| 700 Class Electric Helicopters 700 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
I have a rex700e v2 with DFC head, and whant to convert to "normal" v2 fbl head.
What parts do I need? Cheers
/// JR DSX9 2.4 \\\ /// TREX 450 SE v2 \\\ ///TREX 250 \\\ /// HYPERION 720i Net 3 \\\ /// PHOENIX Sim \\\ |
Longer stock main shaft, fbl head hub, fbl dampers, fbl grip arms and fbl 2.5mm links from swash to head grips should do it....
Trex 500esp fbl dfc 6s Trex 600cf fbl 5 blade Hughs 530f TT 6s x2 Trex 600efl Pro fbl 12s Trex 700e v2 12s Chaos 600e fbl 4 blade Blackhawk 12s Chaos 600e fbl Airwolf 12s BeastX DX8 DX18QQ TX |
While back I converted my FB Nitro to FBL with all the required parts from the 700E V2. Here is the thread:
http://helifreak.com/showthread.php?t=305486 I have all the parts listed there, some of them you'll need and some of them you already have. ![]() Hope this helps. ![]()
At the precipice, we change! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Team GrandRC |
Skickat från min LT18i via Tapatalk 2
Could you please let us know if the longer main shaft (its lower part) fits the DFC frame? I think that this is the only problem that could happen with conversion to v2.
I list the parts needed in this thread: http://helifreak.com/showthread.php?t=475648 Thanks, Emil |
#6 |
Is the DFC bad? I was thinking of doing the opposite of you, but now I'm re deciding my plan.
Trex 700E V2 - Canomod Phantom V2 Canopy, AR7200BX, CC BEC PRO DX8! |
