Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Warp 360
Warp 360 Compass Warp 360 Model Helicopter Discussion
Old 12-01-2012, 05:58 PM   #21
Ah Clem
OUTSTANDING SCOTT!
GREAT THREAD!
(and yes, I am shouting!).
KBDD-Team Pilot
Team Compass / ProStar Hobby
Gens Ace Field Representative
Warp 360, 7HV,Knight Pro,Knight 3D, Atom 500, Odin II, 6HV, 3D Plus, Knight 50
Old 12-01-2012, 07:01 PM   #22
integy2
Did u get one already Ah Clem?
integy2 is offline        Reply With Quote
Old 12-01-2012, 07:16 PM   #23
keither1984
Good build thread.
I have one question with your build, you said that you were going to put threadlock in the nut and the threaded portion into the aluminum grip link is that necesarry I did not see anything in the manual about and was wondering I think im gonna do mine that way too definitly don't want that coming off in flight
-Henseleit TDR, CC ice 120, Torq9188/9180, 750mx,Thor lipos, Ikon fbl, Gryphon Quasar bec
-mini protos hobbywing 40 esc, msh1300kv, mks 92a cyclic, mks 8910a tail, stretched edge 353mm main blades, brain flb, 1300mah 6s lipos how high does it go
keither1984 is offline        Reply With Quote
Old 12-01-2012, 07:41 PM   #24
dunkonu23
Thanks, guys. I wish I could do more tonight, but it's not happening. I hope the antibiotics I got yesterday kick in soon.
Richard... you da man! Shout away! I'm honored, sincerely.
Scott
Spartan Vortex VX1 Inside
Team A Main Hobbies/ProTek Field Rep.
dunkonu23 is online now        Reply With Quote
Old 12-01-2012, 07:45 PM   #25
dunkonu23
Originally Posted by keither1984 View Post
Good build thread.
Yes. I did put thread locker in on the bolt then threaded the nut up to the thread locker, and also in the aluminum portion of the swash driver for the bolt. Without a locking mechanism it seemed too much of a risk for me. The manual said nothing except the standard "metal to metal" disclaimer, so it's metal to metal and it gets thread locker applied.
One thing thread locker might prohibit is the quasi turnbuckle action of this kind of link; but I thought it was worth it.
Scott
Old 12-01-2012, 07:52 PM   #26
1BADAIR
nice build Scott
TREX700LE-beastx,TREX 600LE-vbar,COMPASS 6HV-beastx,
1BADAIR is offline        Reply With Quote
Old 12-01-2012, 08:26 PM   #27
dunkonu23
Originally Posted by 1BADAIR View Post
nice build Scott
Larry! Thanks! Long time, bro! I haven't seen you since July. What have you been up to?
Scott
Old 12-01-2012, 09:29 PM   #28
1BADAIR
not much at all
Old 12-01-2012, 09:53 PM   #29
dunkonu23
Don't sound too enthusiastic, Larry!
Scott
Old 12-01-2012, 11:23 PM   #30
eagleridge
Great build thread as usual Scott!!
Kevin Williams
AmainHobbies/ProTek Field Rep
Rush700: Scorpion 4035-500kv, Vbar Silverline, CC160HV
eagleridge is online now        Reply With Quote
Old 12-02-2012, 12:17 AM   #31
Jeff_Barrett
Good job, Scott.
I took lots of photos of my build before forgetting in the excitement of my build. LOL!
Owner - RCHeliCanada.com
Compass || Gaui || Synergy || Walkera || DJI || Skookum Robotics || TracX || Bavarian Demon || MKS Servo
Jeff_Barrett is online now        Reply With Quote
Old 12-02-2012, 02:23 AM   #32
dunkonu23
Thanks, Jeff! I know what you mean about the excitement. I have to reign myself in during the build.
Scott
Old 12-02-2012, 12:49 PM   #33
dunkonu23
Default Basic tail and boom assembly
Still not feeling that well, but a promise is a promise... Here we go with the basic tail and boom assembly!
Bag 7,8,9... well, the numbers skip around a little, but they relate to the steps in the manual--there are cases where parts in a prior assembly are used in the current assembly--so the number skips. Don't worry! You're likely not missing a bag of parts! You gotta love that the packaging factories weigh each bag!
Contents of bag 7,8,9. Note that you have eight screws, four smaller and four larger. Also, note the spring pin slightly under the belt bag.
Parts for assembling the tail output shaft. Note that the spring pin is missing from this step. It's missing because I was trying to figure out how to get the pin in without a small vice.
The first step in the process is to line up the hole in the main shaft with the hole in the pulley. The cleaner you do this step, the easier the spring pin can be inserted. I ended up using a "C" clamp to press in the spring pin. My suggestions? Two, really. Buy a small bench vice. Second, Compass might want to consider assembling this part.
