Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 425
Hurricane 425 Discussion and support of the Gaui Hurricane 425
Old 11-18-2012, 08:30 PM   #1
SQRT(-2)
Default Trex 500 FBL head fit?
Will the Trex 500 FBL head fit? Someday I may want to go FBL and the Tarot is $40.
Gaui Hurricane w/ 530mm blades & Robird G31
Walkera Super CP
Walkera Devo 10 w/ Deviation
SQRT(-2) is offline        Reply With Quote
Old 11-30-2012, 11:29 AM   #2
kavic5150
Post
Both have an 8mm diameter main shaft. I had a look at the standard trex 500 main shaft and it has a smaller diameter section on one end.
http://helidirect.com/align-main-shaft-h50086-trex-500-p-6586.hdx
http://www.helifreak.com/showthread.php?t=412770
Same deal with the trex 500 FBL main shaft...
http://www.espritmodel.com/h50133t--trex-500-fbl-main-shaft-2.aspx
So you will probably need to use a gaui mainshaft.
I dug up an interesting thread on the topic:
http://www.helifreak.com/showthread.php?t=455418
You might want to send Sp00fman a PM and ask which FBL head he bought.
And if all else fails you could just spring for an X4 FBL head that is listed as compatible with the 425:
http://www.heliflightcenter.com/204685_Gaui_X4_FES_2_Blade_Rotor_Head_Assembly_p/204685.htm?gclid=CISK6sqM97MCFQqk4AodQh0AUw
I know as much about going FBL as I do interior decorating. Very little. Hope this post helps.
kavic5150 is offline        Reply With Quote
Old 03-21-2013, 06:50 AM   #3
pioppo68
Default Yes it fit
After a crash I replaced the head with Align FBL. I have only shortened the main shaft of 12mm and redone hole 2,6 mm to fix the head.
I am not able to insert the image sorry
pioppo68 is offline        Reply With Quote
