Old 11-30-2012, 03:52 PM   #1
Scotty T
Default Preferred Connectors
What do you guys prefer? EC5's, Deans, or what?
Addicted to Helis
Trex 900 DFC Ultra Combo OS HZ 195 Hyper , Goblin 1200 84S Flybared
Scotty T is offline        Reply With Quote
Old 11-30-2012, 04:00 PM   #2
satsuma
ECs, great connectors.
Regards
Sats
satsuma is offline        Reply With Quote
Old 11-30-2012, 04:01 PM   #3
treotraveler
I prefer and use E-flight or Losi EC5s on flight packs, and EC3s on rx packs. I had a Deans fail just prior to lift off, so I will never trust a Deans connector any longer. I was real lucky the Deans failed before getting airborn....
Trex 500esp fbl dfc 6s
Trex 600cf fbl 5 blade Hughs 530f TT 6s x2
Trex 600efl Pro fbl 12s Trex 700e v2 12s
Chaos 600e fbl 4 blade Blackhawk 12s Chaos 600e fbl Airwolf 12s BeastX DX8 DX18QQ TX
treotraveler is online now        Reply With Quote
Old 11-30-2012, 04:06 PM   #4
Geardaddy
I've been a loyal Deans fan for years.. Never had one hiccup.. I think the trick to deans is soldering them properly, with enough heat.. That being said, I don't like the mini "nuke" explosion when I plug in my 6s packs on my TRex 500, and I've developed some pitting on the blades of the connectors. For that reason, on my 700 that I'll be starting soon, I decided to give Anderson PowerPoles a try.. Ordered 25 of them, and the crimping tool.. I've played with EC5's, and don't care for them because I have a hard time getting them apart.. I'm excited to see how the PowerPoles work..
GD
TRex 700DFC CC 120HV/VBar
TRex 500 ESP/FBL CC Ice100, MiniVBar
TRex 600LE/ OS50/ Full Size VBar/ Arizona Regulator , FrankenBlade 400/Sonic head and tail/CF Frame, Blade MSR, Bunch o' planks.. DX7/Futaba 9C
Geardaddy is online now        Reply With Quote
Old 11-30-2012, 04:11 PM   #5
Scotty T
That was my concern. The EC3 are a bastard to get apart. I can't speak to the EC5's cause I never used them but based on the EC3's they were a nightmare. I felt like I had to yank too hard on the connectors / cables.
Addicted to Helis
Old 11-30-2012, 04:14 PM   #6
motogman
You still get the pitting / arcing ing the PP's also I have been using these inbetween the Positive connector use it as last heat up connection.
http://www.espritmodel.com/jeti-afc-...-8mm-300a.aspx
well not this large one they have smaller sizes but work great. I use PP's on everything from a 450 on up to a 36% 30 plank pulling 200 amps work great but yeah they pit also
motogman is offline        Reply With Quote
Old 11-30-2012, 04:17 PM   #7
RobO
EC5 or EC3, never a problem.
You don't have to be the best pilot to have the most fun!
RobO is offline        Reply With Quote
Old 11-30-2012, 04:21 PM   #8
RV_7A
Just a quick tip on EC3 and 5s. I always just used the blue housing to hold the female connector on the battery. I then solder the male on the ESC and never install the blue housing on them. They are very easy to plug each wire in separately. Nothing is exposed that could short out. On my 700 I use the deans to connect the batteries to the serial connector and use Castle Creations 5mm connectors to energize the ESC. Works great!
Jeff B
RV_7A is online now        Reply With Quote
Old 11-30-2012, 07:32 PM   #9
K2Freak
I highly recomend using an anti-spark resistor. Your connectors will never scar again...
T-Rex 800E CHP DL / VBar / YGE 160HV / X-era 4030 470kv / MKS DS660A+ & DS760 / Align 780mm / Gryphon Quasar / KDE performance tail
K2Freak is offline        Reply With Quote
Old 12-22-2012, 12:07 AM   #10
Sladex
Ec5's all the way !
Trex 700E V2 - Canomod Phantom V2 Canopy, AR7200BX, CC BEC PRO
DX8!
