Go Back   HeliFreak > R/C Electronics Support > Thunder Tiger GT5 FBL System
Thunder Tiger GT5 FBL System Thunder Tiger GT5 Flybarless Electronics
Old 11-19-2012, 08:21 AM   #1
SQRT(-2)
Default Does it work with STD RX?
Hi, silly question, they show the GT5 with a sat plugged into it, but my radio does not use sats, does it work with a standard RX? You know, by running all the channels into it through separate wires form the RX.
Gaui Hurricane 425 FBL with Robird G31 500 Class Rocks!
EFlight Blade 450 3D, Walkera Super CP
Walkera Devo 10 w/ Deviation
SQRT(-2) is offline        Reply With Quote
Old 11-20-2012, 02:01 AM   #2
NitroAl
It sure does, thats the only way I'll do it!
CustomHeliParts/KDE TRex 700N
ThunderTiger X50 FBL
Ely.Q Vision 90
Ely.Q Vision 50
NitroAl is offline        Reply With Quote
Old 11-20-2012, 04:58 AM   #3
Laurens
+1, you can even use your old 35/72mhz radio.
Team Thunder Tiger Europe
4RC.nl, Edge rotorblades, Scorpion systems
Laurens is offline        Reply With Quote
Old 11-20-2012, 08:47 PM   #4
Bladecpnitro
Have you seen the youtube 1-5 setup vids on the GT-5?.
Its just a nice close up look at it and a breif setup demonstration. I got mine in the mail yesterday right here of helifreak forums. Can't wait to try it on my EXI 450. I also plan to use an RX and also plan to use it as a tail gyro until my FBL head gets here.
DX 7, EXI 450 FBL GT-5, HK 250 FB Quark, Nano Brushless 16500KV 125mm boom
Bladecpnitro is online now        Reply With Quote
Old 12-20-2012, 10:28 AM   #5
kahn6976
First choose the manual
1.Wrench manual
2.Rx type
3.choose "Spektrum "
Now ,You can use the Satellite RX.
kahn6976 is offline        Reply With Quote
