Old 12-01-2012, 05:44 PM   #1
Lee777
Default info needed on roll rates???
Hi Lads,
I have just programmed my 3g unit, i did all the limits and swash moving the correct way but how do i lower the swash roll and elev rates?? do i just set them in the tx like on a flybarred heli?? and do i set the tail gyro gain in the tx aswell??
Cheers lads any help apreciated so i can get it sorted and go test flying in the morning
Dx7S T rex 450l Dominator x2 - T rex 500l Dominator - T rex 550l Dominator - Radian Pro - Radian Eflite Inverza
Lee777 is offline        Reply With Quote
Old 12-01-2012, 08:48 PM   #2
bad007
With the 3G you actually get all the cyclic you programmed at 80% stick so use DRs and go straight to 85% and you'll still have all the cyclic you programmed but not till 95% stick that way. Set TX expo to 30 and cyclic expo in the software to 0 for maden. Yes use the roll rates to tame it down and fine tune it. For example my 550 and 500 is setup at 13.5 cyclic, DRs at 85 and some expo to tame it down around center stick. No DRs with 13.5 is super twitchy
Read post 8 and 10
http://helifreak.com/showthread.php?t=473914
Align 450Pro 3GX, Align 500 3G
Align 550 3g, Velocity 50 Vbar
bad007 is offline        Reply With Quote
Old 12-02-2012, 04:28 AM   #3
Lee777
Can i use my 3gx software and lead to set this 3g unit up?? Or it it different?
Old 12-02-2012, 08:48 AM   #4
bad007
3G software is totally different and requires you to download and install it. You need to get it installed because the 3G has small and large helli settings to load into the controller. The 3GX dongle will work on both 3G and 3GX.
Old 12-02-2012, 03:37 PM   #5
Lee777
What version is best to download??
Old 12-02-2012, 04:23 PM   #6
bad007
2.1
