Old 12-13-2012, 12:44 AM   #41
3D Dave
Tape will work for a short time but I highly recommend you make that connection more permanent.
Get a very small screw and (after drilling an even smaller pilot hole) mount it at the bottom of the boom about 2" back from the frame. Crimp the wire in a small electrical terminal and screw it in there.
Use a DVM to check for continuity.
Hope the maiden went well.
Reserved for Logo 700V2 / Logo 600SE V-Bar NEO / Logo 500 V-Bar / Blade 130X / mCPxBL / nano CPS / VBar Control
"Ginger" 11/10/02--7/6/12
3D Dave is offline        Reply With Quote
Old 12-14-2012, 10:15 PM   #42
michael88997
well the maiden was delayed until sunday because i work tomorrow and its been raining :/
question before i fly, i plan to use fixed endpoints for now until i purchase pro version if i do.. i have the 16t pinion installed with the 1100kv motor, the headspeed calc says at 100% ill be getting over 2600 rpm, but the castle gov software says at 2300 ill be using 98% power...
what is a good % to run around the 2200-2300 rpm and not overspeed the head
michael88997 is offline        Reply With Quote
Old 12-14-2012, 10:45 PM   #43
el guapo
just run the castle gov. its not bad with version 4. but ignore their max recommended setting warnings, its nonsense. you could set it to 2600 and it will just act as a limit. BLINK182 said he ran his 500 at 2600rpm.
I'd run about 12 gain. try 2350rpm. then check the castle log to see if it flat-lines at 100% power. if you flat line at 100% then you were probably bogging. if it just pin pricks 100% every once in a while, I'd call that really good. castle gov works better the closer you get to 100%. it will hold like crap if you try a 1800rpm setting. the jives and the Vbar gov work much better for lower RPMs.
i use Mr mel's calculator I run that program with external governor(Vbar,SK etc). and use the performance (-) setting.
Greg
MSH USA Heli Flight Team
Mikado V Team
Lynx
el guapo is offline        Reply With Quote
Old 12-14-2012, 10:50 PM   #44
michael88997
ah ok so even if it gives you the warning it will still work? ive always set my helis up for 100% flat line but being plastic i dont want to overspeed the head too much
Old 12-14-2012, 11:07 PM   #45
el guapo
I ignore the warning. the closer you get to 100%, the smoother the head-speed will be for sport flying. I'm personally not worried about the head, what I recall is the blade bolts will bend and then tracking goes to hell....the tail grips are a different story. quick UK set or a SX tail hub upgrade are worth looking into.
Greg
Mikado V Team
Lynx
Old 12-16-2012, 11:39 AM   #46
michael88997
Ok guys just maidened and omg I love this thing... So quite, smooth, nimble and has soo much power...
I had 2 problems, first the Velcro I used to hold the front of the battery is too strong and it was a pita to get the packs out,
2 more serious my motor was pretty hot, wasn't on fire hot but it was the temp it should be after a 5 min hard 3d flight, not 4 min hover... I did have my belt in hopes it would break in but I loosened it some and didn't feel any change, could it be the gear mesh too tight? Or the gear breaking in
Old 12-16-2012, 12:09 PM   #47
michael88997
just pulled the castle graph, the max amps was 26 and it was around 24 while hovering... i was also running lower rpm cause i hadnt setup gov mode so it was just fixed endpoints on a normal curve
Old 12-16-2012, 01:32 PM   #48
el guapo
what motor? did you buy a 4025?
motor timing? 5
PWM? 8Khz
my castle dat file is attached.
Greg
Mikado V Team
Lynx
Old 12-16-2012, 01:44 PM   #49
michael88997
yes its a hk III 4025 1100
i left everything stock on the setup
timing was 5 and pwm was 12
Old 12-16-2012, 01:49 PM   #50
michael88997
i changed it down to 8... would that make much of a difference?
Old 12-16-2012, 02:05 PM   #51
el guapo
what blades... 550s?
Greg
Mikado V Team
Lynx
Old 12-16-2012, 02:10 PM   #52
michael88997
523... it was probably only running around 70% throttle
Old 12-16-2012, 02:35 PM   #53
el guapo
if you didn't calibrate your throttle, then you really don't know what you did.
if you check your castle log it has a field called Power out. it will be in percent and it basically corresponds to throttle. was it 70% or was 100%?
in regards to the PWM... 8 is what you need to run. I think it will effect motor temp. my 4020 doesn't run hot. but my 4035 on my TDR could cook and egg.
Greg
Mikado V Team
Lynx
Old 12-16-2012, 02:47 PM   #54
michael88997
average is 42 max is 76 on power out... think maybe it was running too low rpm
Old 12-16-2012, 06:34 PM   #55
michael88997
Tomorrow I will try and raise the TC up so the motor is spinning faster and see how it does then
Old 12-17-2012, 11:33 AM   #56
michael88997
Quick question, I'm buying some lube for the Heli.. The silicone spray has petroleum distillate, is that ok? They also have a ptfe(Teflon) spray
Old 12-17-2012, 05:15 PM   #57
michael88997
ok 2 more flights... i changed a few things and the motor is now running at a much nicer temp...
i updated to 4.02 and ran gov mode at 2k rpm to try it out.... my tach said 2030 so it was pretty close.. i think its about time to throw the canopy on, bring it up to 2300 and let her rip
Old 12-17-2012, 05:24 PM   #58
maarset
NICE!!
Good to hear!!! Yah 2300 is balistic!
maarset is offline        Reply With Quote
Old 12-17-2012, 05:29 PM   #59
michael88997
Ya I'm still old fashion and like to break in my packs a little, but after 2 cycles I'm ready to see what she can do
Old 12-17-2012, 11:02 PM   #60
michael88997
In case anyone is interested... I decided to sell the gens ace and get some pulse 45c packs. Here is the size difference, according to my scale they were within 5 grams of each other
