Old 12-02-2012, 11:27 AM   #1
tourerjim
Default Setting Gov.?.
I've just replaced my aging 3G for the 3GX but struggling to fine info on setting throttle & gov in tx, done the gov sync with with 3GX so just need an idea what to set the throttle norm mode & idle 1/2 & the atv for gov
DX18, Phoenix Sims, Blade Nano, mCP X, 130x, 180cfx.
Trex 250dfc Gpro, Mini Titan 325se 3G.
Trex 450v2pro Gpro, Trex 500EFL Gpro.
Trex 600Ndfc Gpro, Trex 600E Pro Gpro.
tourerjim is offline        Reply With Quote
Old 12-02-2012, 11:45 AM   #2
tourerjim
forgot to mention this is for my 600n but also got 700n to do.
Old 12-02-2012, 01:18 PM   #3
bad007
Use mixing, here's some examples. First is 3GX no gov in normal and two speeds using the gear switch.
No gov setup in normal
Switched to IU
Here's one for my vbar, two mixes, the second adds to the first to get two speeds with the FMs Mix1 FM 1and2 and mix2 FM2
Align 450Pro 3GX, Align 500 DFC 3G
Align 550 3GX, Velocity 50 Vbar OS55 HZ-R
Dominator 500L, MicroBeast Plus, Radix V2 Edge KDBB Castle,Hobbywing Platinum Pro V4, Switch Blades.
bad007 is offline        Reply With Quote
Old 12-03-2012, 03:46 AM   #4
tourerjim
My TX is DSX9 so only need to use atv for 'gear' + is gov & - is rate mode so i assume i keep throttles curve v's in iu's as if mechanical setup then in gov mod set to around 60ish %.?.
Old 12-03-2012, 05:57 PM   #5
bad007
Set usable v curves just incase the gov fails and you good to go.
Linked up it will show you the head speed for your settings after inputting your gear ratio.