After I got the spring pin in the pulley and output shaft, I installed the other half of the pulley. I waited to do it at this point because the output shaft can be used as a guild. I slid the box end side of a wrench over the output shaft then lightly tapped on the wrench so the pulley halves would merge.
Here's the proof: The assembled tail output shaft.
Here are the parts to assemble one side of the tail block. When you're doing this, pay close attention to the orientation of the bearing in the carbon fiber end plate--the flange must face the pulley on the tail output shaft.
Install the screws carefully. Make sure you get even tension on them! I tightened them until they were snug then went 1/4 turn past snug.
Slide the tail output shaft into the flange bearing on the end plate.
Next, install the other plate.
Even tightening here, too. The reason is this: Carbon fiber, even a small piece like this may flex when the screws are not evenly tightened. Flexing may cause the bearings to wear prematurely or even cause vibrations that are a pain in the butt to track down!
To install the belt, I first stretched it out, then applied tape to one end as shown above.
Next, I simply just pushed the belt through the boom! Simple. If you don't tape or somehow squeeze the belt like this, you may spend a frustrating time getting the belt through the boom.
Remove the tape from the belt then just slide the tail case assembly inside the belt. Really a good design here. It's simple. I can see belt replacements not taking too long at the field!
Next we attach the tail case assembly to the boom. First, you thread the screws through the fin and the plastic support.
Screws are through. Be a little more careful with the blue thread locker than I was. In the manual it says to put thread locker on the curved portion of the machined tail case. I don't know why, but I did it anyway.
Tighten the screws evenly here, too. The screws go through the boom and into the tail case assembly.
As we did with the tail, thread the screws through the plastic tail control arm support. Don't forget thread locker!
Tighten the screws evenly here, as well. The manual doesn't state orientation of this piece, but if you look very closely at the drawing, it shows the curved part facing to the top.
Here is the partial boom/tail assembly, completed. Next up, we'll do more with the tail.
Scott
Name:	Bag 7,8,9.jpg
ID:	370499   Click image for larger version
Name:	Bag 7,8,9 Contents.jpg
ID:	370500   Click image for larger version
Name:	Tail output shaft and pulley parts.jpg
ID:	370501   Click image for larger version
Name:	Line up the hole in the output shaft with the hole in the tail pulley.jpg
ID:	370502   Click image for larger version
Name:	pushing the back half of the pulley.jpg
Name:	Assembled tail output shaft with pulley.jpg
ID:	370505   Click image for larger version
Name:	Tail case half parts.jpg
ID:	370506   Click image for larger version
Name:	Installing screws.jpg
ID:	370507   Click image for larger version
Name:	Slide in the tail output shaft assembly.jpg
ID:	370508   Click image for larger version
Name:	Attach the other end plate.jpg
Name:	Attaching the other end plate 2.jpg
ID:	370510   Click image for larger version
Name:	Taping the belt together.jpg
ID:	370511   Click image for larger version
Name:	Belt in boom.jpg
ID:	370512   Click image for larger version
Name:	Belt over pulley.jpg
ID:	370513   Click image for larger version
Name:	Thread screws throught the tail fin and plastic support.jpg
Name:	Screws threaded through the fin and plastic support.jpg
ID:	370515   Click image for larger version
Name:	fin on boom.jpg
ID:	370516   Click image for larger version
Name:	Thread screws throught the tail mechanics support.jpg
ID:	370517   Click image for larger version
Name:	Tighten screws evenly.jpg
ID:	370522   Click image for larger version
Name:	Finished basic boom assembly.jpg
Old 12-02-2012, 01:05 PM   #34
Luigi_tuga
Thanks a lot for the effort!
Nice tips on general building also, VERY pedagogical thread!
Warp 360 , Tarot 480
T500Fbl AP
MCPX bl PZ StrykerQ DX8
Luigi_tuga is offline        Reply With Quote
Old 12-02-2012, 03:05 PM   #35
dunkonu23
Default Tail assembly part 1
In this post we'll do the first part of the tail assembly. I'm breaking this up into two parts because the tail pitch slider assembly has two links and pins that need to be properly fit so it's going to take more time to make sure they're properly installed.
So, here we go with part 1!
Bag 10.
Bag 10 contains the tail pitch control lever parts.
The first thing I did was resize the link. Note in the picture, the link is not yet on the ball link sizing too. I used a standard JR ball link sizer.
Now, this picture may be a bit misleading, but it does show the installation order of the ball. The easiest thing to do is to temporarily install the ball on the lever-do not use the top washer-- then press the link on to the ball. Next, remove the screw, slide washer onto the screw. Then slide on the ball, apply thread locker to the threaded hole on the lever then install the ball/link assembly.
