Go Back   HeliFreak > R/C Helicopters > RC Helicopter Flight School
RC Helicopter Flight School Instructional Flying Tips, Tricks, Videos, and Q&A
Old 11-24-2012, 10:25 AM   #1
aramb
Default Need Help Improving Roll Technique
I am trying to really improve my roll technique. The rolls are pretty axial, however, I lose altitude as I exit from inverted. I am not sure what is wrong in my timing and collective management. Any suggestions would be appreciated. I have tried making it a two-point roll as well - going from upright to inverted and stopping and then continuing the roll back to upright. Everything is solid from upright to inverted with no change in altitude. It is only when I roll back to upright that I lose altitude.
Megavolt 800, Trex 800e, Goblin 770, Fusion 50
Spektrum DX18 / AMA# 959345 / IRCHA #3954
Team Lynx Team HeliDirect
aramb is offline        Reply With Quote
Old 11-25-2012, 12:09 PM   #2
gitbse
You're too quick to go back to positive pitch. Really good heli flying comes with really good left stick skills. Watch a really good pilot and a "wild" pilot and it will mostly all come down to the left stick. (mode 2)
I always tell people I teach to pay twice the attention to the collective as you do the cyclic. It will give you much better results, maneuvers will look better and fly alot better, and you will learn how to fly the helicopter, rather than it flying you around.
Skookum Support Rep
Mini Protos SK540,Rave ENV SK540, 4525 LE
Runways are for models and wings are for fairies.
gitbse is offline        Reply With Quote
Old 11-25-2012, 12:19 PM   #3
aramb
Thanks. I figured it was a collective issue, but I wasn't quite sure what was off. I have been working on making my flying more technical and precise and you are right - its all about collective management.
Old 11-26-2012, 07:19 PM   #4
gitbse
Do you have a sim? If you do, the best way to work on collective management is to fly something small, and at *slightly* higher sim speeds.
I only use Realflight, and normally I fly the Gaui X5 or even a 450, and at 110-115% sim speed. If you don't nail the collective and miss a beat here or there, the bird falls out of the sky. Then moving on to a bigger or even real life bird becomes much easier to manage.
Skookum Support Rep
Old 12-15-2012, 08:10 PM   #5
PassinThru
Yeah...it's all about collective management. Just ask Stalin...wait! Oops, wrong post!
Cereasly, gitbse is spot on!
Gaui FES X5 w/ BeastX, Trex 450 Pro, Blade mcpX BL (dry docked), Blade 130X blinged, Blade msr, JR 9503, Aerofly 5
PassinThru is offline        Reply With Quote
Old 12-15-2012, 08:24 PM   #6
cajkat1073
There are many ways to learn good collective. For me the easiest was to practice small rainbows side to side and forward and back. Using different amounts of positive until it was flat inverted before adding negative and vice versa. It really showed down my movements in the beginning. I'm sure others can give some good ways also.
Team Adventure RC
cajkat1073 is offline        Reply With Quote
