| 700 Class Electric Helicopters 700 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
#21 |
You shouldn't have to. But once you connect just save your existing settings to file. Perform the update and verify. Very easy to do.
Jeff B |
#22 |
Thanks is anyone using 4.2 on the 700 dfc. Is it worth upgrading ?
#23 | |
Went back to 3.27 and it's good again. Other guys at our club have had the same problem with 4.2 also
T-Rex 700E DFC HV Brain | T-Rex 600E Pro DFC V-Bar Silverline 5.3 Pro | T-Rex 500 DFC Pro AR7200BX JR DSX9 LE Mode 2 |
#24 |
Thanks theres nothing worse then hesitation .could you post your settings. My pwn rate is 8 khz is that ok?
#25 |
Cool, my setting are almost exactly like Szabo's. I must have stumbled in the right direction!
The autorotation function works well with the head speed change rate at 18. Quick enough to get things going without ripping teeth off. Practice several aborts at altitude and check it.
700e DFC / KDE 700XF-495 and mount CC Ice2 HV120 / BEC Pro Sk 720 Flybarless / Batt Bus |
