Old 01-26-2013, 02:08 PM   #101
michael88997
made a video
michael88997 is offline        Reply With Quote
Old 01-26-2013, 03:37 PM   #102
el guapo
Originally Posted by michael88997 View Post
Well I had max Headspeed set to 2300, I had my normal throttle curve set to 0 at low then 60% flat line, when I brought the stick up to Max in normal mode it is 60% and the program is showing requested that low, the actual seems right but idk why the program is showing requested only in the 400's... How long does the soft start take to disengage?
"requested" is pretty much straight from your radio. its just telling you that at your current throttle position you have requested 447RPM.
your issue is between your radio and the vbar. you probbaly have to increase the end point in you radio and set you throttle curve to 100%.
test to make sure you get 100% at the arrow I drew on the attached photo.
Greg
Lynx Team Pilot
Heli: TDR; Logo 600,500; Trex700E,500,450,250
Flight video: http://www.youtube.com/watch?v=GUkswcoyGEk&feature=plcp
el guapo is offline        Reply With Quote
Old 01-26-2013, 03:48 PM   #103
michael88997
Ya it's adjusted... And it was a flat line 60%... It seems to work fine with just a nicd pack... Ill try idle up and see what it does
Old 01-26-2013, 04:29 PM   #104
michael88997
ok got it working... i guess 60% is too low to test but once i jumped it to 100% the requested moved up... hopefully can try it out tomorrow. thanks
Old 01-26-2013, 11:28 PM   #105
el guapo
make sure you lower the gain.
Greg
Lynx Team Pilot
Old 01-26-2013, 11:39 PM   #106
michael88997
ya i set it to 25 per mrmel's video
Old 01-26-2013, 11:43 PM   #107
el guapo
I think I had to go to 20. bring a lap top.
I wasted a few days trying to dial in pre comp to the tail and the gov. lowering the gain worked.
Greg
Lynx Team Pilot
Old 02-02-2013, 03:10 PM   #108
michael88997
So I tried the gov out today and my hs was pretty low, I had to raise my throttle end point to 125% to get my hs around 2300 rpm, I did calibrate my throttle and set the gear ratio correct... What else could It be?
Old 02-02-2013, 08:52 PM   #109
maarset
Default It's official!!!!
Which gov?
Logo 500 VBAR GOV/YGE
MSH mini-p VBAR
mcpX V2
mikeaarset.zxq.net
maarset is offline        Reply With Quote
Old 02-03-2013, 12:17 AM   #110
michael88997
Vbar
Old 02-03-2013, 09:39 AM   #111
maarset
What did you set your max HS to be in gov 2 tab?
MSH mini-p VBAR
mcpX V2
mikeaarset.zxq.net
Old 02-03-2013, 10:03 AM   #112
michael88997
i set max at 2300 rpm... my idle up was 100% flat curve... i raised my endpoints in my tx to 125% and it was at the 2300rpm, but i had already programmed it at 100% in the vbar which my endpoint was around 98%
