Go Back   HeliFreak > R/C Electronics Support > DJI Heli Autopilot System(Naza-H/WooKong-H/Ace One)
DJI Heli Autopilot System(Naza-H/WooKong-H/Ace One) DJI Heli Autopilot System(Naza-H/WooKong-H/Ace One) Factory Support Forum
Old 12-02-2012, 10:17 PM   #1
DJI Innovations
Default DJI Naza-H GPS Flybarless System
DJI Has Already Released Formally Naza Series Product——Naza-H GPS Helicopter System.
In order to help customers get rid of some confusions about Naza-H GPS functions, a thread created.
Naza-H GPS is not only an autopilot stabilization system (Attitude Mode & Gps Attitude Mode) included following all other DJI existing helicopter autopilot system, Ace One, Ace Waypoint and WooKong-H/WooKong-H Lite, but is a Flybarless System with very good performance ((Including Pirouette Compensation, Auto Trim, Suitable for Different Flying Styles, etc). You can check the video below.
Therefore, Naza-H is a good option for Flybarless System 3D Flight and Autopilot Stabilization Flight.
Naza-H Main Features:
All-in-One Design
Built-in Tail Gyro/Flybarless Supported
Support for Multiple Electric Helicopter Platforms
Advanced Attitude and Control Algorithm
Optional GPS Module
Multiple Flight Control Modes/Intelligent Switching
D-Bus Supported
Independent LED Module
Semi-auto Take-off & Landing (Will Be Available in The Following New Firmware)
Welcome your discussion, feedback and questions about Naza-H GPS?
DJI Naza-H Setup Demostration:
DJI Naza-H Assistant Software Configuration:
DJI Naza-H 3D Flight
DJI Naza-H GPS Atti.Mode with Position Lock
DJI Innovations is offline        Reply With Quote
Old 12-03-2012, 05:55 AM   #2
thehatguy
Do you plan on adding the Return to Home functionality to this?
John
EX-HeliFreakSwag.com guy
(arthritis got the best of me)
thehatguy is offline        Reply With Quote
Old 12-03-2012, 06:32 AM   #3
alchemy66
John
+1
alchemy66 is offline        Reply With Quote
Old 12-03-2012, 08:10 AM   #4
yang_loo
Will it get Intelligent orientation control with future firmware ?
yang_loo is offline        Reply With Quote
Old 12-04-2012, 03:14 AM   #5
DJI Innovations
Absolutely, the firmware of Naza-H is upgradable!
It will have more useful functions included according to customers' requirements, such as Neutral-Position Recordable and Semi-auto Take-off/Landing. We will have the two functions available firstly.
Regarding Return-to-Home and IOC, we don't have the plan at this early stage. Will make it announced here if we have the plan.
NAZA-H+GPS Autopilot System has GPS Module(optional), Attitude Stabilization, and perfect Flybarless System and Tail Gyro (Including Pirouette Compensation, Auto Trim, Suitable for Different Flying Styles, etc)
Therefore, Naza-H has already been a good option as an autopilot system with GPS module and also a good FBL flight system.
Now we are preparing some videos for Naza-H, will be posted here....
Old 12-04-2012, 03:23 AM   #6
DJI Innovations
We are preparing some good videos now, will post here ASAP.
Old 12-04-2012, 03:31 AM   #7
zeeflyboy
Glad to see you are posting here, since I never had a reply to the two emails I sent... Perhaps I can get a response here.
What is the logic behind not including RTH when the Naza-M has it and it works so well?
I would also like to see you change the software slightly to give the option of setting tail gain numerically in software (in the same way as cyclic gain).
On an AP/FPV rig, which I suggest are your prime targets here, channels are at a premium. To give over a channel just for tail gain is a waste... For the vast majority it is a value they will set and then never change once its working well... Make it so we can set tail gain in the software if we want, and then we'll have another channel spare!
Lastly, when do you expect to have the full manual available for download from your site?
Blade mCP X - Brushless, XP-7A, HP05S
Gaui X2, BeastX/Scorpion 3400kv/YGE-30A/GS-093/DS95i
Align AH-1 Cobra (T-Rex 500)
Align T-Rex 600 EFL Pro, SK720/600MX/YGE-90HV/BL9180/BL9188
zeeflyboy is offline        Reply With Quote
Old 12-04-2012, 12:07 PM   #8
efmautoclutch
Default naza
This is fine showing flips, backwards flight etc, show me a novice using this system, spending 500 bucks isn't a problem, since when you pile up one you are spending that much to fix it.
I want to see a novice take off, fly around, use the home feature, if you get to where you can flip it around, wrecking it will eventually happen, but I want to see a novice fly it around, land, take off, get confidence in flying, I have a couple hex's with your stuff on it, flawless, im ready to buy a couple of these for my 700 nitros, but would like to see someone with no experience fly with your unit on it.
efmautoclutch is offline        Reply With Quote
Old 12-05-2012, 10:34 AM   #9
Hizlimax
Your product description states "Naza-H is suitable for a variety of electric helicopter platforms from small to large, such as 450, 500, 600 and 700 size, etc." Does that mean I should not use it in Trex 800? I just wanted to make sure.
