Old 11-29-2012, 03:11 PM   #1
snowman1638
Default What's Kyle's vbar numbers
Hi Dave, do you mind sharing Kyle's vbar numbers on Logo 800 Extreme? Saw you just did it with logo 700.
snowman1638 is offline        Reply With Quote
Old 11-30-2012, 12:23 PM   #2
dahld
No problem.
Main Rotor:
style - 70
agility - 100
gain - 108
Main Rotor Expert:
parameters:
dead band - 2
elev. pre-comp - 8
paddle sim. - 0
expo - 5%
optimizer:
50 / 50
Tail Rotor:
yaw rate - 120
gain - 80
Tail Rotor Expert (I'll just list the numbers vertically as they appear in the menu):
parameters:
5
65
80
55
25
10
expo - 10%
optimizer:
30/30
torque pre-comp:
35
0
0
Gov Gain: 30
Gov Expert (numbers listed vertically as they appear in the menu:
3
20
15
15
Set-up menu:
collective - 87 (not sure what that equates to as to the number of degrees +/- collective...about 12 I recall)
cyclic - 100
pitch pump - 15
Caution: you may or may not like the way the helis flies with these numbers. The beauty of V-Bar...adjust to your liking.
(-: Dave
dahld is offline        Reply With Quote
Old 11-30-2012, 01:00 PM   #3
faxxe
Expo -10? Halleluja
Thank you for that information, Dave.....
-Heimo
Logo 800 XX / Pyro800 comp / Kosmik200+ / S9352hv_BLS256 / Vstabi 6.0 / Edge 813
Raptor e720 / 4530 / Kosmik160+ / JR8921&256 / Vstabi6.0 / DH 711
Mikado VBC
faxxe is offline        Reply With Quote
Old 11-30-2012, 02:55 PM   #4
snowman1638
thank you so much, Dave. All of us can learn from those numbers and they will be really helpful! Those numbers are for 753mm blades, right?
Old 11-30-2012, 02:57 PM   #5
snowman1638
Originally Posted by faxxe View Post
Expo -10? Halleluja
-Heimo
guess good fingers are needed when using just -10 expo on tail (50% default)
Old 11-30-2012, 03:38 PM   #6
dahld
@ snowman1638,
Kyle and 753mm blades on the XX 800...
Kyle competed with the 800 in 2011 with various blades. The XFC was with 813's, the 3D Masters and the "ONE" Competition at IRCHA was with 753's, and then post IRCHA, he reverted back to 813's. At the Rotor Live Show in Germany in March of 2012, he flew 813's.
The 753's were used to help "quicken-up" the heli, but as I said during the debate at the time between the two blades, the 753's raise the disc loading on the 800 pretty high, and you've got to learn to manage the flying of the heli to make the combo work for you. I'd dare say most would not like the way the 800 flies on 753's, as most guys are brought-up these days on helis (from all manufacturers), that are pretty lightly disc loaded as a general rule.
In the end, Kyle would tell you that due to the machine's size and weight, it is far more suited for (and has a better overall blend of performance), when flown on the 813's.
The numbers shown are Kyle's current set-up using 813's.
(-: Dave
Old 12-01-2012, 08:41 PM   #7
jtjohn1
I wonder how it will fly with the ~770mm blades that are coming out with the goblin770
Logo XXtreme, Kosmik, Pyro 800-48L Futaba 157s/256. Henseleit TDR, Pyro 700-52, 120 Jive, V-Bar 5.3, BLS253/251. Logo 600SE, Scorp 5020-450KV, 120 Helijive, Futaba 451s/251. Logo 400, Align 510MGs, JR 8900G, Kontronik Jive 80+ LV,Mini Pyro 400-14,
jtjohn1 is offline        Reply With Quote
Old 12-06-2012, 02:19 PM   #8
sgrim80
Expo -10? Halleluja
-Heimo
I dont read that as -10. If you look above and below it the - is used between other numbers that wouldnt be negative so I think Dave means 10% NOT -10%
Team Mikado USA!!!
Team Scorpion!
Logo 600SX - Scorpion 4035-560, 10s 4400 packs
Logo 690SX - Stock Scorpion motor, 12s 4500 packs
sgrim80 is offline        Reply With Quote
Old 12-06-2012, 03:44 PM   #9
dahld
Correct (-:
(-: Dave
