Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 30/50 > Titan X50
Titan X50 Thunder Tiger Titan X50 Helicopters
Old 11-28-2012, 09:23 PM   #1
ranma103
Default Gov sensor bracket
Hey guys I have to ask when sensor brackets are you using and what magnet sensor I want to install my gov but need a bracket that will fit.
Sent From My Galaxy S3 Using Tapa Talk 2.0
Gaui NX4 FBL (SK-540)
Gaui X4 II FBL (Gaui Mini V 5.3 Pro)
TT X50 N FBL (GT5)
T-Rex 700N FBL OS GT15 HZ (SK-540)
ranma103 is online now        Reply With Quote
Old 11-29-2012, 12:23 AM   #2
Elgyn
CV GV1 stock braket that came with it
TT titan x50 / TT mini titan / JR Vigor CV... ...vbar'd / 700 airwolf streched JR Voyager mechanics / JR Venture CP
Elgyn is offline        Reply With Quote
Old 11-29-2012, 06:54 AM   #3
tr911
What governor are you using? I use the Align G600 and I made my own bracket for all three of my Helis. I also purchased magnets from ronlund.com.
Titan x50 FBL, R50 Titan SE FBL, R50 V2, R30 V2 , Trex500, T-Rex 450x2, mCPx X2,
tr911 is offline        Reply With Quote
Old 12-01-2012, 01:23 PM   #4
crashagain
I am using the spectrum backplate sensor on mine.
No making brackets or installing magnets, just mount it on the back of the motor and it picks up the crank pin. and they work with just about everything out there..
Name:	spectrum sensor..jpg
Titan X50...Trex 600LE... Trex600NP...Trex700...
more to come.....
crashagain is online now        Reply With Quote
Old 12-01-2012, 01:31 PM   #5
tr911
You saying this will work with the RCE-G600 governor?
Old 12-01-2012, 08:59 PM   #6
crashagain
it will but you have to solder it to the plug for the align gov, and reverse the black and red wires.
Or you can buy or make one of these. Only the polarity is changed.
http://www.horizonhobby.com/products...ght-SPMAJST1UL
I am running one os these on my 600. Just soldered my own plug.
more to come.....
Old 12-01-2012, 10:27 PM   #7
tr911
Hmmm, this one looks like it would work without the adapter..Looks like I would still need to swap the red and black..
http://www.horizonhobby.com/SearchCm...JZbfBjQI7F8ZaZ
Old 12-17-2012, 02:33 PM   #8
KouDy
Slightly modified stock bracket that i got with Aerospire MultiGov. You know it doesn't really matter, bracket is just holder, there is no science in it. Magnets should be same, also doesn't matter which you use as long as you put them into fan correctly. I think i am currently using Throttle jockey magnets from helikraft. Not like it matters from who are the magnets. Magnet is magnet, it works the same
Titan e325 SE flybarred | Titan X50 flybarred torque tube
Futaba 10C in mode 3
KouDy is offline        Reply With Quote
