Go Back   HeliFreak > R/C Helicopter Support > Mikado Logo Helicopters > Mikado Logo 700 Xxtreme
Mikado Logo 700 Xxtreme Mikado Logo 700 Xxtreme Helicopters Discussion
Old 12-15-2012, 01:54 PM   #41
Mathias
Originally Posted by zguy View Post
$32- shipping! :eek:
By Norwegian standards, that's very reasonable.
I did a search on the measurements. The TDR is apparently 1420 mm long, while as the Logo 700 is 1390 mm long. I guess that Mikado and Henseleit has some different methods for indicating their measurements.
Anyways, the bag is 1500 mm long, which should be sufficient enough to carry the L700. Height and width should be plenty as well.
Yea, I'll post back when I get it.
Mathias
Mikado Logo 700 Xxtreme | JR XG8 & Spektrum DX8
Mathias is offline        Reply With Quote
Old 12-18-2012, 12:20 PM   #42
Mathias
To the guys running an external RX pack - where do you put it?
Mathias
Old 12-19-2012, 09:13 AM   #43
taoY
Looks like RX packs is not a popular choice. I would try the compartment after the main battery or the one after that.
Cheater
taoY is online now        Reply With Quote
Old 12-19-2012, 09:44 AM   #44
dahld
RX pack? The instruction manual shows a BEC located between the frames behind the aft frame brace. Kyle places the 2S 1350mah RX packs that he uses on his 700's in the same location.
(-: Dave
Kyle Dahl
Sponsored by:
Mikado, JR, Voltz/Thor, Scorpion, Edge Blades.
dahld is offline        Reply With Quote
Old 12-19-2012, 03:45 PM   #45
Mathias
Will try that!
Mathias
Old 12-20-2012, 09:14 PM   #46
kevinbj
What did you use to level you swash? Also how many mm is the main shaft for swash.. I measured 14mm but not sure if I did it properly ..
kevinbj is offline        Reply With Quote
Old 12-21-2012, 03:32 PM   #47
Mathias
Yes, it should be 14mm. I have a 14mm swashplate leveler from Fast Lad Performance. I do also have the RDLohr 14mm swash leveler, but I really don't like the wobbly design of it, as you would have to be very precise when installing it. I do have the RC Logger 2 too. It has a 13m swashplate leveler, and I am wondering if it might work on the L700.
Hope that helps.
Mathias
Old 12-22-2012, 02:19 AM   #48
taosgraveyard
Ditto on the lohr leveler, could not get it to slough the same way twice... Tossed it I the junk bin. Bought the one from fast lad,
Kasama Srimok Faifa 90e, Synergy E5, Synergy E7, Goblin 500, Goblin 630, Goblin 700, Goblin 770, Logo 500, Logo 600 SE, Logo 700, Logo 800, TDR, Diabolo. Voodoo 600
taosgraveyard is offline        Reply With Quote
Old 12-22-2012, 02:49 AM   #49
KnifeEdgeUk
do u have a link to the fast lads one?
KnifeEdgeUk is offline        Reply With Quote
Old 12-22-2012, 04:07 AM   #50
taosgraveyard
Go to
http://www.fast-lad.co.uk
In the search enter "leveling"
You'll find it in the results
Old 12-22-2012, 10:09 AM   #51
Mentalic
First few flights on my 700 I used a larger receiver pack. Only place I found was under the frames. To hold it there I made a balsa box that just fit inside the frame and two of the frame joiners. Velcro'd the box to the pack and the assembly would just push up into the frame, then strap in.
Don't use this anymore because I went with a WR BEC and WR battery buffer unit with a small 2s450mah pack as backup. For me I wanted a redundant receiver power system and it weighs less than what I originally had..
I'd upload a picture of the original battery set up but the site times out, must be more ddos attacks...
Wayne
Logo 600/ Logo 600se/ Logo 700
Mentalic is offline        Reply With Quote
Old 12-22-2012, 05:31 PM   #52
Mathias
Did you guys use any special method when gluing the TT holders to the tube?
