| Align 3G FBL System Align 3G FBL Flybarless System Software and Hardware Support |
OK Heli Gurus, I need help. I have a 3G on my 450 Sport and no matter what I do I cannot get rid of my constant tail wag - here is what I tried:
Made sure belt was plenty tight Made sure t-pitch slider was smooth Made sure no binding in t-servo pushrod Gyro gain set on Aux2 with endpoints Moved ball on servo arm both in and out Set the gains all over the map. This is running wiht a Futaba 9257. Any bright ideas/suggestion would be much appreciated. Thanks
RC Heli Pilot = Control Freak |
#2 | |
You can also tighten the belt to much and cause escessive vibes. With the tip of a driver the belt pushed to the centerline of the boom with moderate pressure is about the proper tension
Align 450Pro 3GX, Align 500 3G Align 550 3g, Velocity 50 Vbar |
Bad, thanks for the tip I will give this a try.
Loosening the belt a bit did the trick -thanks
LOL, that's why I went to all TT. Got tired of checking and adjusting the belt everytime the temps changed.
