| Mikado Logo 700 Xxtreme Mikado Logo 700 Xxtreme Helicopters Discussion |
I got my logo700 and I finished building yesterday……..nice build and 100% match.
I have my setup with kosmik 160A. I am very happy with governor on kosmik and the setup is really nice and easy on kosmik. My setup: LOGO700 Futaba bls HV servos all over Vbar Kosmik 160A……with slave kable Connected to aux2 on vbar Stock SCORPION motor 713mm. edge blades 110mm. edge rotor blades Futaba Sbus receiver 6208 2x5000mah nano tec 65C batteris Head speed 2050 Using kosmik build in BEC on 7,4 volt(no backup battery for me) ….I adjust the volt by programming disc witch is easy to work with. I had to fly it yesterday to see what LOGO700 is like…..i got impressed and it is the best 700 I have ever flown. I like kosmik because it has build in BEC and easy to setup and the governor on kosmik is fantastic. I hope you enjoy yours………….. |
Nice, show us some pictures of how and where you have Kosmic mounted. Would be neat to see. Thanks.
i just used 4 plastic straps to fasten kosmik on the frame.it looks clean and very easy to reach to adjust if necessary.
Was there any way to use the bolts or so fourth to affix to the tray?
#6 |
I personally didn’t find other ways to secure kosmik…I tried to mount with 3 plastic bolts that came with a kit for YGE(esc) and I wanted to add a platform on plastic bolts and then mount kosmik on platform secured with 4 bolts……….but I got a problem….canopy didn’t fit …..the fix was too high . so in my opinion this is the best and easy way …4xplastic straps=fixed=go fly=have fun
#7 |
When Kyle has testing the Kosmic ealier this year, we pretty much used the same method as LOGO800. The unit is BIG, and doesn't leave much room under the canopy for other mounting schemes.
(-: Dave
Kyle Dahl Mikado Sponsors: JR, Voltz/Thor, Scorpion, Edge Blades. |
#8 |
Dave |
#9 |
Logo800,
Can you share a view of your log file with us...I'd like to see what the amp draw and spikes are with this setup...trying to decide if a Kosmik 160 will work or if I need to wait till I can find another Kosmik 200.. Thanks
#1 - Compass 7HV, Scorpion 4530 , VBAR, Kosmik 200 #2 - Logo 700 |
#10 |
indeed and also how tall were the stand offs you tried?
#11 |
Basing the size of the controller, what if you sanded down those sides of CF and just used a few strips of height and approx 1" width of servo tape, that clear stuff>>?
#12 |
Shawn,
Can't believe you haven't broken down yet and bought a Kosmik!! Wish you had so you could feel me in I'm putting one on my Logo 700...it shipped today I'll have a pre-set, Brand New, ready to go YGE 160HV for sale as soon as kit arrives..$350
#13 |
#14 |
I'd think the K 160 would be sufficient. The YGE 160 on the Logo 700 (and 800 as well), has proven to be sufficient in the spec. department, so why not any other 160 rated ESC?
(-: Dave
#15 |
The kosmic works really well in my whiplash, & from ks model I paid a extra $200 for the Logo 700 kit to be replaced with the kosmic instead of YGE.. Use K bec & gov it's sooo easy.. The 160 is plenty.. Probably 90% of use could use a 120 helijive and it be good
#16 |
Because my kit was bare I didn't have the yge to test with my flights before the BIG freeze so I can not comment there. As far as a Jive 120HV,,, I am not sure and will never commit to saying how it will or would hold up, the MOST important part there to consider is your ambient temperature, that makes a HUGE difference on what size of esc will work for you for sure. And YES in regards to the Big K Kosmics...Jim I will try one no worries, although the given combo is 100% proven and adequate to all ends, I tend to like to try stuff out!
#17 |
Guys.....as Dave said: other brands of 160A esc doing good on logo700 whay not kosmik?? Here in Norway is getting cold now and not mutch flying.... But i am going to fly more as soon as i get a chance....
#18 | |
Your statement about Kyle testing the Kosmic begs the question. How does the Kosmic governor compare to the V-Bar/YGE external governor for 3D flying? |
#19 |
Kosmic testing? I don't want to disparage the good Kontronik name (and great products...have used them for years and still do), and I am confident Kontronik got all the bugs worked out prior to releasing the Kosmic. But I won't lie about things, so here's why I can't answer the question.
Kyle received some very early prototypes of the Kosmic, and they didn't last long. We went through several units, burned one up, sent one back, got another, it didn't work, did on-line updates, things still didn't work right, sent the unit back etc. You know, standard prototyping stuff which always goes on. Nothing starts out perfect...at least none of the products we've prototyped and been involved with. But before we could really get one to work well enough to start making comparisons, Kontronik quit sending units to test. So we never got the chance to build an experience base with the Kosmic. Kontronik obviously got things straightened out, as Kosmics are being used now with good reports from what I've read. So, I can't answer your question, as I don't know the answer (-: Dave
#20 |
I made this for my XXtreme 800 from some aluminum stock from my local Home Depot.
