| DJI Heli Autopilot System(Naza-H/WooKong-H/Ace One) DJI Heli Autopilot System(Naza-H/WooKong-H/Ace One) Factory Support Forum |
#21 |
It is exactly that. Whatever the throttle is at when you switch to AH/GPS mode, the throttle will stay there regardless of what you are going to do with the throttle control. Even Throttle Hold from your controller won't change the throttle of the heli. NAZA-H will use the pitch to control up/down. Your throttle stick will simply telling NAZA-H how fast to go up/down related to it's hovering point.
Align 450 with NAZA-H, 450XL, XCell60, Align 700e, Skookum SK 720, SK-GPS, DX8. ArduPilot (APM 2). Talon 625 Hexa with NAZA-M. |
#22 | |
- SAB GREEN GOBLIN 700 - Synergy E5 - Futaba 18MZ, DJI F450, T-Rex 500 ESP DFC, Hirobo Shuttle Plus +2, Blade MCPX v2, Nanocpx, E-Sky Belt CP CX, E-Sky Co-Comanche, Kyosho Hyperfly |
#23 |
I think it'll work like their NAZA product for the multicopter. You do the special take off sticks sequence and the motor will spin up to a pre-determined throttle and take off using the throttle stick.
#24 |
DJI: Please see the other thread in this forum:
http://www.helifreak.com/showthread.php?t=446123 A lot of pilots are requesting RTH for safety purposes, and peace of mind. Please consider implementing this feature. Thank you! |
#25 | |
That's how I fly anyway tbh, I am always in idle up. Flick off throttle hold and the ESC soft start takes care of the spool up, spins up to whatever speed you have set your curve at in idle up and then off you go... On landing you just land, cut the throttle and let it spool down. There is no problem in operating this way.
Blade mCP X - Brushless, XP-7A, HP05S Gaui X2, BeastX/Scorpion 3400kv/YGE-30A/GS-093/DS95i Align AH-1 Cobra (T-Rex 500) Align T-Rex 600 EFL Pro, SK720/600MX/YGE-90HV/BL9180/BL9188 |
#26 |
Check this out...
https://www.youtube.com/watch?v=_N9KJEtcNMI https://www.youtube.com/watch?v=r9AjbnyBCVA
Jose (Youtube -> Silverexpress01 See also Helifreak Blog) MCPx 76/7 | Trex 250 DFC 667/19 | Hurricane 200 FES 143/7 |
#27 |
DJI Has Already Released Formally Naza Series Product——Naza-H GPS Helicopter System.
In order to help customers get rid of some confusions about Naza-H GPS functions, a thread created. Naza-H GPS is not only an autopilot stabilization system (Attitude Mode & Gps Attitude Mode) included following all other DJI existing helicopter autopilot system, Ace One, Ace Waypoint and WooKong-H/WooKong-H Lite, but is a Flybarless System with very good performance ((Including Pirouette Compensation, Auto Trim, Suitable for Different Flying Styles, etc). You can check the video below. Therefore, Naza-H is a good option for Flybarless System 3D Flight and Autopilot Stabilization Flight. Naza-H Main Features: All-in-One Design Built-in Tail Gyro/Flybarless Supported Support for Multiple Electric Helicopter Platforms Advanced Attitude and Control Algorithm Optional GPS Module Multiple Flight Control Modes/Intelligent Switching D-Bus Supported Independent LED Module Semi-auto Take-off & Landing (Will Be Available in The Following New Firmware) Welcome your discussion, feedback and questions about Naza-H GPS? DJI Naza-H Setup Demostration: DJI Naza-H Assistant Software Configuration: DJI Naza-H 3D Flight DJI Naza-H 3D Flight in 3DX China 2012 DJI Naza-H GPS Atti.Mode with Position Lock Last edited by DJI Innovations; 12-17-2012 at 04:17 AM.. |
#28 |
Check this out:
http://helifreak.com/showthread.php?t=479611 If it works for you, let's start to consolidating the Naza H threads. I have closed this thread: http://helifreak.com/showthread.php?t=448443
AMA #844172 DJI S800 WKM Z15 Nex5N iOSD Data Link Waypoint DJI F450 Naza + GPS with 5.8gHz vTx DJI Phantom with GoPro3, DJI F330 with Naza + GPS Align Trex 550 with WKH, Trex 500 with Naza H |
#29 |
#30 |
at gps mode(position hold) Can i use 6 channel radio(T6j)???
#31 |
No, 7 channels minimum for the GPS mode option
#32 |
Zeeflyboy is correct, you need a 7 channel Tx and Rx preferably with preset failsafe.
#33 |
Guys
Do you think there will be a software upgrade to add governor into Naza-H?
Suat Trex 700 Gasser FBL | HeliBug HB7-RC 17T | Silverline V-Bar| TRM VX270TT | SG | RJX Gas muffler Trex 600 Gasser FBL | HeliBug HB6-RC7 20T | BeastX | GV-1 | Stock Zenoah G290RC | Century V5 muffler |
#34 |
Why not use the ESC gov?
Henseleit TDR! Trex 800E F3C; Trex 550FB ------------------- I have no life anymore - only heli's in my head.. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#35 |
To use Naza in the future on nitro helicopters.
#36 |
Nitro SRH is not supported now. Try the WKH or the Ace One for Nitro unless you want 3D, in that case you are SOL.
#37 |
Tahoe,
I've nearly finished the set up on my Trex 600 but there are a couple of questions I'm unable to find answers to. First one is, when using a BEC, NAZA or any other shouldn't the hot wire be pulled from the ESC to prevent powering the MC from both sides? Second, I am using a flybar. NAZA setup as me skip setting any pitch values and I don't see in the quick guide any thing about pitch or throttle curves. ![]()
Bill Trex 500CF - Trex 600ESP Futaba T8FG |
#38 | |
#39 |
I didn't mention in my post that I had already pulled the positive from my plug on my ESC. I think the positive and negative rail are common on all of the pins so this would be the right way to do it.
//Dennis.
Mini Protos FBL Stretch - 4s MSH Brain : Protos FBL Stretch - SK-720 : Protos FBL Stretch Night flyer SK-720 SAB Goblin 500 Ikon : Logo 600 FBL V-bar, 10s : SAB Goblin 700 Vbar, HK5020, Hawk 120A |
#40 |
Most HV ESCs don't have a BEC built in... In this case you can leave all three wires connected.
If however yours does have a BEC then quite correct - you want to remove at least the positive pin if using external power for the system.
