Old 12-07-2012, 02:21 PM   #1
RV_7A
Default Setting up GOV mode within the HV120
On my 700E DFC. This is my first time for setting this within the ESC and just wanted to see if it jives with what others have set. I used the settings from Castles site. How well is this working for you? Please note there was NO brake set within Castlelink however once you save it to file and then open your DAT file its in there...I have yet to try this method.
Hex55: 85
Brake Delay: .6 sec (Delayed) (*)
Brake Ramp: Immediate (*)
Motor Start Power: 59
Direction: Forward (*)
Brake Strength: 0
Power-On Beep: Enabled (*)
Motor Timing: 5
Data Log Enabled: 255
Current Limiting: Insensitive (180A)
Vehicle Type: Helicopter
Throttle Type: Governor Mode
Throttle Response: 5
Governor Gain: 12
Initial Spool-Up Rate: 5
Head Speed Change Rate: 18
Auto Rotate Enabled: True
Governor Mode Type: Fixed
Vehicle Setup - Battery Type: LiPo
Vehicle Setup - Number of Cells: 12
Vehicle Setup - Battery Voltage: 44.4000
Vehicle Setup - Gear Ratio: 9.3333
Vehicle Setup - Pinion: 12
Vehicle Setup - Spur: 112
Vehicle Setup - Motor Kv: 530
Vehicle Setup - Motor Number of Poles: 10
Desired Head Speed 1: 1800
Desired Head Speed 2: 2000
Desired Head Speed 3: 2100
PWM Rate: 8 Khz
Sample Frequency: 2 Sample / Sec
Cutoff Voltage: Auto Li-Po (*)
Auto-Lipo Volts/Cell: 3.0 Volts/Cell
Voltage Cutoff Type: Soft Cutoff (*)
Current Cutoff Type: Soft Cutoff (*)
Link Live Enable: Disabled (*)
800E Trekker - 700E DFC - 550v2 - 500 DFC - 450 DFC - Goblin 630
RV_7A is offline        Reply With Quote
Old 12-08-2012, 07:44 AM   #2
Steemo
looks pretty much the same as what I have and it works pretty well
You can ramp HS 3 up to 2150 and still have a decent amount of overhead if you wanted.
Just depends if you want that little bit extra pop, I do
T-Rex 700E Pro DFC HV Brain | T-Rex 600E Pro DFC V-Bar Silverline 5.3 Pro |T-Rex 500 DFC Pro mini V-Bar
T-Rex 450L Dominator | JR DSX9 9503 Mode 2
Steemo is offline        Reply With Quote
Old 12-12-2012, 06:04 PM   #3
rcflyerheli
I run a couple different choices on my 120. Your governor mode should be set rpm, not fixed endpoints. Also, I recommend something higher than 3.0 volts/cell on your cutoff. With the soft cutoff, you can reset the throttle, and continue to run, but if the cutoff is 3 volts, you can damage your packs this way. I use 3.5 volts/cell and run a good 6 minutes without hitting the cutoff. Other than those two items, your setup is the same as mine.
Goblin 700, Trex 700 V2, Trex 700DFC, Gaui X7, Logo 600SX, Logo 690SX, Forza 700
Trex600EFL Pro, Trex 600 ESP, Trex 500 ESP, DJI 550
Amain Team
Rep
rcflyerheli is offline        Reply With Quote
Old 12-13-2012, 09:36 AM   #4
Dino Spadaccini
PWM Rate: 8 Khz change that to 12 khz
Motor Timing: 5 what was the stock setting ????? if they mean pole count its a 10 pole on the 750mx motor
Governor Gain: 12 might be a little low for a 3gx not sure on other FBL i run mine at 15
2150 is the best head speed for the DFC you will get about 4mins of all flying
Dino Spadaccini Team Capt Align Factory Team USA / Team Futaba
Dino Spadaccini is offline        Reply With Quote
Old 12-20-2012, 05:34 PM   #5
Chris Wall
What should I use for just some nice gentle sport flying numbers? I was thinking 1700, 1800, 1900. When I was just hovering around the Castle logs seemed to look like it was around 1850 tops with fixed endpoints.
Synergy Field Representative / Team Scorpion / Team FBL Rotors / Team OptiPower USA
Chris Wall is offline        Reply With Quote
Old 12-20-2012, 06:14 PM   #6
Chris Wall
Settings I went with, please let me know if anyone sees any issues! I am just hovering it around in figure eights right now, so I didn't think there was a need for high head speed...
# Castle Link Data File
# Created: Thursday, December 20, 2012
# Do Not Edit This File By Hand
Hex55: 85
Brake Strength: 0
Motor Timing: 5
Governor Gain: 15
Head Speed Change Rate: 5
Auto Rotate Enabled: False
Desired Head Speed 1: 1700
Desired Head Speed 2: 1800
Desired Head Speed 3: 1900
PWM Rate: 12 Khz (*)
Sample Frequency: 10 Sample / Sec
Auto-Lipo Volts/Cell: 3.2 Volts/Cell (*)
Voltage Cutoff Type: RPM Reduction Cutoff
Old 12-20-2012, 08:20 PM   #7
K2Freak
Did you set up throttle hold?