Sladex is online now        Reply With Quote
Old 12-22-2012, 01:08 AM   #11
ddj74
Never had a problems with Deans. You just need a good soldering iron. I use a 150 watt one from Radio Shack. If you use a weak soldering iron your connector is exposed to heat longer thus melting the connector a little which will make the fit loose. All my Deans connectors have always been very snug fit. Never had one fail which only reason it would fail if you did a poor soldering job.
This is what i use to soldier the connectors on. Makes it quick and easy...
T-REX 700 DFC v3, AR7200BX, ICE2 160HV,DC-UP MARK II
MKS HBL950 & MKS HBL980, GRYPHON EXTREME REGULATOR
POWERED BY THUNDER POWER LIPO'S
ddj74 is offline        Reply With Quote
Old 12-22-2012, 04:15 AM   #12
Strategist
I know people have used Deans and EC3 connectors on 700s - they absolutely work. And yes, Deans are a LOT easier to connect and disconnect.
However ... The electrical engineer in me could never get past the idea that those connectors are usually only rated for ~60 amps ... And my 700 is constantly operating well above that level. So EC5s for me.
Strategist is offline        Reply With Quote
Old 12-22-2012, 06:10 AM   #13
EC225LP
EC5's for the flight packs and EC3 for the rx.....
I used deans on my 550 but converted all my packs/ESC's when I got the 700. I recon the EC5's are way better for the HV set up... Deans good for 3s/450's though
EC225LP is online now        Reply With Quote
Old 12-22-2012, 09:50 AM   #14
K2Freak
I ran 200+ amps through Deans for months. Just fine.
Old 12-22-2012, 01:04 PM   #15
nightflyr
+1 and APP's will last forever.
MSR, MCPX, 450s, 600, 650, 700, 800, 900, 1000
Assorted
Mix Fixed Wing.
AMA # 972083
Old 12-22-2012, 01:58 PM   #16
flyinghigh450
PRC6 connectors from Progressive RC are the best connectors $$ can buy..Also the only connectors rated to handle 200+ Amps ..
Team Align
flyinghigh450 is online now        Reply With Quote
Old 12-22-2012, 08:23 PM   #17
beenflying
I'm converting all of my larger helis over to the XT90:
http://www.hobbyking.com/hobbyking/s..._5_pairs_.html
I've been using XT60's on all of my smaller helis without any problems, and I was using EC5's on the bigger helis, but I like the XT90 better, especially as they take large wires well and you can use heat shrink to support the weakest point in the lead (where the solder on the wire stops).
Gaui X2 FES ZYX, Gaui 425 FB, Gaui X5 FES MB v3,
250 DFC ZYX, 450 V2 FB, 450 DFC Sport ZYX,
ALZRC 450 Pro FBL 3GY v2, Devil 450 FAST VCTRC 3GX, 500 DFC Pro GV8000 VBar, O6
500ESP SDC ZYX-S
, 700E DFC HV iKon, O7, 550E DHPS FBL HB800, O9 - ZYX v4
beenflying is offline        Reply With Quote
Old 12-22-2012, 08:46 PM   #18
Skidpad
I think it depends on your ec3's...I recently purchased some genuine eflight ec3's and they were very difficult to pull apart initially, so I lubed them with some RadioShack contact/control electrical cleaner/lube (store brand of Deoxit) - they work great now - secure, yet come apart easier. My "clone" ec3's pull apart easier.
Fusion 50, Blade 450 3D/FBL; mCPX BL, DX8
Skidpad is offline        Reply With Quote
Old 12-23-2012, 05:52 AM   #19
Scotty T
Interesting, I'll have to give that a try.
Addicted to Helis
Old 12-23-2012, 06:36 AM   #20
jimbo4510
on my 700 i use ec5 for flight packs and deans for rx on my 500 and below xt60s ec5 are a pain and i have had deans melt on some of my rc cars but they where during massive amps through them
mcpx,130x,blade400standard equipment,trex 450 flybarred,trex 500 converted to dfc head and microbest, 700dfc with vbar 5.3 silverline,dji naza f450 ,raptor 50 v2 , warp 360 with microbes
jimbo4510 is offline        Reply With Quote
