Old 11-27-2012, 03:39 AM   #1
Steemo
Default Edge 105mm vs Edge SE 105mm
Have yet to find any solid info on the SE tail blades?
I saw a blurb on them from Edge saying they are have an aerofoil designed for higher tail speed setups.
Wondering if anyone with the 700 DFC or 700E V1/2 with 1 : 4.73 tail gearing had tried both the standard and SE and can comment on if there is any benefit for using the SEs on this setup?
Here are the facts AFAIK.
Weight, length and chord all the same.
SE cost more and have less white on them so not as visible.
But if they will be more stable at higher tail speeds (and hence the tail issues we are facing) I'll be all over them like a fat kid on cake
T-Rex 700E DFC HV Brain | T-Rex 600E Pro DFC V-Bar Silverline 5.3 Pro | T-Rex 500 DFC Pro AR7200BX
JR DSX9 LE Mode 2
Steemo is offline        Reply With Quote
Old 11-27-2012, 07:24 AM   #2
raptorz499
I was also wondering the same thing, but the website gives the same description for both stlye tail blades about them being designed for higher tail speed..
raptorz499 is offline        Reply With Quote
Old 11-27-2012, 08:30 AM   #3
Steemo
Did just notice that after posting this thread
So is there anyone from Team Edge in here who can comment?
What is the difference between these blades except for paint job?
JR DSX9 LE Mode 2
Old 12-08-2012, 11:46 AM   #4
CaliRCflyer
To the top. Still waiting for someone from Edge to chime in on this.
Blade MSR, Blade 400 "Retired", T-Rex 550 FBL SK-540??, Blade 130X, Blade Nano cpx, T-Rex 700 DFC V-Bar Silverline, Warp 360 AR7200BX
CaliRCflyer is offline        Reply With Quote
Old 12-08-2012, 11:55 AM   #5
ddj74
I read it has a better airfoil design for higher tail speed applications.
T-REX 700 DFC v3, AR7200BX, ICE2 160HV,DC-UP MARK II
MKS HBL950 & MKS HBL980, GRYPHON EXTREME REGULATOR
POWERED BY THUNDER POWER LIPO'S
ddj74 is offline        Reply With Quote
Old 12-09-2012, 03:30 AM   #6
blackout19
ddj74, it says that for both the normal ones, and the SE ones.
From their website I found this quote:
"The new Edge "SE" Rotor Blades, were designed for the more advanced and aggressive 3D pilot in mind...no holds barred. Edge "SE" blades are quicker, and more suited for aggressive 3D flying styles, yet maintain their efficiency and stability in high speed flight. They're ready for anything, and they're ready for competition." - Kyle Dahl
That's about the main blades, but they wanted to sell a matching set of tail rotors I guess.
TREX 700e DFC HV-Ikon FBL | TREX 500 EFL Pro-AR7200BX | TREX 450 Pro V2/Tarot V2 DFC-Align 3GX 3.0
blackout19 is online now        Reply With Quote
Old 12-09-2012, 04:54 PM   #7
Steemo
Thanks blackout,
I had heard from a few people tar they think the differences are just cosmetic.
I'm now scratching my head how they can justify the extra cost on a different paint job. Exclusivity?
JR DSX9 LE Mode 2
Old 12-12-2012, 05:28 PM   #8
nmdesertracer
My friend had a set of SE's on his 450 and I had the regular edge blades on my 450. they were both the same except the edge white design.
Juan Martinez for President!
nmdesertracer is offline        Reply With Quote
Old 12-22-2012, 09:08 AM   #9
cwall64
Is the conclusion that they are just cosmetically different? I have the tails in SE, but didn't know which mains to order...
T-Rex 700E DFC HV (Outrage BL9180 & BL9188) V-Bar Silver & KDE700XF
T-Rex 700E DFC HV (Outrage BL9180 & BL9188) MSH Brain & KDE700XF
T-Rex 600E Pro DFC MSH Brain & KDE600XF
cwall64 is offline        Reply With Quote
