Old 12-01-2012, 05:58 PM   #1
Windmanquebec
Location: St-Julie Québec Canada and Isle La Motte Vermont USA
Default Disable Copilot for swash leveling.
Ok I changed my head ans I want to start over with my mechanical set-up from servo leveling going up to blade angle.
I want to make sure that the copilot don't interfere with my set-up. I normally have the off-on copilot setup on my gyro switch but even with the switch at off, it look like the copilot still have a bit of authority am I dreaming ?
SYMA S-107/BLADE (2)450 3D FBL/ALIGN(3)T-REX 500 (2)T-REX 550/DX8
Windmanquebec is online now        Reply With Quote
Old 12-01-2012, 06:28 PM   #2
nightflyr
If you have auto trim set to anything over 0 your not dreaming
nightflyr is online now        Reply With Quote
Old 12-01-2012, 10:52 PM   #3
Windmanquebec
So if auto trim is set to 0, I can go with my swash leveling and it is like if the copilot was not installed?
Old 12-02-2012, 10:12 AM   #4
jdd1
Hi Windmanquebec,
That is correct. There is no input to the servos if Auto Trim is set to OFF (0) AND the remote is in the Off position on the Tx to prevent swash movement.
Note: Auto Trim can and should be adjusted or set to OFF (0) during Quick Setup to prevent swash movement. It is also possible to adjust Auto Trim later in the Preferences menu.
Jack
Jack Doherty
FMA Beta Tester
CoPilot II HD
PowerLab 8
jdd1 is offline        Reply With Quote
Old 12-02-2012, 02:38 PM   #5
n6nev
I have the same problem, when come's to the part where is states " move stick to the left and press enter" the elevetor servo drops the swash plate all the way, so I disconnect the main sensor and the setup proceeds just fine. flys great....when doing a quick set up , all other setting are errased. so there should be no cp2 input.... I only have this with the v2.41. , old program it was not a problem...(1.47 I think).........
"You can always tell a pilot,but not much"
Gaui X 5 Phanthom 2
n6nev is offline        Reply With Quote