VControl SAB Goblin 770C, BT 650, 570C, 420
#97
K2Freak is online now        Reply With Quote
Old 12-20-2012, 08:44 PM   #8
Chris Wall
Yes, with throttle curves of 0-30-30-30-30, 70-70-70-70-70, and 100-100-100-100-100.
Old 12-20-2012, 09:06 PM   #9
RV_7A
Hex55: 85
Brake Strength: 0
Motor Timing: 5
Governor Gain: 15
This is exactly what I use and recommend it for sport flying. I tried 2100 in the beginning and flipped into IU1 and my reaction was JESUS LORD!!! No way! Then tried 1900 and it too gets your attention. 1700 and 1800 is very nice speed and gives the ESC room to add the juice when you need it. I also made the changes Dino mentioned and it was a nicer transition when changing modes and when I loaded the disc with my sloppy collective changes.
Old 12-20-2012, 09:25 PM   #10
Chris Wall
RV_7A,
Thanks for the feedback! I to, would rather avoid an OH JESUS moment, and when I saw everyone saying 2150, and the most I was using in fixed endpoints was 1800 - I thought twice!
Old 12-21-2012, 01:10 AM   #11
Steemo
2150rpm isn't to scary, everything just happens more urgently.
2000 is what I fly at most of the time
Old 12-21-2012, 01:32 AM   #12
RV_7A
Well it's clearly a relative thing. Relative to skill. But when I weed eat my lawn here in Texas I don't pull the trigger to full throttle. About mid way does the trick for me. On my heli I use governor more like a cruise control as opposed to a rev limiter. Call me old if you like. Because I am ;o)
Old 12-21-2012, 08:59 PM   #13
Eddge
I suggest setting the pwm rate to 12 and the timing also should be higher than 5. I forget what the choices are in this esc, but I think mine is at 12.5. I agree with the lower headspeeds. I used to run 2000, but have found that 1800 is plenty enough power for my style of flying. I have run 1650 for a bit, and I am heading lower than that soon as well. I want to try 1200 if i can get there on 12s. I may have to go 6s to get it happy.
Align Trex 700 V2 DFC
Skookum SK540
I don't want no stinking Goblin!
Eddge is offline        Reply With Quote
Old 12-21-2012, 09:48 PM   #14
Chris Wall
Wow, I flew 6 packs today and this thing is a BEAST! I very rarely went into IU2 (1900 RPM), staying in IU1 around 1800 RPMs and loved it! I do not know if the Align servos respond the same way as the Outrage Torq ones do, but even with lots of expo the heli was ready to respond and move at any little stick movement! I thought the 600EFL Pro was a nice heli, but the 700E DFC is a lot quicker to move and respond to input... My poor wife she is 3rd in line now!!!
Old 12-21-2012, 10:18 PM   #15
RV_7A
Hey guys you might want to set your "Auto Rotate Enabled" within your ESC to on (True). I may be incorrect but setting it here enables a quicker spool up of the motor once you flip the switch back to the off position when practicing them. The very first one I attempted from 150 feet or so I dropped to within 10 feet off the ground with good head speed but aborted because I missed my mark by a few feet. Only to find out that once I flipped the switch it began a medium spool up which forced me to commit to land. At that point I had begun my flare at 10 feet thinking I was just going to fly off and try again. Well I lost too much head speed and when I dropped and flared again I hit hard enough to barely cause a boom strike. :
Can anyone confirm this will create a quicker spool up on an aborted auto? I'm ready for egg on my face so let me know.
Jeff B
Old 12-21-2012, 11:25 PM   #16
Chris Wall
Jeff B
From Castle's documentation:
Setting
 up
 the
 Auto
 Rotation
 Mode
 allows
 a
 small
 window
 in
 Throttle
 Hold
 where
 the
 motor
 is
 not
 powered
 but
 the
 Controler
 has
 not
 seen
 “Zero”
 thus
 allowing
 you
 to
 use
 the
 Head
 Speed
 Change
 Rate
 to
 give
 a
 faster
 controllable
spool
 up
for
 recovery
 when
 bailing
out
 of
 an
 auto.
Old 12-22-2012, 01:16 AM   #17
RV_7A
That's what I'm talkin about!!! Guess I'll be setting that up tomorrow.
THANKS!
Jeff B
Old 12-22-2012, 09:17 AM   #18
jimmitch
Subcribed
jimmitch is offline        Reply With Quote
Old 12-23-2012, 05:18 AM   #19
Lee2782
Here are Alan Szabo 120HV settings he posted on his Facebook page the other day
Goblin 700c Vbar5.3 GOBLIN 500 Vbar5.3
T-Rex 700e DFC Vbar5.3 SYNERGY E5s Vbar5.3
Lee2782 is offline        Reply With Quote
Old 12-28-2012, 06:31 PM   #20
jimmitch
I have frimware 3.27 should I upgrade? If I do will,I have to reset everything? Thanks Jim
