Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 30/50 > Titan X50
Titan X50 Thunder Tiger Titan X50 Helicopters
Old 12-05-2012, 07:54 AM   #1
Gscott
Default X50 tail buzzing
I have been having an issue with my x50 that I can't track down. The tail makes a loud buzzing under load. I have tried numerous tail blades and even mounted an Align v2 hub and grips but the issue still persists. Today I noticed play with the rear input gear assembly in the tail case. I can move the gear in and out about 1mm and I can also spin the bearing in the tail case. I disassembled the tail tonight and noticed the bearings and spacer for the input bevel gear are not a tight fit in the tail case. Anyone else have this issue? How tight should the bearings and spacer fit in the tail case?
Gscott is offline        Reply With Quote
Old 12-05-2012, 08:46 AM   #2
tr911
It sounds like the drive shaft is fluttering. Check your bearing placement and may be even add another bearing to the shaft.
Titan x50 FBL, R50 Titan SE FBL, R50 V2, R30 V2 , Trex500, T-Rex 450x2, mCPx X2,
tr911 is offline        Reply With Quote
Old 12-05-2012, 11:59 PM   #3
Elgyn
Mine had a similar probem then I heard that the X50's have insufficient torque tube support so I did the double bearing up grade almost right away. Never had a probelm since
TT titan x50 / TT mini titan / JR Vigor CV... ...vbar'd / 700 airwolf streched JR Voyager mechanics / JR Venture CP
Elgyn is offline        Reply With Quote
