Go Back   HeliFreak > R/C Helicopters > Aerial Videography and Photography > Realtime Video and FPV
Realtime Video and FPV Discussions of receiving video in realtime from the aircraft
Old 11-22-2012, 09:08 PM   #1
nuttzzy
Default what to choose, what to choose?
so i just got a F550 with Naza and GPS.. now i wanna look for a cam,tx/rx not sure how im going to view it yet i have a ipad and computer tho im looking at the Fatsharks..
I've seen some of them from fox.. and some from heli hobby and stuff.. not gonna lie i have no idea what the 5.8 and 2.4 and all that means i know they are frequencies but transmitter strength and distance.. what will interfere with my DSM2 Signal or what.
Ill have a Gopro 3 eventually for recording so I'm just interested in FPV now..
so whats the best method.. i think the Fatshark would end the end be the best method blocks the sunlight and you see the screen.. but what happens if you need to switch to external view? like if you need to see around your craft and the cam isn't picking it up? i know the go pro can Wifi to a iPad using the app but im sure that limited on distance.. so can some of you guys help me? just looking for a 720 or so i know the fatshark cant do HD so no since in paying for a HD the recording will be HD. but as for my eyes and guiding the craft idc. only two options i need are 500-1000m or so.. and viewable but not hd.. and not a huge Camera.. and an add on for OSD... i know it wont be cheep but.. what are you guys thinking? cause im gonna be honest i look at them on the screen read the specs and then look at the next and read the spec and nothing compares to the other in my mind.. they all seem equal. but i dont wanna buy something that wont be good because it says "its the best cam around!" please help me out..
nuttzzy is offline        Reply With Quote
Old 11-23-2012, 11:46 PM   #2
sl4ppy
All of the frequencies used to transmit video require an amateur radio operator license, so you'll need a HAM license to do anything first.
sl4ppy is offline        Reply With Quote
Old 11-24-2012, 12:19 AM   #3
anhquan1
What class do we have to apply or test on. Can you post a link for us.
anhquan1 is offline        Reply With Quote
Old 11-24-2012, 03:22 PM   #4
sl4ppy
Not sure I understand the question, but I think this is what you want.
http://howto.wired.com/wiki/Become_a_Ham_Radio_Operator
Old 11-24-2012, 10:34 PM   #5
anhquan1
Thank you for the link.
I plan on using EZ UHF setup, what should I take a test on: Technician Class, General Classor Amateur Extra.
Old 11-24-2012, 10:55 PM   #6
anhquan1
I found your answer from another thread. Thank you.
Sorry Nuttzzy for hijack your thread.
Old 11-24-2012, 11:06 PM   #7
nuttzzy
haha no problem..
Old 11-26-2012, 07:25 AM   #8
rmalt
The technician class is the one you need which is element 2. I joined this to study from.
https://www.hamradiolicenseexam.com/login.htm
Pulse XT 60 Saito 100
~KBDD Team Pilot~
rmalt is offline        Reply With Quote
Old 12-01-2012, 09:07 AM   #9
Brian4301
Small question to clear up my understanding/confusion.
sl4ppy....I checked the site on your post which has a lot of info but doesn't seem very clear on what is needed for FPV. The technician class is the basic but list the transmitting range 30 MHz or less.
The FPV equipment I'm looking at is the 900 MHz system.
Brian4301 is offline        Reply With Quote
Old 12-01-2012, 11:23 AM   #10
sl4ppy
Technician class is the basic licensing and is good to cover you for all the available FPV frequencies.
Under some circumstances, you can use 900mhz without a license (cell phones are on 900, for example), but you'll probably want to get you license so you can go further than a few hundred yards with a UHF control system.
Old 12-02-2012, 09:37 AM   #11
Brian4301
Thanks for the info. Time to hit the books.
Old 12-11-2012, 11:47 PM   #12
thielecg
Don't take this the wrong way, and I think it is great you are getting a HAM License but technically you don't need a HAM License for all frequencies in the 900Mhz, 2.4Ghz and 5.8Ghz ranges. Some frequencies are still unlicensed at 500mw transmitting power and typically that is were manufactures try to stay around but it really depends on the power of your transmitter. I have been researching FPV and have some equipment picked out but while I was in the process I considered going with 1.2/1.3 GHz but Fat shark did not have any modules for that range so I settled on 5,8 for my video tx. I would suggest 5.8Ghz if you are running 2.4GHz on your radio. a lot of people say it has no range but with the right antennas it is fine and it will out last your flight radio transmitter. 5.8 GHz also has more bandwidth and if you are looking more for a more realistic clear picture 5.8 is the best option. Personally I have decided on a Fat Shark set up because I want a simplistic set up. I didn't want to have to set up a tripod every time I fly but I still wanted the goggles for the realist aspect. Also just remembered some before saying cell phones are in the 900Mhz range and I don't think that is true, awhile back I go to play with a very expensive spectrum analyzer and my phone was at 2.10GHz, it is possible some of the older phones are in 900MHz range but again pones today need more bandwidth so they have been moving up the spectrum.
thielecg is online now        Reply With Quote
Old 12-13-2012, 11:41 AM   #13
jlharv
What is your source for saying you don't need a license? This is the tx that I have..
http://www.readymaderc.com/store/ind...roducts_id=266
It is a 600mw 5.8ghz and I would love to not have to get the license, but every thing I have read says that I must get it. So if you have something legitimate that I can print out and carry with me, then I will not have to worry about it.
I have grounded myself because I don't have the license yet, so this would be great news.
Thanks,
John
nCPX ,mCPX BL, 130x - T-Rex 500ESP DS510, mini VBar, 13T
T-Rex 600ESP 12s, scorpion 4025 630, VBar, DS650, DS610, 14T- T-Rex 700E V2 VBar
jlharv is online now        Reply With Quote
Old 12-13-2012, 12:29 PM   #14
rmalt
Thanks,
I too have been searching for these answers and I did find under the FCC part 15 rules about the 1 watt with 5.8 Ghz. 15.407 If I am reading it right. I have just decided to get it to be covered. It only took about 5 night of studying and Im going to take the test this week.
~KBDD Team Pilot~
Old 12-23-2012, 10:49 PM   #15
iceman320
can you take the test online or do you have to go somewhere to take it?
iceman320 is offline        Reply With Quote
Old 12-24-2012, 07:54 AM   #16
jlharv
You have to go somewhere.
John
Old 12-24-2012, 02:15 PM   #17
aaronredbaron
There is a lot of inaccurate info in your post here. HAM rules can be complicated, heck I've got my HAM and I could not find specific links to what I was trying to find... But it boils down to this; If there is a transmitter that can be operated legally within the US without a HAM licence it would be certified under the FCC's part 15 rules. Any product under part 15 must be certified by the FCC, and in the case of transmitters that certification includes the antenna. Being able to buy a video transmitter with a user accesible antenna connector that allows easy antenna changes will mean it does not comply with part 15. In the case of 5.8GHz you absolutely need a HAM licence, you might have seen some rules pertaining to digital 5.8GHz transmissions, but most of the unlicenced products you can by are between 1-10 mw...
In a nutshell- If it does not have a PART 15 FCC sticker on the transmitter, you need your HAM
good times and happy landings
aaronredbaron is offline        Reply With Quote