When you're done, it looks like this. Keep the small washer and bolt for later.
Bag 11. Ha! No weight!!!
Bag 11 contains the tail grips and two balls with screws.
Since this is a high stress part of the helicopter, I first threaded the hole in the link, then removed the screw.
I then filled the threaded hole with CA that I first applied to a toothpick.
Finally, I reinstalled the ball. Don't over tighten! Remember, the link is plastic!
Balls are installed.. sounds bad doesn't it?
Bag 12/13 Contains a lot of parts for the tail assembly.
I did a double take on the blades. They have a design on them... both blades have the same design. I wonder what it means or if it is a logo of some kind?
Here is the assembly order of the grips and tail hub. This is pretty critical to get right. When you're done, the grips should turn freely on the hub.
The first thing to do is to install the bearings into the grips. Each grip has two radial bearings. I pressed them in with the shoulder of a Thorpe hex driver.
The bearings slid in with only a small amount of force.
Same deal with the outer radial bearing.
Just apply constant, steady pressure and the bearing will slide right in. Stop pressing when you feel the bearing has found the lip inside the grip.
Outer radial bearing installed.
I applied blue thread locker to a tooth pick then used the toothpick to apply the thread locker to the threads inside the shaft portion of the tail hub.
Slide the grip over the hub and tighten the screw until you feel some resistance. Do this with both tail grips.
For final tightening, insert a hex driver or screw driver through the center hole in the hub, then tighten each grip screw evenly. After that, check to make sure there is no binding on the grips by turning them. If you find binding or a notchy feel you may not have pressed the grip bearings in fully.
The completed tail hub.
The manual wants builders to install the tail blades at this point. This picture shows what goes where. I'm skipping this step because I think having the blades on and flopping around will be a distraction when fitting the links. I'll install the blades later.
That's it for these steps. Next up is the tail pitch slider!
Scott
ID:	370546   Click image for larger version
Name:	Bag 10 contents - Pitch arm parts.jpg
ID:	370547   Click image for larger version
ID:	370548   Click image for larger version
Name:	Attaching the ball.jpg
ID:	370549   Click image for larger version
Name:	Link and ball installed.jpg
Name:	Bag 11 No weight!.jpg
ID:	370552   Click image for larger version
Name:	Bag 11 contents.jpg
ID:	370553   Click image for larger version
Name:	First start the threads.jpg
ID:	370554   Click image for larger version
Name:	Put CA on a tooth pick and fill the threaded hole.jpg
ID:	370555   Click image for larger version
Name:	Reinstall the ball.jpg
Name:	Links attached.jpg
ID:	370557   Click image for larger version
Name:	Bag 12 13.jpg
ID:	370558   Click image for larger version
Name:	Interesting design on the tail blades.jpg
ID:	370559   Click image for larger version
Name:	Order of assembly.jpg
ID:	370560   Click image for larger version
Name:	Pressing in rear bearing.jpg
Name:	Rear bearing installed.jpg
ID:	370562   Click image for larger version
Name:	Preparing to press in outer bearing.jpg
ID:	370564   Click image for larger version
Name:	Bearing partially installed.jpg
ID:	370565   Click image for larger version
Name:	Outer bearing installed.jpg
ID:	370566   Click image for larger version
Name:	Apply thread locker to inside of hub ends.jpg
Name:	Installing grip on hub.jpg
ID:	370568   Click image for larger version
Name:	Tightening grips.jpg
ID:	370569   Click image for larger version
Name:	Completed grip and hub assembly.jpg
ID:	370570   Click image for larger version
Name:	Assembly order for blade installation.jpg
Old 12-02-2012, 03:07 PM   #36
dunkonu23
You're welcome, Luigi! I haven't seen that word used in ages! Thank you so much!
Scott
Old 12-02-2012, 04:30 PM   #37
Luigi_tuga
Scott
I used a old-fashion dictionary i had laying around
T500Fbl AP
Old 12-02-2012, 06:12 PM   #38
Rob43
It's like "Finless Scott". Dude, you have an excellent style of presenting the process! I love it!
= R
b43 =
Team Compass Support
Rob43 is offline        Reply With Quote
Old 12-02-2012, 08:29 PM   #39
dunkonu23
LOL! Old dictionaries are good dictionaries! I have a couple of old ones laying around, too.
Scott
Old 12-02-2012, 08:32 PM   #40
dunkonu23
Thank you, bro! Thank you for all the tips you sent me. I truly appreciate it. There's more to come, but not tonight... we'll do part two of the tail build then keep moving ahead.
Scott
