Go Back   HeliFreak > R/C Electronics Support > Spartan RC
Spartan RC Spartan RC - Quark, DS760 Gyros and other Spartan RC Electronics Factory Support
Old 01-30-2008, 04:42 AM   #301
psindrup
Hi Bob.
If you are laughing at me, I was definitely not trying to "get as much as possible" - but the correct amount of gyro gain. My tail wags just a little, so I believe it is time to turn down the gain, from the initial recommended setting of 74% on the DX7.
Best regards
Peter
psindrup is offline        Reply With Quote
Old 01-30-2008, 04:45 AM   #302
Angelos
Bob,
the text on the user guide actually continues and covers exactly what you just mentioned>
It is not uncommon to find that the optimal gain value for a helicopter may be a small number such as 35-45%. The small value does not mean that the gyro will be limited in performance. Any gain value performs well as long as it is the optimal gain value. However, a gain below 35% indicates that the mechanical gain of the tail is too high and it is therefore recommended moving the servo arm ball link further in. Similarly if 100% is reached and no tail wagging is seen the ball link needs to be moved further out and repeat the gain adjustment procedure.
Also on a related topic - the mounting of the ball link on the servo arm - which affects the mechanical gain>
We recommend that the ball-link is mounted 13-17mm from the servo shaft unless a different distance is deemed essential for a particular helicopter. Ultimately, the most important factor is the servo travel which ideally should be around 45 on either side of the mid-point (+/-15%). For most servos this will result to gyro endpoints in the range 85-115%. This combination gives a good balance between tail pitch correction speed and available torque. If the servo travel or endpoints are significantly different than this recommendation you may wish to change the ball-link position to restore this balance.
-Angelos
SPARTANRC - R&D
Angelos is offline        Reply With Quote
Old 01-30-2008, 04:51 AM   #303
Finless
Team Taco VP
Originally Posted by psindrup View Post
Hi Bob.
Best regards
Peter
Peter the DS gyro works a bit differently than others I have used. Too high a gain shows it in down wind flight before it shows it in just hover conditions. If your getting wag in hover then yea it's too high but also watch how the tail works when it is into the wind as you can get a wag if gain is still too high.
BTW no I was not laughing at you! I was laughing when Angelos posted that topic and the laugh was agreeing with him!
So you know on my Nitro600 with 9256 servo I am running 24% gain! YES that low! but the tail is a rock! Don't over work your tail servo by thinking a higher gain is needed!
Bob
Old 01-30-2008, 05:02 AM   #304
psindrup
Hi Bob
Thanks for clearing that out.
I was hovering in pretty windy conditions (for me at least) and I definitely saw some wagging.
Now I have to go back to school to check how the gain is calculated with regard to the "50% mid point" reference on the DX7
Peter
Old 01-30-2008, 05:08 AM   #305
Finless
Team Taco VP
Thats easy Peter... JR (DX) works like this
X = gain
(50-X) x 1.44 = true gain
so lets say you have 70 in your gyro menu on the DX.
70-50 = 20
20 x 1.44 = 28.8 or 29% gain in the rounding.
Futaba radios dont do this and if your usng GEAR end points on the DX instead of the gyro menu, it is more 1 to 1 (but not quite). OK?
Make sense?
Bob
Old 01-30-2008, 07:31 AM   #306
highland flyer
Hi Peter for A500 DS760 DX7 heres some good numbers to start from. DX7 Align 500 with Futaba 9257 my gain in Tx is 38% Servo horn length is about 10mm.
Start with you rudder endpoints set around 90% for a managable piro speed and increase decrease to suit.
cheers Brian
highland flyer is offline        Reply With Quote
Old 01-30-2008, 08:11 AM   #307
psindrup
X = gain
70-50 = 20
Make sense?
Bob
That makes a lot of sense! :wink:
Having my DX7 set to HH = 74% makes my true gyro sense:
74-50=24x1,44 = 35% true gain
Compared to your setting of 24% on your T-rex 600, it seems quite a bit to high.
New setting: (25/1,44)+50=67%
Peter
Old 01-30-2008, 08:13 PM   #308
Sam2b
Smile
RC Helicopters 101 should be given in high school so we don't bust our brains with all the super education we need just to BEGIN to understand this stuff. Oiy!
_Sam B_
Team MSH USA, Prtos Max v2 ● Brain Flybarless System ● Xpert servos ● Xnova motors ● Cyclone Blades ● ProgressiveRC ● VoltMagic ● Ecalc
RCHN Citizen 662
Sam2b is offline        Reply With Quote
Old 01-31-2008, 02:28 AM   #309
psindrup
Or put another way. If we had listened in high school, we wouldn't have such a hard time understanding this stuff now.
