Old 12-06-2012, 06:24 AM   #1
Supertuna
Default My first big 300x crash today and repair bill not bad!
Well my first big 300x crash today straight in inverted lost orientation with low evening light
Mainshaft,main blades,canopy,main frame cracked plus main drive gear chewed plus will do main shaft bearing and grand total of parts looks like only about $70 not bad considering the great crunch i heard when it hit....
What have you guys spent on crashes would be interested to know.....i hope i can get her back in the air asap...
Blade mCPx BL,130X, 250 SE,300x,Trex 450, Building - Goblin 500 Scorpion HKIII-4020-1100KV.
Spectrum DX8
Supertuna is offline        Reply With Quote
Old 12-06-2012, 07:14 AM   #2
Brobbo
My worst one was $125. Then another $10 with a mishap bench test.
DX6i
Blade MSR
BLade mCPX
Blade 300x
Brobbo is offline        Reply With Quote
Old 12-06-2012, 07:42 AM   #3
bk.heli.man
To be totally honest... I don't like to keep track...the amount I have spent on this hobby in the last year (my first year being in the hobby) has got to be scary!
bk.heli.man is offline        Reply With Quote
Old 12-06-2012, 08:14 AM   #4
koi-fish
Looking at threads like is the exact reason I bought a barely used full airframe (minus beastx) yesterday
/MSRX, MCPX, Nano, 1SQ, several 130x, Gaui X2, 300x, 450x, DX8, Harley Road King
"It's not getting any smarter out there, you have to come to grips with stupidity and make it work for you" - Frank Zappa
koi-fish is offline        Reply With Quote
Old 12-06-2012, 09:29 AM   #5
Familyman67
in my 4 crashes so far, I spent somewhere between 30 and 80 Bucks each.
But also for me - this is something I don't really like to think about, since I spent way to much money this year on the hobby.
Started off with a Scout CX in april and now bought my 10th helicopter which is a 550 size.
Active: nano CPx / mCPx BL / 130X / 300X / KDS 550 V2 / UM F27Q Stryker / DX8
retired: CX Scout / mCX2 / B-SR / mSRx / 120SR / mCPx V2 / DX6i
Familyman67 is offline        Reply With Quote
Old 12-06-2012, 09:40 AM   #6
sn00p
My 1 and only mishap so far has cost me around £50
Main Shaft
Feathering Shaft
Canopy
Blades
Boom
Main Grip
Servo linkage
Since then ive spent at least as much upgrading fixing or preventing lol.... of which i find a MUST...
Chassis Braces
CF main Blades
Goo to strengthen canopy
PU gel AR7200BX
Nylon zip tie Landing gear to Main Frame
Balanced motor "Wicked" (or possible loctite mod on stocker)
Now i just need to worry about them pesky servos...
So i guess to answer your question on my first Crash i probably spent over £100
sn00p is offline        Reply With Quote
Old 12-06-2012, 02:40 PM   #7
xpantz
I'll fess up to having a few.
2 where the heli basically exploded on impact.
1 x $130
1 x $70
a few in the $15 - $25 range.
Damn that's cheap.... my 130x costs me more (over time).... seriously... but I do fling it about with reckless abandon :-)
xpantz is online now        Reply With Quote
Old 12-06-2012, 04:00 PM   #8
Supertuna
Ha ha yes I was with my brother in law flying when I put the 300x in and I said to him you just have to wear the repair bill because it comes with the hobby......
Spectrum DX8
Old 12-06-2012, 06:57 PM   #9
mixfisto
I've crashed MANY times (as I don't like Sims)...At one point or another, I have broken/lost pretty much everything except the swash, beastx, and motor.
I have to say the avg cost for me has been $20-25. Crash damage has been as small as a blade grip or main blade or main gear...and as big as replacing about 80% of the heli not including electronics.
I honestly spend almost as much on a good crash on my BL Mcpx.
mixfisto is offline        Reply With Quote
Old 12-07-2012, 04:58 PM   #10
Supertuna
$75 big ones for my crash rebuild....
