| MSH Mini Protos MSH Mini Protos Helicopter Support Forum |
#21 |
Yeah, those vendors are good. The 3rd bearing support and plastic frame parts have the same type of insert but I dont see any issues with those.
#22 |
just added some pics to the original post..
Logo 553 chopped 8FG Super |
#23 |
I found the culprit...
Nano CPX, Align 250 SE, Tarot 450 V2 FBL, Specktrum DX6i |
#24 |
Readyheli is not stocking MSH anymore so they refunded me. Helidirect sent me a replacement set of servo frames and they are just like the first two sets, maybe even worse. So my build is still on hold
#25 |
The CNC servo frames are simply no where to be found. Out of stock everywhere...
#26 |
MSH says a couple more weeks they should be stock.
Mini Prôtos 6S Stretch - DS95/DS95i, Mini V-Bar, YGE60 VBAR Ready |
#27 |
Still no stock on the cnc frames that I don't even really want to buy. This kit has been a waste of money at this point.
#28 |
I have 4 of the CNC frames just sitting here. 2 for my new kit and 2 spares :-) Well, I don't feel that bad. I imagine from the time they run out to the time they get more can be made longer by the Christmas break.
#29 |
Well doing my Mini Protos and I have come across the same issue.... yay......... so excited to build this over the weekend now I can't do anything!!! So annoying!!! Now I have to wait until the middle of next week until an M2 thread tap gets here as no one in my area stocks this size..... There goes half of my next week that I have off work just waiting for this thing..... ARGH!
Futaba T8FG Super Mini Prôtos - Low FBL Hub, MKS DS95i, KDS N300 (MKS DS95 clones) cyclic, Skookum SK540, YGE 60, Scorpion 2580KV, Revolectrix 3S 2200 Phoenix Simulator |
#30 |
I ran a tap through mine. The temptation is to tap it out all the way through. You risk damaging the tap, running the hole off center if you do that. You need a bottoming tap to do it right.
#31 |
I collect mine tomorrow. Hope mine isn't the same!!
#32 |
Probably will be. Collect a new 2mm tap anyways. It comes in handy.
#33 |
Yeah I ordered a bottoming tap
#34 | |
#35 |
I should mention, I tried using a m2 bottoming tap to clean out the threads. But some of the inserts are set crooked in the plastic so the screws all go in at random angles. Shame MS-Heli! Shame on you...
#36 |
I got a spare set of servo frames when I brought mine. One of the frames in the kit had a hole out of alignment so I used one of the spares. Sounds like you've been unlucky
#37 |
I just took a screw and used it like a tap winding it in a bit then back out a bit until the threads were better. I'd expect this from a cheap clone kit but not from MSH. That said when you do get it built you will love it
Goblin 700 V-Bar, Logo 500SE V-Bar, MSH Mini Protos V-Bar, T-Rex 500 V-Bar, E-Flite Blade 130X A few planks |
#38 |
What is strange is that the same tech is used in the 3rd bearing support as well as the Y bracket, plastic frames parts etc and they don;t have issues. Why just the bearing / servo blocks? Its not just plastic in there, the inserts are crappy. And it has that cheap ass alluminum with sand in it feel when you are tapping it.
#39 |
I am officially disgusted in this kit. So now I have had to get replacement servo frames, the bushing was too big to fit through the tail guide pulley so had to get another pulley (another common problem apparently). Finally received my new pulley which was good. Moved on to build the next part and one of the tail plastic rods is missing from the pack.... So another damn part, feels like each step of the build something is wrong or missing. So awful for a 'quality helicopter'
#40 |
I have built 4 mini protos and I have not had one of the problems you guys are having, either things are slipping badly at MSH or you are unlucky...
Minicopter Diabolo - Kosmik 200 Cool, Pyro 800 Comp TT E820 - Kosmik 200, Scorp 5035 MA Whiplash - Kosmik 200, Pyro 700 TREX 700E - DFC Pro HV, Kosmik 200, 850MX Protos 500 Stretch + Protos 500 + Protos Mini Stretch MSH Brain Spektrum DX8 |