Mathias
Old 12-22-2012, 06:14 PM   #53
dahld
FWIW, we never glued the TT bearings to the tube. Just taped the bearing and it's holder in in its proper place on the tube by wrapping tape on both sides, and then installing it in the tube.
Kyle flew A LOT of flights on his Logo 700's in 2012 (flew today as well), and never had an issue with the tube not being glued to the bearings.
It can't hurt of course, unless you get glue in the bearings...which is why we tried it without, and never looked back.
(-: Dave
Kyle Dahl
Sponsored by:
Old 12-22-2012, 06:38 PM   #54
Mathias
Yea, getting glue in the bearings is my concern too. What tape did you use?
Mathias
Old 12-22-2012, 11:25 PM   #55
dahld
Standard issue Scotch tape (-:
(-: Dave
Kyle Dahl
Sponsored by:
Old 12-23-2012, 12:30 PM   #56
rcmarty
I used some 5 min epoxy.
Marked the locations with a sharpie ,
put a light coating on tubr with finger.
then slid bearing over the epoxy watching to see if it builds up. when it builds up a bit ( looks like a ring around tube ) i slid the bearing back , then run finger over again to remove ring. Then try bearing again. Once it will go past the epoxy section , i move it back and forth a few times to get the epoxy worked into the inner side of the bearing.
Trick here is to get the expoxy worked in the space between the bearing and tube , not at all about quanity. So a small smear and your good.
About the size of a dime i did all bearings and end drive caps.
But using tape like dave does works to get them in place , once there in place there isn't any reason they would move.
Martin
Logo XXtreme 8917 / 256HV
Logo XXtreme 700 8917 / 256HV
Logo 600 : bls451/ 9256 , V-bar , QUK tail , Edge 623FBL , Scorpion 4035-500
Logo 600se : bls 451/251, QUK tail , Edge 693/105 , Scorp 5020-450 for sale
rcmarty is offline        Reply With Quote
Old 12-23-2012, 02:19 PM   #57
taoY
I use the same technique as Martin but I use thin CA instead. To prevent CA goes into the bearing, I put a drop of tri-flow on the gearing. If CA does get to the bearing, it will form into a thin film and can be easily wiped off. Practice makes things perfect. After few times, you will make it perfect every time. Another trick is using toothpick to apply CA on the torque tube.
Of course tape works great too and easy to remove if you need to. The key is to fix the bearing in place. I will try tape next time. Thanks Dave.
Cheater
Old 12-23-2012, 04:47 PM   #58
rcmarty
My track record with thin ca and making a big mess is long .. lol
Martin
Old 12-23-2012, 05:31 PM   #59
Mathias
Here is what I did. I wrapped 5 cm of cut medium thickness Scotch fiber tape around the tube. Then I sealed the edges and seams with CA. I had to use some CA kicker to make things effective. The last thing I did was to pack the inside of the boom and the o-rings with clear synthetic grease from Triflow.
By doing it this way, I am certain that the bearings didn't get messed up. I do however find that the solution is a bit "cheapish", though. My concern is that I will experience small vibrations due to the small displacements in weight distribution around the tube. The method is not exactly very precise. On a different note - if it's good enough for the Dahls, it should be good enough for me...
ID:	376456   Click image for larger version
ID:	376457   Click image for larger version
ID:	376458   Click image for larger version
Mathias
Old 12-23-2012, 10:16 PM   #60
Stolla
I would advise first pulling on the Bearing holder to be sure it doesnt come off bearing, then small drop of ca all you need to keep bearing in place, if the cover comes off ca as well, epoxy is not the answer as its too thick and messy on the small tolerances, off course be careful with the ca. My covers came off so obviously i am not a fan of the system.
Tdr quantum 4530 1.4 yy h/ jive120 beastx, Vibe e 8 12s mx 700 1.32yy vbargov, Banshee nr 36 kosmik 200 pyro 800 1.4yy 455kv 14s beastx, xtreme 700 pyro 850 1.5yy 14s kosmik 200
