Old 11-27-2012, 05:46 PM   #1
michael88997
Default It's official!!!!
Got my logo 500 super combo today and everything's else I need for it to fly... Can't start the build til Saturday cause I got a big test Friday... Any tips or anything I need to know on building my first logo?
michael88997 is offline        Reply With Quote
Old 11-27-2012, 05:52 PM   #2
gravydrive
Congrats! I'm sure you'll love it, read through this thread before starting the build:
http://helifreak.com/showthread.php?t=144349
Good luck with your test!
gravydrive is offline        Reply With Quote
Old 11-27-2012, 05:57 PM   #3
michael88997
Everything looks sooo nice, can't wait to build it... Thanks for the thread...
Thanks, if I pass I get a raise, if I fail I loose my job, no pressure lol
Old 11-27-2012, 06:27 PM   #4
Duramax11
Congratulations! You will love it.
Logo 500 & mCPx V2
Vbar 5.3 Pro - Scorpion - Kontronik - Edge - Microheli
Powerlab 8 V2 - DX8
Duramax11 is offline        Reply With Quote
Old 11-27-2012, 07:01 PM   #5
sgrim80
The only thing you need to know is that is a very simple and quick building heli that flies great and requires only a tiny bit of maintenance. You will find yourself flying it more and more and wondering why you have extra time on your hands LOL! Enjoy it...I'm sure you will!
#1 - Logo 600SX-THOR 10s 4400, YGE 90HV, Scorpion 4035-560kv on 12T pinion, BLS451/251
#2 - Logo 700-THOR 12s 5000, YGE 160HV VBar Gov, Scorp. 4525-520kv, BLS451/256
sgrim80 is offline        Reply With Quote
Old 11-27-2012, 07:54 PM   #6
michael88997
thanks... I have my major test friday, then minor one next friday(securities licenses), then a week off so it would get broken in well
anybody need a new 4020 or hacker esc.. brand new
Old 11-27-2012, 08:45 PM   #7
3D Dave
It's a little old but I'd still recommend watching the Logo 500 build video by Finless. It will give you a little preview of what to expect.
That, and read the thread that Mike linked to. Have fun and take your time building.
Once you're done, you'll be amazed at 3 things.
-The simplicity of the build
-The quietness of the Logo
-The flight characteristics of the Logo
People rave about the V-Bar on the Logo. I'm here to tell you that while V-Bar is superb, my Logo 500 flew awesome before it had V-Bar. Add V-bar, and there's nothing quite like it.
Logo 690SE V-Bar /// Logo 560 V-Bar /// E325 mini-Titan /// Blade 130X /// Blade mCP X /// Blade nano
"Ginger" 11/10/02--7/6/12
3D Dave is offline        Reply With Quote
Old 11-30-2012, 09:50 PM   #8
michael88997
Got the frame almost complete, I noticed finless said he used shoe glue on the main shaft bearings, is that what most use? The manual doesn't say anything about it
Old 12-01-2012, 05:18 AM   #9
maarset
Not really needed
Logo 500 VBAR GOV/YGE
MSH mini-p VBAR
mcpX V2
mikeaarset.zxq.net
maarset is offline        Reply With Quote
Old 12-01-2012, 07:42 AM   #10
michael88997
So don't glue them in at all?
Old 12-01-2012, 08:35 AM   #11
dahld
Correct. When the main shaft is pulled tight and the main shaft collar is tightened, they are mechanically seated (squeezed together) in the frames, and cannot move.
We have thousands and thousands of flights on various Logo 500/600 helis, and gluing the main shaft bearings in the frames is definitely not needed.
(-: Dave
Kyle Dahl
Sponsored by:
Mikado, JR, Voltz/Thor, Scorpion, Edge Blades.
dahld is offline        Reply With Quote
Old 12-01-2012, 09:41 AM   #12
michael88997
Awesome sounds good, hope to get it mostly build today... Gotta celebrate my test
Old 12-01-2012, 12:16 PM   #13
michael88997
Can anyone explain the anti static kit? The pic looks like its on the cf tail
Old 12-01-2012, 05:48 PM   #14
maarset
Goes from pulley to boom. Then from boom to motor mount. If you search this forum you can find some good pics.
MSH mini-p VBAR
mcpX V2
mikeaarset.zxq.net
Old 12-02-2012, 05:42 PM   #15
michael88997
Well the frame is built, all that's needed is mount servos and electronics... Should maiden next weekend, that was the nicest build I have ever done, zero slop in everything
Old 12-02-2012, 07:54 PM   #16
el guapo
BTW it is easier to mount the tail servo and the elevator servo with the frame split.
Greg
Lynx Team Pilot
Heli: TDR; Logo 600,500; Trex700E,500,450,250
Flight video: http://www.youtube.com/watch?v=GUkswcoyGEk&feature=plcp
el guapo is offline        Reply With Quote
Old 12-02-2012, 10:23 PM   #17
michael88997
Too late for that lol, but I got small hands so I can reach in there
Old 12-08-2012, 09:03 AM   #18
michael88997
Anybody have any tips on the pinion. I had it loose and was spinning the main gear to get it to align but it was still moving a little on the shaft, should I just eye ball the middle line?
Old 12-08-2012, 05:05 PM   #19
michael88997
And by moving I mean up and down, so it doesn't just zero in on a meshing
Old 12-08-2012, 08:46 PM   #20
el guapo
1. the Main hub will have play up and down on the main shaft. I center the hub and then eyeball the pinion to line up with the main gear.
2. I recommended Molykote EM-30L for the gear. (or thundertiger plastic gear grease)
3. the logo pinion should have less lash then normal. went i set the pinion they just touch.
Greg
Lynx Team Pilot
