Go Back   HeliFreak > R/C Helicopter Support > Mikado Logo Helicopters > Mikado Logo 700 Xxtreme
Mikado Logo 700 Xxtreme Mikado Logo 700 Xxtreme Helicopters Discussion
Old 01-01-2013, 07:27 PM   #81
futurase
I honestly don't think it matters. If I can ever get my hands on some more a TDR comes with couple of pieces of a teflon-like heat shrink that is slick not grippy like regular heat shrink. It shrinks down super tight to the tail rotor pushrod and that part is what slides through the pushrod guides on a TDR. It would work perfect on a L500-L800 tail rotor push rod and maybe even the L400 I forget the tail rotor pushrod diameter on it.
That is what I need on mine. It works fine with two supports and there is no friction, but the TDR is like buuuuuutter!
Norman Ross Jr.
Team KDE DIRECT
Team Insane Canopy
futurase is offline        Reply With Quote
Old 01-01-2013, 10:21 PM   #82
Mathias
I used that on my Logo 500. Thanks for reminding me - I'll add that to the 700 as well.
Mathias
Mikado Logo 700 Xxtreme | Blade 130 X | JR XG8 & Spektrum DX8
Mathias is offline        Reply With Quote
Old 01-01-2013, 11:02 PM   #83
rcmarty
any idea what it is ? link ?
I'd like some also.
My 800 rod is partially sanded down and is a bit smaller in diameter after 60 flights
Martin
Logo XXtreme 8917 / 256HV
Logo XXtreme 700 8917 / 256HV
Logo 600 : bls451/ 9256 , V-bar , QUK tail , Edge 623FBL , Scorpion 4035-500
Logo 600se : bls 451/251, QUK tail , Edge 693/105 , Scorp 5020-450 for sale
rcmarty is offline        Reply With Quote
Old 01-01-2013, 11:30 PM   #84
panz
Originally Posted by futurase View Post
.....a TDR comes with couple of pieces of a teflon-like heat shrink that is slick not grippy like regular heat shrink. It shrinks down super tight to the tail rotor pushrod and that part is what slides through the pushrod guides on a TDR. It would work perfect on a L500-L800 tail rotor push rod and maybe even the L400 I forget the tail rotor pushrod diameter on it.
Synergy helis come with something like that: http://www.fblrotors.com/Tail-Push-R...eve_p_158.html
panz is offline        Reply With Quote
Old 01-01-2013, 11:33 PM   #85
futurase
That looks like the stuff Panz posted...
Team KDE DIRECT
Team Insane Canopy
Old 01-02-2013, 04:05 AM   #86
stocksy27
Originally Posted by dahld View Post
FWIW, we never glued the TT bearings to the tube. Just taped the bearing and it's holder in in its proper place on the tube by wrapping tape on both sides, and then installing it in the tube.
Kyle flew A LOT of flights on his Logo 700's in 2012 (flew today as well), and never had an issue with the tube not being glued to the bearings.
It can't hurt of course, unless you get glue in the bearings...which is why we tried it without, and never looked back.
(-: Dave
Could use heatshrink either side of bearing?
stocksy27 is offline        Reply With Quote
Old 01-02-2013, 08:40 AM   #87
Mathias
Yea, that's it. I got mine from ReadyHeli years back. Try searching for "teflon heat shrink tubing".
Mathias
Old 01-02-2013, 06:46 PM   #88
Mathias
Originally Posted by taoY View Post
Please report back. I have a bag that fits TDR but too short for Logo700. Logo 700 is longer than TDR.
Got the bag today. Yup - today! It has taken forever to get it. Both FedEx and the national postal service took their time...
As I promised, here are some details. It does fit. Actually it fits perfect - maybe even a little too perfect, as the L700X filled the whole thing with no room to spare. If you decide to get one - let's just hope there's no big production tolerances. I don't believe so, though.
That being said, the quality is excellent - really top notch. The outer fabric seems very solid, while as the inner padding is pretty soft. Nice design too.
ID:	380014   Click image for larger version
ID:	380015   Click image for larger version
ID:	380016   Click image for larger version
ID:	380017   Click image for larger version
ID:	380019   Click image for larger version
Mathias
Old 01-02-2013, 07:00 PM   #89
taoY
Thanks, Mathias. Nice to know it fits.
Cheater
taoY is online now        Reply With Quote
Old 01-07-2013, 04:33 PM   #90
OICU812
Cool like the bag indeed!!!
OICU812 is offline        Reply With Quote
Old 01-20-2013, 05:30 PM   #91
rexxigpilot
Why does the manual show female bullet connectors for the motor side of the ESC motor connections? I assume this is an error and male bullets go on the motor side as usual?
rexxigpilot is offline        Reply With Quote
Old 01-20-2013, 06:01 PM   #92
dahld
I'm with you. The male side of the connectors traditionally go on the motor side. All ours are set-up that way. I guess it's and error, although since it ultimately doesn't matter, I guess it's not "technically" incorrect But certainly not the standard.
(-: Dave
Kyle Dahl
Sponsored by:
Mikado, JR, Voltz/Thor, Scorpion, Edge Blades.
dahld is offline        Reply With Quote
Old 01-21-2013, 07:25 AM   #93
rexxigpilot
Thanks Dave. I just wanted to make sure there was no reason Mikado showed it that way.
Old 01-26-2013, 08:59 AM   #94
rdlohr
Originally Posted by Mathias View Post
Yes, it should be 14mm. I have a 14mm swashplate leveler from Fast Lad Performance. I do also have the RDLohr 14mm swash leveler, but I really don't like the wobbly design of it, as you would have to be very precise when installing it. I do have the RC Logger 2 too. It has a 13m swashplate leveler, and I am wondering if it might work on the L700.
Hope that helps.
Originally Posted by taosgraveyard View Post
Ditto on the lohr leveler, could not get it to slough the same way twice... Tossed it I the junk bin. Bought the one from fast lad,
Really sorry you weren't happy with my tool. Once you install it and give it a turn to level it, then turn the main shaft and make sure it is level, manually level it if need be turning the main shaft to verify it is perfectly leveled. Once it is level, you can now use it to level your swash. I added the main shaft turning part to the instructions since I had a few people who were having a hard time getting repeatability. If that doesn't work out for you, please let me know and I'll take care of you.
I just used the 12 mm version on my new Rush and it worked great.
Rick
Helifreak, the place to be!
Rush 750,Logo 400SE 600SE, TREX 450SE, 500, 600, Blade mCPX,130X
My products, flown by top pilots around the world, like you!
rdlohr is offline        Reply With Quote
Old 02-07-2013, 07:55 AM   #95
abanihani
I have been using Rick's tools on all my 7 helis with perfect results and could not have been happier. Just follow the instructions and you are set to go.
Banshee #26, Vibe SG 12E Hiroki ito, Forza, Diabolo, Triabolo, 800 plus, Raptor E820, Logo 600sx, logo 600SE Uvular, Logo 600SE mikado Hughes scale
abanihani is offline        Reply With Quote
