Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > NX4
NX4 Discussion and support of the Gaui NX4 Nitro Helicopter
Old 12-27-2012, 08:35 AM   #21
Jesse
I had the same problem on the throttle linkage I had to cut it down with a dremel to get my arms 90 and 90 to the linkage. as for the fan I would assume epoxy cause your cluing metal, but I don't have magnets so I don't take my word for it. the bubbless clunk in the main.
Jesse is offline        Reply With Quote
Old 12-27-2012, 08:45 AM   #22
tauscnc
Originally Posted by crickr1 View Post
Alright, have my motor now and finishing the build.
Few more questions;
I'm running a header tank, also picked up a "bubbleless" clunk.
should I use this in the main tank and the metal klunk (came with quick uk header) in the header?
Also, I have Lynx cnc fan, Do I ca glue or epoxy magnets to it?
On my th servo,,I have the linkage as small as I can make it(about 84mm) and the manual says 81mm. The servo arm and th arm are not perfectly aligned, off by a couple degrees.
Will this be ok or should I shorten the linkage rod?
Thanks guys can't wait!
Congrats, almost done!
Bubbleless clunk would go in the main tank. The header will be a backup reserve for the bubbles which might get through. I use a fuel magnet in my main and clunk in the header. Use a fuel filter between header and engine like the align 3 way fuel filter.
I would epoxy the magnet or use JB weld epoxy. Make sure to clean the hole and roughen it up a little (I just used a little screw driver). Make sure the correct side is up. I personally just put one magnet in and a 2 mm hex nut on the other end. If I lose a magnet I have a spare ready.
I would cut a few threads off the link and make it as perfect as you can now. I don't think it will matter especially if you are using a gov. But why not get it as close to perfect now. Once flying that is all your gonna wanna do as it flys awesome!!
tauseef
www.cuttingedgecnc.com
tauscnc is offline        Reply With Quote
Old 12-27-2012, 01:09 PM   #23
crickr1
can I use regular fuel line for the clunk? I have dubro nitro line?
None of my local shops carry "clunk" line
Keep it in the air!
Lovin MSH!
hybrid Gaz/otos fbl,stretched 6s MiniP Stretched PROTOS 500 ,EC135 Era/Protos500,Compass 6HV, Gaui NX4 all MSH-Brain/Futaba8FG Compass 3D+ CGY750
crickr1 is online now        Reply With Quote
Old 12-27-2012, 01:36 PM   #24
tauscnc
Yes, regular line should be fine... Just make sure it is not to long so the cluck does not get stuck in the tank. The line they give is nice because it is so flimsy but seems to tear at point of input. I am using regular line with my fuel magent.
Old 12-27-2012, 02:25 PM   #25
crickr1
Keep it in the air!
Lovin MSH!
