Old 11-28-2012, 09:22 AM   #1
torch8
Default 3GX MR
3GX MR is only compatible fith Futuba? I don't want to build and the Trex 450 Plus DFC looks good, but I would like to bind it to my specktrum dx6i. If this is not possilbe I will have change out to Beastx or other FBL system.
Walkera V4501
Gaui 200 V2 MicroBeastx
Walkera M120D01
torch8 is offline        Reply With Quote
Old 11-29-2012, 07:26 PM   #2
bad007
3gx and a separate RX, BX with spek sat adapter and sat. or a AR7200BX
Align 450Pro 3GX, Align 500 3G
Align 550 3g, Velocity 50 Vbar
bad007 is offline        Reply With Quote
Old 12-12-2012, 10:15 PM   #3
dwdw910
The 3X MR stands for micro receiver. It is an all in one 3GX compact with SFHSS Futaba receiver inside. The unit is not updateable because it has no port on it though. Align has rebranded the Futaba T6J as their own Align T6.
dwdw910 is online now        Reply With Quote
Old 12-12-2012, 10:17 PM   #4
dwdw910
I would encourage you to look at the transfer rates of the T6J versus your transmitter. The Futaba transfers commands way faster... Smokes it.
Old 12-12-2012, 10:29 PM   #5
dwdw910
I had to look it up real quick... Its 6.8ms... There isnt another 6 channel TX that fast. Plus by the time you change out FBL systems.. you really have built a helicopter.. in that respect, you should get the Pro and build it to have the extra insane performance capability. ;-)
