Old 01-21-2013, 06:12 AM   #41
Dogga
Default problems bearing blocks/ servo frames?? Pics added..
Came across yet another issue. I thought I'd check the rest of the parts I need to put together. I only have 3 of the bearings for the tail blade grips, there's supposed to be 4. Ugh so over it I should have had this heli build we'll finished by the start of last week!
Futaba T8FG Super
Mini Prôtos - Low FBL Hub, MKS DS95i, KDS N300 (MKS DS95 clones) cyclic, Skookum SK540, YGE 60, Scorpion 2580KV, Revolectrix 3S 2200
Phoenix Simulator
Dogga is offline        Reply With Quote
Old 01-21-2013, 06:45 AM   #42
rossk
Did you get this kit new?
Did you actually get brotos nimi from hobby king?
At this point I think only jokes can be made about your kit.
Minicopter Diabolo - Kosmik 200 Cool, Pyro 800 Comp
MA Whiplash - Kosmik 200, Pyro 700
Protos500Stretch-YGE90+3226-900 Protos500-YGE80+MVVS950 ProtosMiniStretch-YGE60+2025-1360
MSH Brain Spektrum DX8
rossk is offline        Reply With Quote
Old 01-21-2013, 02:34 PM   #43
Dogga
Lol I know! Yep brand new from ARKRC
Futaba T8FG Super
Phoenix Simulator
Old 01-21-2013, 09:51 PM   #44
desertstalker
Why do i think they put your kit together late on a friday arvo...
-DX8
Old 01-21-2013, 10:14 PM   #45
Dogga
Sad thing is I emailed MSH advising of all the issues I've had and had no response. Not even an apology
Futaba T8FG Super
Phoenix Simulator
Old 01-21-2013, 10:28 PM   #46
rossk
MSH tend not to reply to anyone, ever, even if you are waiting for stuff you have purchased from their store.
Stay with the dealers, they should look after you.
Old 01-22-2013, 01:14 AM   #47
Dogga
Yeah it's bad on MSH part. I've been dealing with Jake from ARKRC and he's been awesome!
Futaba T8FG Super
Phoenix Simulator
Old 01-26-2013, 07:15 PM   #48
yachtheli
So I just received a new set of servo frames that were supposedly "inspected" and guess what? ...more of the same...
So, I am cutting my looses at this point. Keep an eye in the FS forums as I will be listing this kit in the next few days.
Logo 553 chopped
8FG Super
yachtheli is offline        Reply With Quote
Old 01-27-2013, 03:39 AM   #49
sp00fman
Cant you fix it? As a last resort you could use the tip of a small soldering iron in the metal insert and bent it straight when the plastic starts melting.
Perhaps using a long screw in there that you heat up might get a better result.
FBL clone 250 + 450's - with CX-3X1000
FBL GAUI Hurricane 425 EP with ZYX-s -=- GAUI Hurricane 520mm - bell/hiller mixed paddled stabilization
The more money you have up in the air, the less you love it...
sp00fman is offline        Reply With Quote
Old 01-27-2013, 10:22 AM   #50
SMJT
I don't use the plastic ones anymore but when I did I do remember them not being perfect but not as bad those ones.
mini PROTOS
GAUI X2
GOBLIN 500
SMJT is online now        Reply With Quote
Old 01-27-2013, 07:50 PM   #51
jmisuraca
Sorry you had such a rough time with your Heli. Honestly it flies awesome. Maybe give the company a call that sold you the "inspected" parts and see if they can make the situation right.
Best of luck.
T-Rex 500efl
Mini Protos 6s Stretched
2x 130x (hp08 xp-12 10T, hp10s xp-12 10T)
jmisuraca is offline        Reply With Quote
