Old 11-07-2007, 02:36 AM   #21
OICU812
Default 6003D W/Vbar
Well just need a decent day and away we try the ol' Vbar out! Need to paint the canopy and fins yet but she is all ready to go, triple checked and anxious!!!
Setup as follows:
Motor: Actro 32-3 with 19tooth pinion
ESC: Jazz 55-10-32 ESC modded with Heatsink
BEC: Western Robotics 5AMP ESC modded with dual outputs, running 6V
Servos on swash: JR 8717
TR Servo: Futaba 9256 with Western Robotics stepdown
RX: Spektrum AR9000 with dual antennas
Extras: Spektrum Voltage Cap / Spektrum Antenna Fade,Hold and rx power monitor
Main Blades: Vblade 600mm TST
TR Blades: Vblade 95mm
I will report graphs in the setup and power system forum once I get solid results.
Name:	P1010528 (Large).jpg
ID:	30159   Click image for larger version
Name:	P1010532 (Large).jpg
ID:	30160   Click image for larger version
Name:	P1010534 (Large).jpg
ID:	30161   Click image for larger version
Name:	P1010551 (Large).jpg
ID:	30162   Click image for larger version
Name:	P1010530 (Large).jpg
Name:	P1010536 (Large).jpg
ID:	30164   Click image for larger version
Name:	P1010544 (Large).jpg
ID:	30165   Click image for larger version
Name:	P1010546 (Large).jpg
OICU812 is offline        Reply With Quote
Old 11-07-2007, 05:59 AM   #22
Mercuriell
Nice build and pics Shaun - Thanks - what's the big cap for just above the V-Bar amp - is that part of the V-Bar system ?
John
Mercuriell is online now        Reply With Quote
Old 11-07-2007, 06:50 AM   #23
tomas
I suppose it's the Spektrum voltage cap !?
tomas is offline        Reply With Quote
Old 11-07-2007, 11:37 AM   #24
OICU812
It is the Spektrum voltage cap. Bascially it balances spikes both high and low on the power and ensures a more consistent voltage. They work very well at under 10 bucks. Several big plane foolz run them on high demand systems as well, JR and Futaba both sell them as well, Spektrums is the cheapest of course and does same thing, cheers. :wink:
Old 11-07-2007, 01:53 PM   #25
th3tick
Two more questions on those pictures:
1) is that two of the Spektrum satellite modules, one on the left servo bulge, and one also on the right, or are these two different stages with two different locations you tried?
2) On the left side, in addition to the Spektrum satellite, what's that other clear smoke plastic doohickey above the rudder servo?
John
EDIT: Now I see the "Spektrum AR9000 with dual antennas". Sorry.
Logo 600 3D V-Bar, Jazz 55-10-32, Tango 45-7, 0.7/13T, BLS451/BLS251, JR R921, Maniac623
Logo 500 3D V-Bar, Jive 100+LV, Scorpion HK-4020-1100, 0.7/15T, S9452/S9256, AR7000, RT560
T-Rex 600 CF, Jazz 80-6-18, Neu 1515/2.5D/F/H, 11T, S9451, ds760/S9254, AR7000, Radix600
T-Rex 500 CF, stock ESC/motor/rotors, 13T, HS-5245MG, ds760/S9254, JR R921
th3tick is offline        Reply With Quote
Old 11-07-2007, 02:22 PM   #26
OICU812
John
The doohickey, lol on left side is the Antenna Frame hold, loss and voltage indicator. It is a handy little unit which gives you data right after flight to evaluate your antenna locations as well as you rx voltage etc.... It just plugs into the data port of the AR9000. I like the 9000 and the dual antennas, in comparison to the AR7000 it stepped up my range check from 36 paces to 79 so that was pretty huge imho. Maidened it today, wow is all I got to say. I have alot of tweaking to do as it was pitching up etc but still was pretty amazing on Vbar that is for sure.
Old 11-13-2007, 02:04 PM   #27
LITHIUMSTATIC
LITHIUMSTATIC is offline        Reply With Quote
Old 11-13-2007, 02:09 PM   #28
Mathias
Great!
Mathias
Mikado Logo 700 Xxtreme | JR XG8 & Spektrum DX8
Mathias is online now        Reply With Quote
Old 11-13-2007, 02:55 PM   #29
veegor
Now that makes yor LOGO LOOK MORE AWESOME !!! Except ...WHERE ARE THE GREEN STIFFIES AT JEREMY? ....: ) STILL NICE PHOTO !!
HDX 450SE Scorpion HK 2221 -8 motor, Scorpion Commander 45amp ESC ,3 HITEK 65 ,9650/ Gy401, K&B rotor blades 2200mah 20c 11.1v /2150 20c lipos, Futaba 7c fasst.. cellpro4 charger
Dragonus ll , Atom500 & Knight 600E
A turning rotor ......FEARS .....NO PAIN!!!!
veegor is offline        Reply With Quote
Old 11-13-2007, 03:38 PM   #30
Eyon
looks awesome Jeremy!
Now get her flying!
Ian Watson
Avant Aurora, YS91 SR, Hatori SB19, GY611, V-Blade 690 smooth extremes
Logo 600 3D, V-Bar, Hacker ElectricTurbine A50-12L-8P-ET, Flightpower 10s1p 5350 EVOLITE, 600mm V Extremes
Eyon is offline        Reply With Quote
Old 11-16-2007, 08:42 PM   #31
OICU812
Well finally got some color on the 6003D, all stock decals and what not. :wink:
Name:	P1010580 (Large).jpg
ID:	30894   Click image for larger version
Name:	P1010579 (Large).jpg
ID:	30895   Click image for larger version
Name:	P1010575 (Large).jpg
Old 11-16-2007, 08:51 PM   #32
LITHIUMSTATIC
Nice........
Old 11-16-2007, 11:55 PM   #33
BruceW
I better start thinking of a paint scheme for mine since I don't want plain white and logos. Are you guys spraying a finishing gloss coat of some sort over the paint?
Logo 500 3D /Scorpion HK4020-1100KV (16T)/Jazz80/BLS451/Spartan DS760/BLS251/RT 560mm/AR9000
TRex 450SE
/Scorpion HK-2221-8 (13T)/ AlignESC35(X)/ HS65MG/Spartan DS760/S9650/AR6100
Spektrum DX7
BruceW is offline        Reply With Quote
Old 11-17-2007, 03:28 AM   #34
Ticidytoc
Only the orange is reflecting off the snow, are you sure that will be bright enough?
A Helicopter, Brushless Motor, Esc, Battery, Servos, RX
Ticidytoc is offline        Reply With Quote
Old 11-17-2007, 03:52 AM   #35
OICU812
LOL Smartie pants, yea it should be good. -6 was at tad cold today to fly though, then came in freezing rain so was time to pack it in for the day.
Old 11-17-2007, 10:10 AM   #36
Hulley
Damn that looks Kick A$$!:thumbsup2:
Hulley is offline        Reply With Quote
Old 11-17-2007, 11:56 AM   #37
LITHIUMSTATIC
I had mine airbrushed by a good friend that does it for a living. He put much clear coat on mine.
Old 11-17-2007, 12:12 PM   #38
BruceW
Do you think it adds extra strength compared to an unfinished canopy?
TRex 450SE
Spektrum DX7
Old 11-17-2007, 12:19 PM   #39
Foamy Love
Looks good Shawn. Simple always looks better to me.
Foamy Love is offline        Reply With Quote
Old 11-17-2007, 12:22 PM   #40
BruceW
Yep Shawn, those will be good colors against that snow you'll be flying in. Nice job.
TRex 450SE
Spektrum DX7
