Old 11-27-2012, 04:02 PM   #1
joallen001
Default Sbus to Sk540 Power Connection
I am putting a sbus rx on a nitro heli. If I am reading the manual right I only need a jumper wire from rx to IO-B port?
This gives me power to the receiver?
Does the jumper wire keep the signal, negative, and positive input?
Does this mean only one lead plugs in to the receiver from sk540?
I will be powering everything with a 2s Life. As far as that goes I just use a servo connector and remove the signal wire, plug into an open port on the sk540. Then on the other end put my power poles for plugging in the battery (rx pack)?
Sorry for so many ?'s I tried to space it all out so it could be quoted and answered.
joallen001 is offline        Reply With Quote
Old 11-27-2012, 06:05 PM   #2
desertstalker
The single wire supplies power to the RX, it also carries the signal.
So yes, 1 cable is all that is needed.
-DX8
desertstalker is online now        Reply With Quote
Old 11-28-2012, 06:18 PM   #3
joallen001
Is that the proper way to get power to everything?
Old 11-28-2012, 09:59 PM   #4
desertstalker
Yes, power the SK, from the ESC or BEC, then let the ESC power the RX.
-DX8
Old 11-29-2012, 01:39 PM   #5
joallen001
I am running nitro so I dont have a ESC. Do I need to get a BEC? Or can I run the 2sLife straight into the SK?
Old 11-29-2012, 04:40 PM   #6
desertstalker
Assuming all your servos are OK with straight LiFe (6V rating or better) then there is no problem there. The SK is fine with any voltage up to (and exceeding) 2S LiPo.
-DX8
Old 12-18-2012, 09:34 PM   #7
joallen001
Found out the answer in the sk540 manual. If I am using a servo extension plugged into the life pack to power the sk540. Is there any concern with the gauge of the servo extension. Considering that wire is sending the power throughout all the servos.
Old 12-19-2012, 10:53 AM   #8
georgi UK
=] splice in 2 extension plugs and fit to open 540 ports, not ex-led tho'!
georgi UK
georgi UK is offline        Reply With Quote
