| MSH Protos MSH Protos Helicopter Support Forum |
Hello
Im new to the Protos 500 I had purchased one from a HF member a few months back and as I get closer to a total strip down and re fresh of heli hardware I wanted to know.... what lubricants are out there to oil bearings and how do you go about cleaning, and general maintenance of the heli during the season. I have a Hyperion motor and I was told by the last owner to oil every 10 to 14 flight to keep the bearings happy. But what is the best product out there to use .. Whats your maintenance schedule like for your Protos 500? Last but not least... the previous owner had the heli grounded with few wires I plan to either replace or do without. I have a carbon fiber version.. is this a wise idea to take off some of the wires and keep the tail boom grounded to the airframe/ motor mount as well as the esc? The owner said I could also use pure silicon on the belt to help keep the static charge issue to a minimum... Solex227 |
Any light oil will work on the bearings. I use 3-in-1. Use grease on the thrust bearings and shafts. I use lithium grease on all my helis, including the dampers, shafts, servo gears, and thrust bearings.
I strongly recommend you keep the grounding wires. The previous owner put them there for a reason, and the Protos is know for creating lots of static issues because of the plastic tail case.
Fly first ask questions later. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0 MSH PRÔTOS 500 FBL "Sky Whip" | ZYX v4.0 Audacity P6 FBL "Phoenix" | MSH Brain | 12s e-conversion |
Thanks Dr M
A little thread surfing here and I found a thread on the whole issue by the previous owner (awesome) and found my answer thank you . Solex227 Last edited by solex227; 11-24-2012 at 05:28 PM.. |
I would lube the motor bearings every 5 flights or so. The 3 pulley bearings and the tail shaft bearings including the slider bearing and the tail shaft itself every 10 flights. Dont forget the big swashplate bearing too, I give that one a drop every 10 flights.
Hoss X4e 6s, Gaui 550, Protos 500 12s, Losi Speed-T. Save the flybar !! |
Thanks Kavic5150 I plan to pull the heli down this weekend and do all the lube and re loctite all metal to metal screws and freshing up some of the nyloc nuts that seem a bit worn. They should be replaced being they really work in this application a dozen times before the start to wear out and a few on the heli look due.
Solex227 |
#6 | |
-DX8 -MSH MiniProtos Stretched, SK720, DS95/DS95i, Hyp 4S 25C 2500mAh -MSH Protos Stretched, Brain, Hyp DS16/BLS251, 6S 3000mAh |
#7 |
You probably already know this, but nyloc nuts and loctite do not mix.
Good old Finless.
#8 |
One more thing that came up in the main forum: never lube the one way bearing. It will cause it to slip. And be careful if you oil the radial bearings that bracket the OWB in the pinion, lest oil leaks into the OWB...
#9 | |
IMO best bet is not to lube em at all.
#10 | |||
Yes Finless Bob videos are priceless!! love watching them even on helis I dont have!! Just good Information! Quote:
Thanks again |
#11 |
You're right, solex. I do the same thing to pre-owned birds and I've been, on occasion, appalled at the quality of construction others were flying. I've found dry dampers, thrust bearings installed backwards, missing washers, notchy motor bearings, etc. Other used birds I've bought were assembled to the same quality standard I would put into the build, but there's no way to know unless you verify.
#12 | |
#13 | ||
#14 |
I bought mine used and have had to strip everything down. I have had to replace alot of parts. I think it would have been quicker and eaisier to start new. Everytime I find something I have to wait for parts. I guess from what I now now I should have stipped it down totally made a list and ordered parts and reassembled. Originally thought I would not have to but everything I have taken apart pretty well needed attention.
Hopefully the last mechanical area. The tail. Should I replace the shaft ? I thought I should. It has some scouring on it. I ordered a new one. It was assembled without two of the washers and the new one comes with te washers I need. I will replace the bearings as well. Then start programing !!
Logo 600SE,4035-450,12S,VBar. Protos450Stretch,VBar. Protos500Stretch,Helicommand HC3SX. Logo500SE,VBar. Rave Ballistic 700. |
#15 | |
You are missing one washer. http://www.msheli.com/Manual/MSH51330_Tech_Data.pdf |
#16 |
Unless you know it has been changed recently, I'd consider it cheap insurance to change the belt too. I had one fail in it's 170th flight.
#17 |
Yes, I have already put on a new belt, main gear, pinion, pinion brace, etc etc. I will replace the tail as well. Already installed new tail shaft. The only thing I haven't changed is the bearings in the rollers. Now I am wondering about them ?
#18 |
Those are the fastest spinning and smallest bearings on the Protos. You should definitely check them.
#19 |
I just turned them by hand a first and they spin OK. After fixing or replacing everything on this heli I think I should take them apart. Can you replace the bearings inside and keep the rollers ?
#20 |
yes you can, but it's not easy to get that center pin out. However, if you spun them by hand and didn't feel any notchiness, they should be good to go for another 100 flights before you need to check again. Don't forget to oil these on both sides from time to time.
