Old 11-28-2012, 10:27 PM   #21
Larry227
I'll find out this weekend for sure unless it's pouring rain which is very likely. Might be able to catch a break in between showers though.
I did get a minute tonight to check the volts/rpm screen and the rpm light does toggle when I spin the head backwards so that's a good sign.
Compass 6HV - SK540 - MKS HBL665/669
Trex 500 ESP - SK540 - 510's/BLS251
DX8 / Phoenix / Persistence
~"See the heli, fly the heli"~
Larry227 is online now        Reply With Quote
Old 11-29-2012, 09:02 AM   #22
TBur
Originally Posted by Knuckledragger View Post
My money is on the lack of blades being the issue. I couldn't get the governor to work on my 6HV with the HW ESC without blades. On my E7, it's worked sometimes and not others. Both of them have always worked correctly with the blades, however.
Same here - can't test this on the bench w/o blades
Compass 7HV SK720
Compass 6HV SK720
Compass 500 SK720
Blade MCPx V2
TBur is offline        Reply With Quote
Old 11-29-2012, 11:17 AM   #23
Jeff_Barrett
My governor issues were an incompatibility between the soft start on my ESC and the SK720 governor.
Owner - RCHeliCanada.com
Compass || Gaui || Synergy || Walkera || DJI || Skookum Robotics || TracX || Bavarian Demon || MKS Servo
Jeff_Barrett is online now        Reply With Quote
Old 11-29-2012, 12:26 PM   #24
soko
bdw: Let us know your ESC!
ONE TOOL for ALL SIZES and ALL BRANDS
"Unique features" | "Awesome setup tool" | "its simply awesome"
www.soko-heli-tools.com
soko is offline        Reply With Quote
Old 11-29-2012, 01:20 PM   #25
Jeff_Barrett
Hyperion Atlas 130A Opto
Old 12-21-2012, 10:44 PM   #26
Larry227
Just a quick update on my governor issue, or what I thought was an issue.
I still haven't maidened this thing since I put it on. Work, weather, etc has been getting in the way.
My wife gave me an early Christmas present which is a DX8 so I went through and did a fresh setup with DSMX sats. Afterwards I decided to try the governor on the bench again and again it didn't work without any blades. So what I did was change my Norm TC from 00-25-40-40-40- to 00-37-40-40-40 and I put the tail blades on. Now it works as expected even without main blades.
Not sure if it was changing the TC or adding the tail blades that did it but don't really care. Main blades are now installed and it's ready to go. Taking it to work tomorrow and going to at least do a maiden hover at lunch unless it's pouring rain. No room to cut loose and fly but plenty of room to at least hover it around and do some pitch pumps. I will also get my buddy at work to tach it for me. Will report back on how it goes.
Old 12-21-2012, 11:37 PM   #27
Slyster
Good luck on the maiden!
It's not just a hobby... it's a lifestyle!
Outrage Fusion & 550 / Goblin 700 / SK540 / Kontronik / DX8 / Quantum / RJX / 4010 Duo
Pete Team Outrage.
Slyster is online now        Reply With Quote
Old 12-22-2012, 12:29 AM   #28
Jeff_Barrett
Let us know how she goes, Larry!
Old 12-22-2012, 12:30 PM   #29
georgi UK
=] here we go Larry!!, best.
georgi UK
georgi UK is offline        Reply With Quote
Old 12-22-2012, 06:44 PM   #30
Larry227
Ok I finally got to fly it! Granted it was basically just hovering with a few flips and pitch pumps but I was in the parking lot at work and there wasn't much room.
The survey says.........I like it!
Keep in mind I haven't flown this 6HV since the end of August and since October i haven't flown anything but the sim so needless to say my heart rate was up. Sure felt good though. It was all uneventful as expected. Couple of times I had some good sustained hands off hover and then it would all of a sudden get a good drift to the right/rear. Not worried about that yet.
The governor worked great though I suppose I need to lower my gov gain. I set it to 35 last night and it worked well today in Norm and IU1 (1800 - 1900) but in IU2 (2000) it started chattering and getting a little tail shake. At first I thought it was a vibe until I remembered it could be the gov gain. So I'll lower it to like 25 the next time I get out and try it.
Tail held great. Piros were nice with nice stops and didn't get any movement during pitch pumps. Granted like I said, my heart was pumping pretty good so once I get back in the groove I'll be better equiped to notice the more subtle things. Plus this was my first flight with the new DX8 so that felt different too.
Only had two small issues. First was on spool-up I got a bad wobble until it ramped up. I know this has been a Compass issue for some but it's never happened to me. But this is the first time I've ever spooled up on concrete so that may have been it too.
Other issue was my fault. Last night when going over final checks I set my TH pitch curve to 00-50-50-50-100 so I would be sure I was at midstick when checking zero pitch. When I landed my first flight I hovered about 5ft off the ground and hit TH to do my mini-auto. Guess you can imagine how that went. I'm just glad I wasn't any lower when it went from hovering pitch to 0* pitch. Somehow I pulled off the landing without damaging anything. If you're ever bored I suggest you give it a try. It certainly makes the adrenalin flow.
So all in all I'm thrilled. Looks like all I need now is a few fine tuning flights and it will be awesome. Can't wait to be able to get it to a field where I can let it rip.
Old 12-22-2012, 06:47 PM   #31
Slyster
Pete Team Outrage.
Old 12-23-2012, 08:33 AM   #32
georgi UK
Originally Posted by Larry227 View Post
The survey says.........I like it! So all in all I'm thrilled. Looks like all I need now is a few fine tuning flights and it will be awesome. Can't wait to be able to get it to a field where I can let it rip.
=] Bravo!
georgi UK
Old 12-23-2012, 08:46 AM   #33
RodneyK
Great! Really glad you have it back in the air, Larry!
Rodney
Synergy E7, Synergy E5, Synergy N5C, Blade 130X
RodneyK is online now        Reply With Quote
Old 12-23-2012, 07:46 PM   #34
soko
Old 12-24-2012, 10:01 PM   #35
frypan
Registered Users ):>
Always good to see a happy ending.
700n
Dan }:>
frypan is online now        Reply With Quote
Old 01-07-2013, 04:10 PM   #36
frypan
I AM having the SAME issue, I take off.
and it stays at a LOW headspeed doesnt switch headpseeds at all.
Thought it was blades being on or what ever thats not the issue here.
I am having an issue please HELP!!!!!!!!!!!!!
700n
Dan }:>