You have to include some sort of RTH in case of failsafe. Even if it doesn't land like Naza-M when RTH is activated, it should return to a certain radius of initial GPS home position. I'm planning to use this for fpv and I need to be sure it will at least return back to where I have TX signal incase I loose it. I do the same with my F450 Naza-M and if I loose signal after like 2kms, it gets back to my signal zone and I take over before it actually returns home and lands. This is a big reassurance especially with a heli that would cause more damage where it falls.
One last question, can the Atti and GPS modes be used as a bail-out function for 3D practicing? I know Align APS cannot be used like that as some members here tried and crashed many times. I feel like it would work since Naza-M seems to level and hold my F450 from any manual flight position whenever I flick the switch.
- SAB GREEN GOBLIN 700
- Synergy E5
- Futaba 18MZ, DJI F450, T-Rex 500 ESP DFC, Hirobo Shuttle Plus +2, Blade MCPX v2, Nanocpx, E-Sky Belt CP CX, E-Sky Co-Comanche, Kyosho Hyperfly
Hizlimax is offline        Reply With Quote
Old 12-05-2012, 04:22 PM   #10
lvmosher
Asked my dealer about getting more Wookong-H units. Reply was he wasn't Does this mean no more Wookong H and now only Naza H? Pardon me if asked and answered already but have not been able to find the answer.
Price difference of $1250 vs $495 has me wondering....
lvmosher is offline        Reply With Quote
Old 12-05-2012, 11:31 PM   #11
DJI Innovations
Naza-M and Naza-H are different product line, so you can't compare the functions with each other. Regarding RTH, we will think over about that, but not at this stage. Quick start is a good start to help customers understand how to use it very quickly. If you run the assistant software of Naza-H, you'll know all of the detailed instruction included inside software. You just need to follow step by step to finish the setup.
Old 12-05-2012, 11:34 PM   #12
DJI Innovations
Totally understand your feeling. We will add the Semi-auto Take-off/Landing feature in the next step. that will help a lot for a novice. That's very easy to come out.
Old 12-05-2012, 11:39 PM   #13
DJI Innovations
Please follow the manual to set up on recommended helicopter type, thanks!
We will considering about RTH function. Naza-H doesn't have bail-out function now....
Old 12-05-2012, 11:43 PM   #14
DJI Innovations
We don't stop the WooKong-H product line, if you need, you can reach the dealers.
Old 12-06-2012, 12:12 AM   #15
Tahoe Ed
I have the WKH and just received the Naza H. They are two different products. The Ace One is the pinnacle of SRH controllers capable of waypoint navigation and control of the Z15 Gimbal. The WKH is more of a scale controller, no 3D. In the future, DJI may choose to give it some of the functions of the Ace One, but since the software has not been upgraded in over a year it is uncertain if that will happen. The Naza H is sport controller capable of 3D plus has stabilization built in with a barometric sensor for altitude hold. Then you add in the GPS/Compass you have an inexpensive controller that can do it all. Maybe not all things as well as its big brothers, but dang good none the less. I hope that helps understand the difference between the models and why there is a difference in price.
AMA #844172 DJI S800 WKM Z15 Nex5N iOSD Data Link Waypoint DJI F450 Naza + GPS with 5.8gHz vTx
DJI Phantom with GoPro3, DJI F330 with Naza + GPS
Align Trex 550 with WKH, Trex 500 with Naza H
Tahoe Ed is offline        Reply With Quote
Old 12-06-2012, 02:05 AM   #16
DJI Innovations
Default Video: Naza-H GPS Attitude Mode with Attitude Stabilization & Position Lock
The Video is for Naza-H GPS Attitude Mode with Attitude Stabilization & Position Lock.
Old 12-06-2012, 03:55 AM   #17
Hizlimax
You could just have said "Yes", "No" or "We haven't tested it on anything larger than 700. I just had to read through the whole manual and it just says "Supported Helicopter Types: 450, 500, 600, 700 Electric Helicopter" Going from your logic and statement, it should not be used on a 550 size helicopter either since its not listed on the manual. I'm still not clear if it would be suitable for Trex 800 or not.
So will Naza-H let you fly around like the Naza-M and Wookong-H does in Atti and GPS modes with 45 degrees angle or will it just lock the position and let you yaw, roll and pitch very slowly? The manual also states that the throttle locks to the current position when you switch to Atti or GPS modes and I don't get the logic in that. I guess I will just buy it or wait for a member to test it out
- Synergy E5
Old 12-06-2012, 05:31 AM   #18
zeeflyboy
Come on, of course it'll be fine on an 800...
It's just a generic statement.
Old 12-06-2012, 06:13 AM   #19
Hizlimax
Most likely it will be fine, but I just wanted a verification from them. Plus when you get an answer like "Please follow the manual to set up on recommended helicopter type, thanks!", you start to question whats generic whats not on that manual.
- Synergy E5
Old 12-06-2012, 07:45 AM   #20
Hizlimax
This seems to answer my question about forward flight in Atti and GPS modes. It seems to work pretty much like the NAZA-M and lets you cruise around with a limited angle.
- Synergy E5
