Old 12-03-2012, 07:09 PM   #1
Sladex
Default Beastx Throttle Problem.
The throttle doesnt work. Ive been looking around and i says that the esc has to beep. It only beeps when i put the 12s in. I am using a cc bec pro and the cc hv120
Trex 700E V2 - Canomod Phantom V2 Canopy, AR7200BX, CC BEC PRO
DX8!
Sladex is offline        Reply With Quote
Old 12-03-2012, 07:18 PM   #2
K2Freak
Are you sure that you calibrated the esc correctly? If not, go to the documents section of castle creations site and read about fep and gov setup. It must be done right...
T-Rex 800E CHP DL / VBar / YGE 160HV / X-era 4030 470kv / MKS DS660A+ & DS760 / Align 780mm / Gryphon Quasar / KDE performance tail
K2Freak is offline        Reply With Quote
Old 12-03-2012, 07:27 PM   #3
GT86
Yep, that's probably the problem. You have to teach the esc what your throttle low and high points are.
http://www.castlecreations.com/support/documents.html and toward the bottom you'll see a how to on setting up fixed endpoints. You have to do this first even if you plan on using the governor.
Also, it won't arm unless it sees a zero throttle signal, so check and see that your throttle hold is set to zero.
Sent from my Galaxy Nexus using Tapatalk 2
GT86 is offline        Reply With Quote
Old 12-03-2012, 07:47 PM   #4
Sladex
I dont have the kit to plug it into my computer?
DX8!
Old 12-03-2012, 08:02 PM   #5
K2Freak
They gave you a gift cert for one in the package. Or if not then buy one. You need it to use the cc controller on a heli. Period. That should never have been optional.
You calibrate the endpoints without the castlelink, but probably a bad choice to try to fly - Too many settings not exposed via stick programming. You don't teach cc, you find the points with tx atv. Its not like hw, scorp.
And your throttle hold will not be zero. You will "find" that too.
Read those docs until you understand what you are doing. They are good.
Old 12-03-2012, 08:12 PM   #6
ddj74
make sure your throttle curve is 0, 25, 50 , 75, 100
T-REX 700 DFC v3, AR7200BX, ICE2 160HV,DC-UP MARK II
MKS HBL950 & MKS HBL980, GRYPHON EXTREME REGULATOR
POWERED BY THUNDER POWER LIPO'S
ddj74 is offline        Reply With Quote
Old 12-03-2012, 11:34 PM   #7
Sladex
It still doesnt work. ive got it to spin 3 times so far. But it the esc keeps blinking. I think that means it is in programming mode. My ATV Is L = 52% And H=102%. Something is wrong.
DX8!
Old 12-04-2012, 12:03 AM   #8
Sladex
Bump
DX8!
Old 12-04-2012, 12:21 AM   #9
Sladex
Come on guys i need this in the next few minutes
DX8!
Old 12-04-2012, 12:23 AM   #10
DoctorJ
Is your throttle curve set linear. 0 25 50 75 100
Goblin 700 - XF495 KDE - HC3SX - CC160
Trex 700 - 700 MX - HC3SX - CC120
Blade 450X - Scorpion 2221-6 - CC 50
Blade 130x - HP08 - CC ( many others )
DoctorJ is offline        Reply With Quote
Old 12-04-2012, 12:26 AM   #11
Sladex
Yep
DX8!
Old 12-04-2012, 12:33 AM   #12
K2Freak
Castles have a light? I don't remember that.
Slow down and figure this out. You need the castlelink before you are going anywhere anyway.
Old 12-04-2012, 12:37 AM   #13
DoctorJ
Opp's didn't see that was posted already.
When setting end points you set both to around 50%, then went high and it alerted at 102, sounds ok. Then you went low and it alerted at 52?? What?
You should be going down not up. But what ever this can't be right.
Old 12-04-2012, 12:38 AM   #14
Sladex
I am gonna have to wait days for it to come. Isn't there a way to do it without it . The hv escs have a light on the side. It will basically ask you the questions through the light.
DX8!
Old 12-04-2012, 12:40 AM   #15
Sladex
Yeh. It alerted fine at 102 then I went beep beep beep really fast and then when I switched to low it did the same and beeped on 52. I think I know the culprit, the ar7200bx fail safe thingy
DX8!
Old 12-04-2012, 12:41 AM   #16
DoctorJ
Good luck with that, you really need the cc link. Your in airplane mode.
Old 12-04-2012, 12:44 AM   #17
Sladex
Oh **** off course. Ty
DX8!
Old 12-04-2012, 12:44 AM   #18
ddj74
Re-bind the controller but make sure you are at low stick and switches are at default settings such as throttle hold on or whatever. If a switch isn't in a certain position other then what it was when you bound the controller it will not initialize.
Old 12-04-2012, 08:47 AM   #19
Sladex
Any other suggestion guys
DX8!
Old 12-04-2012, 08:59 AM   #20
Sladex
I need as many suggestions as possible
DX8!
