Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 425
Hurricane 425 Discussion and support of the Gaui Hurricane 425
Old 12-04-2012, 07:06 PM   #1
SQRT(-2)
Default Motor is getting hot
While it flies pretty good, the motor on my Hurricane is hot when it comes down. I let it cool before taking off, but I wonder if this could be an indicator of something I need to adjust.
My throttle curve is pretty normal. 75 at mid stick.
I don't know what motor it is, it is what came on the heli (used) and the can is blank.
I don't know the temp, but I can't hold it for long.
Gaui Hurricane 425 FBL with Robird G31 500 Class Rocks!
EFlight Blade 450 3D, Walkera Super CP
Walkera Devo 10 w/ Deviation
SQRT(-2) is offline        Reply With Quote
Old 12-04-2012, 07:41 PM   #2
PTcaflyer
...From your photo, It looks like that motor is the stock 1100 Gaui motor(tall can)
and it will get hot, VERY HOT!
No worries though...that is normal for that motor...
Gaui 500 / Tarot Quad 450 KK2.0LCD/ X525 (2X) DC 450 FPV 500mw 5.8 / SC10
AMA 953414
PTcaflyer is online now        Reply With Quote
Old 12-05-2012, 04:20 AM   #3
SQRT(-2)
Thanks for the info.
Old 12-06-2012, 10:10 PM   #4
crickr1
I've had a few gauis and i ran my esc on the bottom of frame. Undetermined main gear. It gets good airflow. There and helps. Also run a logo 400 canopy. Fits well plenty of room for batts and has air vent cut in top of canopy above motor. The scorpion motor runs quite hot too. This helped out alot
Keep it in the air!
Lovin MSH!
hybrid Gaz/otos fbl,stretched 6s MiniP Stretched PROTOS 500 ,EC135 Era/Protos500,Compass 6HV, Gaui NX4 all MSH-Brain/Futaba8FG Compass 3D+ CGY750
crickr1 is online now        Reply With Quote
