Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Warp 360
Warp 360 Compass Warp 360 Model Helicopter Discussion
Old 12-04-2012, 12:07 PM   #61
dunkonu23
Originally Posted by Bob O View Post
Scott,
The pins in the tail pitch arms aren't roll pins per se. They will be a lot easier to work with. The roll pin in my kit was a super tight fit to the hole. Pliers wouldn't budge it, and besides I didn't want to mess up the pulley. And I don't have a vice. So I rigged up something and had to hit it with a full sized hammer pretty hard, nearly as hard a freakin' nail. After it was flush with the pulley I lined up a drift punch and had my father in-law whack it to get it evenly recessed with the other side. It was the first time in all my heli builds where I needed help from another person.
If I recall, the 6HV used a roll pin to hold the tail pulley. It was nowhere near the hassle as this one. In either case, it's done and I can proceed with the build.
Okay.. Let's just call them PITA pins. The tail pulley thing I called a spring pin. It sounds like a lot of folks are playing whack a hole!
The pins on mine were kind of easy once I figured out how to hold the pin in a pair of pliers then tap the pliers to just get the pin started. Holding the PITA pins with fingers was hopeless for me.
Scott
Team Manager
Spartan Vortex Inside, Cyclone Blades, Team Scorpion
OMGRCUSA Servos ):>
"I don't believe that we're in this alone. I believe we're along for the ride."
dunkonu23 is offline        Reply With Quote
Old 12-04-2012, 12:09 PM   #62
dunkonu23
I suppose not being able to imagine not having a bench vice or Arbor press is akin to me not being able to imagine not having a Mesa Boogie Mk IV or my JP6 BFR...
Scott
Team Manager
OMGRCUSA Servos ):>
Old 12-04-2012, 12:15 PM   #63
Luigi_tuga
Scott
Considering the prices, it's much worse not to have a simple vise
Warp 360 , Tarot Sport 360
T500 AP
PZ StrykerQ DX8
Luigi_tuga is online now        Reply With Quote
Old 12-04-2012, 02:25 PM   #64
OICU812
I have a vice, punches etc... Points being missed here, its a stupid way of doing it period. This is 2012, use damn setscrews and throw away the crap pins, that's my opinion, my tr hub Definetely took a beating and will work but it is not pretty at all lol.
Mikado Heli
Scorpion Motors
Western Robotics RC,
Youth Generation Electronics
OICU812 is offline        Reply With Quote
Old 12-04-2012, 04:11 PM   #65
BaconRaygun
I concur; my hub is now a little warped, though cosmetically not mangled since my vice has smooth clamping surfaces.
I like the set-screw idea. Indent the shaft in the same way as is done on the end where the tail-blade hub is attached (nice touch BTW, much better than the dreaded flat spot) and maybe even use a Delrin or Aluminum pulley.
I honestly thought I would never again see another rolled pin since I quit RC cars.
EDIT: BTW, Scott, lovely thread you got here man.
~SAB~ Goblin 700 ~Compass~ Warp 360 ~Blade~ mCP X (BL)
AMA# 977012
**Team BOCA Bearings**
BaconRaygun is offline        Reply With Quote
Old 12-04-2012, 04:37 PM   #66
Dave Ketelhut
the tail shafts and pulleys will be assembled at the factory for now on in both the kits and for replacement parts
Dave Ketelhut
Team Compass USA
Gens Ace
Prostarhobby.com
Dave Ketelhut is offline        Reply With Quote
Old 12-04-2012, 06:35 PM   #67
dunkonu23
Default Starting the frame
Hey guys, guess what? I got my wife sick. So...I need to take care of her. I wish I could post more tonight, but I'm needed--and it's a good feeling to know that.
With that in mind, I have only a few steps today.
Bag 17 has the electronics tray and support.
Please note: Installation of the tray is directional: One side of the tray has countersunk drilled holes. The screws are countersunk as well. This was likely done to keep a flat surface. Do not over tighten the screws--remember, the hole is countersunk! Also, before you install this in your helicopter, be sure to lightly sand the edges using wet wet/dry sandpaper. If you don't want use wet, make sure you use a mask!
The top side of the electronics tray.
The underside of the electronics tray.
Bag 18 19 Contains bearings and the antirotation/main bearing mount.
Well need these later.
I chose MKS DS92A+ servos. I've been told they're essentially a plastic cased DS95, so I'm happy with my choice. Also shown bag 20.
Bag 20 contains the servo mount and associated hardware. If your servos have four mounting holes you'll want to use the plastic servo nuts. Note that they come in two sizes: 7 and 6mm wide. The bag also contains servo spacers. If you're using single hole servos you'll use the screws in bag 20, but....
You'll need the nylock nuts found in an unmarked bag.
There are plenty of nuts for this step. I only needed four.
I used a servo spacer on the outside of the servo. If I need it on the inside, I'll move it later.
I used a 4mm wrench to hold the nylock nut while I tightened the 1.5mm screw.
This is the completed aileron and pitch servo installation. I always try to get the servos rotating in the same plane. For this installation, I kept the screws barely tight and then pushed down on the servo in the mount while tightening the upper screw. It looks like they'll rotate in the same plane here.
My apologies again, folks. We'll get this kit done! I promise!
