Go Back   HeliFreak > R/C Helicopter Support > Mikado Logo Helicopters > Mikado Logo 700 Xxtreme
Mikado Logo 700 Xxtreme Mikado Logo 700 Xxtreme Helicopters Discussion
Old 01-19-2013, 06:07 PM   #41
NTM
Check your datalogs from the kosmik to see how often you're pegging out the pwm.
That tells the story better than transmitter %.
NTM is offline        Reply With Quote
Old 02-16-2013, 03:17 PM   #42
robbarnes1098
Default logo700 with kosmik160
I did hence I went for a 19 tooth to keep the Pwm correct etc
Midland Helicopters UK
robbarnes1098 is offline        Reply With Quote
Old 03-07-2013, 09:49 AM   #43
mahbouni
Originally Posted by LOGO800 View Post
here are some pictures
Attachment 369796
Attachment 369797
kosmik looks a little bit large but no problems with canopy
I did the same but I cut a sheet of foam from a friend's Goblin packaging to put underneath. I must say its like a battering ram in that position. I would hate to see one of these go nose in to the ground.
Logo 700 Synergy E7 Logo 600 Logo 500 Protos 500 Mini Protos
mahbouni is offline        Reply With Quote
Old 03-07-2013, 02:12 PM   #44
stocksy27
What PWM is correct?
stocksy27 is offline        Reply With Quote
Old 03-07-2013, 04:40 PM   #45
robbarnes1098
Check with Ben Varley he will tell you exactly if you send him your files etc !
Old 03-07-2013, 08:16 PM   #46
NTM
Just not 100, or close to it too much. That means your out of gov headroom.
Old 03-08-2013, 02:08 AM   #47
mahbouni
Correct me if I'm wrong but I would have thought the most efficient use of the governor would be when your most power demanding move just touches 100% PWM or slightly below it. If you're reaching only 80% then there is unused headroom.
Old 03-08-2013, 02:40 AM   #48
NTM
Correct.
Old 03-08-2013, 02:42 AM   #49
stocksy27
My kosmik is currently out if action.
Off topic here but Jlog on my helijive shows PWM 90-97% through the entire flight so would i assume this is most efficient?
Old 03-08-2013, 02:47 AM   #50
robbarnes1098
Ill have to check mine again and ill tell you as mine was right according to Ben !