Peter
Old 01-31-2008, 06:14 AM   #310
leeph
The manual states 'To fly in rate mode set the linkage lengths for approximately 8 degrees tail pitch in the direction that compensates the main rotor torque'.
Does that mean that this adjustment is not required for AVCS flying? TREX 500 manual states setting the tail pitch at 0 degrees when tail servo horn is at 90 degrees, so you get full travel of the pitch slider left and right. If I set the pitch on the blades to 8 degrees while the servo is at 90 degrees, won't there be less throw on that side? Could someone explain why you can't just leave the blades at 0 degrees pitch while the servo horn is at 90 degrees.
Cheers
leeph is offline        Reply With Quote
Old 01-31-2008, 07:08 AM   #311
TheBum
In AVCS mode, the gyro is going to push the blade pitch to about 8 degrees anyway, so there's no throw advantage either way. The only way you'd gain greater throws is if the blade grips could be adjusted to have 8 degrees of pitch when the pitch slider is at center.
HeliFreak Support
DT520Ev2 (VBar), Protos Max V2 (Brain, at least initially), Blade 180CFX
TheBum is offline        Reply With Quote
Old 01-31-2008, 09:21 AM   #312
Angelos
Cheers
You only need the 8deg adjustment if you want to run in rate mode. However, keep in mind that if rate mode is not set the heli may piro uncontrollably if you accidentally switch to it in flight.
Regarding the recommendation in the helicopter manual, there is no need for the left and right throws to be perfectly symmetrical but see if you can keep them within +/-15% as the user guide suggests. As long as full pitch can be reached on both sides the gyro will work fine.
-Angelos
SPARTANRC - R&D
Old 02-05-2008, 10:56 PM   #313
Sam2b
What is the best method of measuring the tail blades to 8 degrees? From the 200 size heli's to the 90 size helis. Is there a common way to measure the tail blades?
_Sam B_
RCHN Citizen 662
Old 02-05-2008, 11:34 PM   #314
BruceW
Here is an outline of a blade at 8 degrees. Scale it, print, and cut it out and hold it next the boom and blade. You'll be amazed how well your eye can pick up the angle.
Logo 500 3D /Scorpion HK4020-1100KV (16T)/Jazz80/BLS451/Spartan DS760/BLS251/RT 560mm/AR9000
TRex 450SE
/Scorpion HK-2221-8 (13T)/ AlignESC35(X)/ HS65MG/Spartan DS760/S9650/AR6100
Spektrum DX7
BruceW is offline        Reply With Quote
Old 02-06-2008, 01:40 AM   #315
Sam2b
Thanks, Bruce. How did you ensure this image is 8 degrees? (for curiosity's sake)
_Sam B_
RCHN Citizen 662
Old 02-06-2008, 01:51 AM   #316
BruceW
I used Paint Shop Pro and typed in 8 degrees rotation on a section containing the shape.
TRex 450SE
Spektrum DX7
Old 02-06-2008, 08:46 AM   #317
nikpro
I bought the USB interface cable and can't get it to work in either Vista or XP; I have downloaded and installed the drivers about 10 times but windows keeps telling me it's an unknown device - what am I doing wrong??
My other Hobby is Racing and preparing Cars!
nikpro is offline        Reply With Quote
Old 02-06-2008, 06:01 PM   #318
Fergus
Just got my ds760 today from revolution models. I know it will have been worth the wait : )
Regards
Fergus
Fergus is offline        Reply With Quote
Old 02-06-2008, 08:14 PM   #319
Big Fil
Wondering if the metal plate is needed/recommended on a Trex600E. I was happy to find that the gyro itself is quite a bit lighter than the 401 it's replacing, but with the addition of the plate it seems heavier. My bird is slightly tail heavy so it would be nice to lose the weight, even if small, but not at the expense of gryo performance. Anyone else running one on a 600E yet and did you use the plate?
Thanks, can't wait to fly this thing.
Mikado Model Helicopters
Edge Blades
Big Fil is offline        Reply With Quote
Old 02-06-2008, 11:00 PM   #320
franticf
Just installed my second DS760 in my Trex 600, both were purchased from Mark Webber. Thanks again Mark. my first one I installed was in the Trex 500. I used the Align pitch gage set for 8 Deg. and sliped it over the tail rotor and aligned the edge of the gage paralell to the boom..
franticf is offline        Reply With Quote
