| NX4 Discussion and support of the Gaui NX4 Nitro Helicopter |
#21 |
My head bolts were very tight but I was very lucky to have 2 new allen wrenches 1 screw broke loose, when I examined the one that came out there was no thread lock.
It was so tight that when it came apart the wrench was bending. I did try to remove the other screw and gave up, put the red dampers in and blue thread lock good to go!!
T-rex 700N, Logo 600,Logo 500,T-rex 600e,Synergy E5,T-rex 450,T-rex 250, Blade 450x Gaui NX4 MCPX, AMA 8367 |
#22 |
A few other issues with my kit.
The supplied 2.6 mm bolts for servo mounting are a problem when trying to mount the aileron and pitch servos. My kit included 2.6 x 12 mm bolts. The manual calls out 2.6 x 10. As the holes in the angled servo mounts are not drilled/tapped all the way through, the 12 mm bolts are too long and required a visit from Dr. Dremel. The four holes (two each) in the motor mounts -- for bolting the mounts to the CF frames were drilled all the way through, but the tap itself was not run all the way through, preventing the four 3 x 8 mm screws from being tightened down to secure the motor mounts. For this, I had a 3 mm tap on hand, and quickly solved that problem. The kit overall is really nice and well thought out, but there are a few places where Gaui needs to address the ability to build without needing to make minor mods here and there. Also -- when setting the machine up, what is the recommended overall collective pitch range and initial cyclic pitch travel? ----- Edit -- I downloaded the current manual from Gaui. In this version, it appears that the servos should be mounted using their rubber grommets, as opposed to the manual I have, which shows the grommets are not used. That makes more sense, as this is a nitro heli with its attendant motor vibes. I'll add those and see if the 12 mm bolts are still on the long side.
Dave Making the world better, one helicopter at a time. Team Heliproz Last edited by dksia; 01-04-2013 at 12:05 PM.. Reason: More info added. |
#23 |
I added the rubber servo grommets and used the brass eyelets that come with the Align servos, the bolts are much happier, although 10 mm would still be preferred over 12 mm length.
No biggie.
Dave Making the world better, one helicopter at a time. Team Heliproz |
#24 |
Awesome post!
I am so pumped to see this! I have gotten away from electric and im having a blast with my trexx700 nitro which is my first nitro bird With that being said i only got a align because Gaui was not offering a nitro I AM SO PUMPED that gaui is going in the nitro direction even if its not in the big bird sizes This thing looks like an x5 on nitro PLEASE PLEASE PLEASE gaui make an NX7 I would buy that in a heart beat regardless of the cost! All of this is great news! Nice thread and beautiful heli
Align 700N DFC -OS105HZR Gaui X7-microbeast, JR HV Servos,Futaba HV Tail, Align 700E 510 KV motor To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Gaui X5-All Stock for the moment Blade 130x, Blade 120, Nano cpx |
#25 | |
GAUI X7 - GAUI X5 - GAUI NX4 - GAUI X4 II - GAUI X2 (R.I.P.) - All on VBar 5.3 Pro GAUI USA / Scorpion Motors & ESC / Scorpion Competition Packs 65C+ / Spin Blades / YS Engines / VP PowerMaster |
#26 |
One NX4 at 3000 headspeed coming up!
The clutch bell, pinion and frame stiffener upgrade was super easy to install. It'll probably be a few weeks to a month before I can test it. Today's high was -7 F.
#27 | |
Matt, I'm having a weird issue and I'm not sure where to start on it. Every once in a while, my engine stutters, especially after a hard stop. For example, if I fly to my right and turn and then do a full speed pass in front of me, sometimes I flick elevator up really hard and stop the heli inverted. The maneuver is easy, but it looks so cool, especially if you do it at high speed. Well, right when I stop the heli, the engine stutters. Its almost as if its trying to catch up. I have a feeling this is a problem with the vbar governor, but I don't know. The other thing I thought of was perhaps a lack of pressure and the engine starving for fuel? Do you run the vbar nitro governor? If so, did you have to make any adjustments to the nitro-specific parameters? Thanks!