Scott
ID:	371133   Click image for larger version
Name:	Parts in bag 17.jpg
ID:	371134   Click image for larger version
Name:	Completed Electronics tray Top.jpg
ID:	371135   Click image for larger version
Name:	Completed Electronics tray bottom.jpg
ID:	371136   Click image for larger version
Name:	Bag 18 19.jpg
Name:	Bag 18 19 contents.jpg
ID:	371138   Click image for larger version
Name:	Bag 20 and Servos.jpg
ID:	371139   Click image for larger version
Name:	Bag 20 contents.jpg
ID:	371140   Click image for larger version
Name:	Nylock nuts were in an unmarked bag.jpg
ID:	371141   Click image for larger version
Name:	Plenty of nuts I only need four this step.jpg
Name:	Installing servos.jpg
ID:	371143   Click image for larger version
Name:	Use a 4mm wrench or nut driver.jpg
ID:	371144   Click image for larger version
Name:	Completed Aileron and pich servo installation.jpg
Team Manager
OMGRCUSA Servos ):>
Old 12-04-2012, 06:53 PM   #68
Jeff_Barrett
I can confirm this is OK ... just don't be like me and accidentally mount the servos on the wrong side of the mount or they won't clear the elevator servo! LOL!
Jeff_Barrett is offline        Reply With Quote
Old 12-04-2012, 06:59 PM   #69
Ah Clem
I have pressed pins in on the old Knights, and the 7HV with both an arbor press and a vice.
It is very easy to do with the right tools.
KBDD-Team Captain/Compass Team Manager/ ProStar Hobbies/ Team JR Americas/ Gens Ace Field Representative/ Western Robotics Field Representative
Ah Clem is online now        Reply With Quote
Old 12-04-2012, 07:21 PM   #70
dunkonu23
LOL... I know what you mean. I make mistakes all the time. Like... uh.. trailing edge...
Scott
Team Manager
OMGRCUSA Servos ):>
Old 12-04-2012, 07:28 PM   #71
dunkonu23
LOL! I found it easy to improvise with the wrong tools!
Scott
Team Manager
OMGRCUSA Servos ):>
Old 12-04-2012, 08:08 PM   #72
Audball
FWIW, on servos with just one hole on each side, you can still use the exact hardware shown in step 20. Simply use the center hole in the CF spacer, a single screw, and either one of the holes in the plastic servo nut. Works great (and is exactly what you do on the Rave 450, for example).
Audball is offline        Reply With Quote
Old 12-04-2012, 08:12 PM   #73
dunkonu23
Yep, you sure can. I just wanted to follow the manual. I will be skipping putting the arms on the servos until I set up the FBL unit.
Scott
Team Manager
OMGRCUSA Servos ):>
Old 12-04-2012, 10:36 PM   #74
Gawl
Scott
Scott, center your elevator servo and put the arm on first with the delrin link if you can. Otherwise it's a pita unless you remove the motor assembly again.
Team Synergy
VP Racing Fuels
Team Scorpion
Gawl is offline        Reply With Quote
Old 12-04-2012, 11:25 PM   #75
Jason O'Connell
Formerly BarnStormer
+1 on that
had to remove the motor assy here
Team Compass USA
ProStarHobby.com
Scorpion Power Systems
Jason O'Connell is offline        Reply With Quote
Old 12-05-2012, 12:50 AM   #76
Luvmyhelis
I have to say, as a fellow custom fabricator and builder. This thread and workmanship is outstanding! Compass picked the right guy to do this! And I am bloody hard to impress. Nicely done so far.
One thing I did pick out. If lots of guys are splitting the links on the grip to swash links. Quick UK makes a delrin version I have used on my own custom fabbed heads that is bulletproof. I just drill and tap them out to the right thread and install them. Never had one go bad yet. And the delrin stays slippery, and can handle lots of abuse before stretching out and getting sloppy. Just an option.
I do have one question? How smooth and tight is the swash so far guys? Mine wont hit till later this week. Maybe early next. I plan on custom fabbing a few upgrades on mine right off the start though.
Jeti//800Triabolo/Gob700/SHS800/Frankenheli600/Chase420/Compass/Coax/Sk720B/540/360 YGE/YEP/HW/MKS/Outrage/Turnigy/Mibl/Soko/KollDubroRcTek/Boca/Herc/Gryphon/ScottGray Scorp/KDE/Kontronik/TP/Tenax/Lynx
Luvmyhelis is offline        Reply With Quote
Old 12-05-2012, 01:48 AM   #77
BaconRaygun
+1 on the Quick UK links, lucky I had some laying around.
AMA# 977012
Old 12-05-2012, 01:54 AM   #78
Stevemech
Let me no if you come up with a better tail slider assembly as I would be interested!
Steve
Stevemech is offline        Reply With Quote
Old 12-05-2012, 04:50 AM   #79
Luvmyhelis
Steve
Been up all night sketching out a design and sourcing bearings and parts to pull it off. Should be interesting. I am trying to do this so no one has to custom cnc out any parts. Off the shelf stuff that can be mildly modded by anyone with some talent. I think most of us fit that mold here? This is an area where someone like KDE could come out and make a killing. In fact, one of their align upgrade kits isn't too far off.
I am also building a list of links where we can all buy ceramics throughout, but I am including thicker flanged versions. The thicker bearings will support the shafts more securely with less play and last much much longer. Especially on the tail shaft! Not only due to the bearings themselves but the wider races and tighter tolerances.
I want mine to come out fully modded/upgraded for its first flight. Jeff B. and I can compare Sk720 vibe logs since his will be an expertly built stock version. My last couple helis were running so vibe low the Sk720 wouldn't engage into flight mode. crazy. This heli has a far far better design to start with than those did. And Jeffs numbers will give me a really accurate baseline to compare with. I also have a new skid design using CF and CF tubes for the lower skids. The fact the factory sets are just clamped in there aren't building much confidence in me right now. Plus all my flights are on grass. So I want to spread out the contact patch just a little more.
Old 12-05-2012, 06:43 AM   #80
syn90
Do you guys happen to have a part number for those delrin quick uk links that you are referring to?
syn90 is offline        Reply With Quote
