Old 12-01-2012, 08:51 AM   #1
xermalk
Default Night Flying on a 250
So
Im planing on kitting out my Walkera Master CP for night flying.
This is what i currently plan to grab from hobbyking.
The glow in the dark stuff is for another project.
Now what I'm wondering is how important it is with a led lit main rotor? I doubt i have the skills to make&balance 205mm night blades myself.
What I'm considering is going with white rotor blades and pointing one or two white 3mm leds against the underside of the rotor.
xermalk is offline        Reply With Quote
Old 12-02-2012, 01:31 AM   #2
OneFingerHank
Here is a link I'm not sure if they make them for a 250. If you look up Timtreo's blog I think he makes custom blades, shoot him a P/M and see. I've been playing around with a 130X that I set up for night flying and it is much easier to have the blades lit up.
http://helircstore.com/shop/index.ph...product_id=615
OneFingerHank is offline        Reply With Quote
Old 12-12-2012, 10:07 AM   #3
xermalk
So, i used some of the turnigy glow in the dark stuff to get a feel for how i want the led layout.
Now im just considering what colors i should go with, im considdering color coding it so i have:
Green on one side and Red on the other, the piecen on the side of the frame, \ / in the y and the strips on the tail.
White on the landing skids and the | in the y on the canopy.
And then yellow/gold on the long side strip and possibly on the tail boom (the boom would have to be fastened with zipties as there's not a chance that the led tape will stick).
The second option is to go with red on the skid white/golden canopy and green small strips on the side of the frame and tail
Im not sure i want leds on the bottom of the skid as ill be flying and landing in the snow . and the skids aren't thick enough for a led strip to attach.
Anyone with some night flying experience on 450/250's that could give me some hints on what to think of ? as the space is very limited on a 250 for the ledstrips,
glow tapes are 5cm (same as 3 leds), the long one on the canopy is 15cm (9 leds).
ID:	373509   Click image for larger version
