias
Old 12-09-2012, 10:17 AM   #32
Luisito
Width and height are fine as long as you don't use the Mikado foam blade holder. I use the Align ones to drop the blades down an angle where it fits nicely....
Old 12-09-2012, 10:51 AM   #33
Mathias
Got it. Looking forward to hear about your findings.
Mathias
Old 12-09-2012, 03:27 PM   #34
Luisito
Here are the pictures with the Heli Gaurd:
Hope this helps,
Luis
ID:	372577   Click image for larger version
Old 12-09-2012, 05:11 PM   #35
Mathias
Much appreciated, Luis! Looks like it will work.
Mathias
Old 12-15-2012, 08:32 AM   #36
Mathias
I went with a nice bag from Revolectrix.
Mathias
Old 12-15-2012, 09:06 AM   #37
zguy
Does the 700 fit in the Revolectrix bag? Tight?
zguy is online now        Reply With Quote
Old 12-15-2012, 11:39 AM   #38
Mathias
According to the measurements it should. I hear people are fitting TDRs in too. The TDR is actually 3 cm longer than the 700. Should be plenty of room to spare.
Mathias
Old 12-15-2012, 11:42 AM   #39
zguy
Please post when you get it.
$32- shipping! :eek:
Old 12-15-2012, 12:22 PM   #40
taoY
Please report back. I have a bag that fits TDR but too short for Logo700. Logo 700 is longer than TDR.
Cheater