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Rush 700 * Trex 700N x 2 * Trex 600Pro * Gaui NX4 - V-Bar on all AMA #934662 |
#28 | |
Can you post what your governor numbers are (both main slider and doctor's hat) and I will compare them to my 90's? I have just about fixed it on that model.
#29 | |
Ok, on the NX4, I left the main slider at the default of 60. Dr. hat... changed runup to 3 and min. governor to -50%. All other values are default for nitro. Thanks Matt! Carlos.
#30 |
Ok I'll check when I get home from work and post back. Off the bat try -10 for min governor. As soon as you unload the heli suddenly, the motor comes really close to idle with -50. (-100 and + 100 means 0 is 50% and -50 is actually 25%) That could cause it to load and then studder trying to burn off the fuel.
#31 | |
#32 |
Ya I'm pleased with it, it's worked well so far. Another thing is on a separate flight, reduce your governor gain to about 45-50. A nitro motor throttle works much slower than an electric and you may also be noticing the lag where the VBar governor is just working the throttle faster that the engine can keep up.
#33 |
Yeah, to be honest, I'm not thrilled with the vbar nitro governor. It worked fantastic with the electric helis, but for nitro, I just have had too many hiccups along the way with all my nitro helis. Could be just inexperience on my end.
But for example, the bailout works great, and in some of my helis, it works on the bench, while in my new 700N it does not. The bailout never arms while on the bench. I opened a ticket with RH about it and MrMel told me that it should never arm on the bench. However, I have two other nitros and I can do the bailout thing on both of them while on the bench. This helps you dial in the lowest number on the TH curve that will still give you bailout without triggering soft start. Very useful! Other times, I hear the nitro screaming while the head is unloaded and then stutter when I do I hard stop. It also gets "confused" sometimes during constant piro flips. I'm adding just enough collective to keep it in the air yet I hear the engine revving or slowing as I'm stirring the cyclic. Perhaps I just need to play with it a bit more.
#34 | |
I agree with you that it is amazing on electrics. The VBar governor does work well on nitros after you get it tuned. I had help from some really cool guys in Texas, Rusty, Rob and John, and they really helped me to understand how the VBar governor works with the nitros. After that help and some self learning about it, mine works great. Stick with it man, try some things and you'll figure it out. I'll post my settings in a few hours when I get home.
#35 |
OK, my VBar governor Nitro settings are:
45 Main slider 30 Runup 25 Differential 25 Integral 30 Max P Limiter 40 Cyclic Add 50 Collective Dynamic 0 Collective Reduce -10% Min Governor
#36 | |
BTW, I did 3 quick flights today with -10% on the min governor and also opened up the carb a couple clicks past 1 turn. I was still able to make it stutter once or twice, but not as bad as it was doing it before. It was very windy so it was hard to tell sometimes if it was stuttering or if it was just windy! I'll try again Sat. and this time I'll program in your settings into another bank. Gracias again! Carlos.
#37 | |
I'm using combined mode, and by looking at your numbers, if I bump up the runup that high, my spoolup will be crazy fast... instead of the nice soft start I have right now. I flew it today after playing around a click or two at a time on the needle and got it to make really good power and eliminated the stutter, so I think I'm going to stick with these settings for now, but I thank you very much anyway! Carlos.
#38 |
Hey , Thanks for all info , mine arived today , verry easy to build , and fast ,,,only when you arive on the feul tank section ,,,,, i have no fingers anymore afther putting all rubbers on place ,, now the compleet rubber is laying in the tank ,,i see tomorow how i can take this out the tank again ,, .
Greats and thanks |
#39 |
You're pretty much screwed if the rubber and nipple are inside the tank. I had this happen on another model and I wound up buying another tank after some frustration.
The bitterness of poor quality, lingers long after the cheap price is forgotten. Buy the best and only cry once! |
#40 |
New carbon fiber skids for the X5 and NX4