Main frame
Main shaft
Main shaft bearings
Canopy
Main drive gear
Main blades
Landing gear
Phew....
Spectrum DX8
Old 12-07-2012, 05:22 PM   #11
mixfisto
How can you tell if your main shaft bearings are damaged?
Old 12-08-2012, 07:06 AM   #12
Supertuna
I normally do them depending on the way it goes in when it crashes but for what they are worth and the extent of the repair I just did them for peace of mind.....kept the old ones for spares.....
Spectrum DX8
Old 12-13-2012, 02:28 PM   #13
utahbmxer
Went flying for lunch today at a new field. Just had my third crash with this thing, to low and sideways coming out of an inverted hover . I think this will be the least expensive crash I will ever have, except for the time I forgot to switch to IU and it fell out of the air upside down = $0.
Stripped gears in all three cyclic servos are the only thing I can find, even the woodies are hardly scuffed. Hopefully $9 tops for 3 gears sets.
120SR | SR | 300X | DX6i
utahbmxer is offline        Reply With Quote
Old 12-13-2012, 02:44 PM   #14
bmc76
I feel much less guilty now about buying 3 helis and a dx8 in a 3 week time span, thanks still lurking the 300x forum after buying the 450x, really don't know how much longer I can talk myself out of it
T-Rex 250 Pro DFC with Beastx / ZYX-S Powered 130x with HP08- XP-12a / 300x with Don's Wicked / 450x / DX8 / Real Flight 6.5
bmc76 is offline        Reply With Quote
Old 12-14-2012, 02:41 AM   #15
347mont
haha thats what I did. Bought the 450X then like the size of the 300X so much that I had to have it.
Its currently undergoing a ground up rebuild. Hitecs 5065's & 5084/ Scorpion 2213-14 and Ice 50 ESC plus all the shinny bits
347mont is offline        Reply With Quote
Old 12-17-2012, 05:01 AM   #16
Supertuna
Better add a pair of feather shaft rubbers and while I'm there a feather shaft......test flew her tonight and blades not tracking well plus after a couple of flights rubbers showing there ugly heads.....
And confidence damaged.......
Spectrum DX8
Old 12-17-2012, 10:03 AM   #17
koi-fish
Well, first crash yesterday, hit throttle cut well before it landed sideways in the grass. Rotor wasnt spinning, which minimized damage. Tally so far was one main blade, one main grip, feathering shaft. Spun it up yesterday with no mains on, no vibes thus far.
I noticed that I have a few chewed teeth on main gear as well, this is next.
All of it was noob to larger heli user error (lost orientation, over correction).
All in all not bad. I had bought a large lot of parts on the for sale forum, covert it completely.
Old 12-19-2012, 05:30 PM   #18
Mvflyer
Default Following in your footsteps-first bad crash
Was flying today and also lost orientation in low light conditions. Main shaft cracked in half and broke main frame in half above the main gear. This will obviously require a complete tear down and rebuild. On one hand I feel lucky as it seems the only parts I have to replace will be the mainframe and main shaft...perhaps also spindle and blades. Total bill will run about $40...
Never have worked on a bigger heli (only repaired mcpx and 130) so am a little intimidated on what lies ahead to rebuild this heli....any pointers and tips welcomed!!
Mvflyer
Mvflyer is offline        Reply With Quote
Old 12-22-2012, 04:53 PM   #19
Supertuna
My 300x is back in new trim again after my first big crash and it is flying as good as new now after a $80 parts bill....
Spectrum DX8
Old 12-22-2012, 05:00 PM   #20
koi-fish
Mvflyer
check out the repair vids from Blade, they helped me immensely (I also had a full spare airframe for reference). Make sure you have no vibes afterward, hunt them down and correct them.
When I repaired mine the other day (first time as well), I had vibration problems that weren't apparent with blades off and spinning up on the ground. Drove me nuts till I figured out the problem, and then I went
Turns out, I had forgotten a screw on the landing gear during reassembly. Vibes caused bad tail wag after the heli lifted off and the lg could rattle (Beastx was trying to compensate, hence the wag). So, watch the small stuff for sure
