Old 12-07-2012, 08:36 PM   #1
lperagallo
Default JETI Duplex Telemetry
Here is a video on how the JETI Telemetry works.
See more at www.circlecityhelis.com
Lou
Vector 550 Quad/Octo Multirotors
DJI WooKong Multirotor Controllers
Twin Bergen 44 Magnum Turbines - KERO Start FBL
lperagallo is offline        Reply With Quote
Old 12-09-2012, 02:25 PM   #2
Laurens
Will this integrate in the display of the DC/DS 16? Also, will it be able to recognize separate packs, telling you how much % you've used instead of pack voltage or used Mah?
Team Thunder Tiger Europe
4RC.nl, Edge rotorblades, Scorpion systems
Laurens is offline        Reply With Quote
Old 12-09-2012, 04:16 PM   #3
lperagallo
Laurens,
1. Yes, all the telemetry will display on the screen. You get to pick the size of the display as well as where to display the data.
2. There is a module for the ESC to tell you the MAH used. You could wire these into a flight pack if you want if you want more than just pack voltage. There is a module that will give you individual cell readings also..
3. There are a few ways to do things. There is also an RPM sensor, GPS, all sorts of things.
The most interesting thing about all this is the voice synthesization. You can program it to talk the data through voice. The data is also stored in the SD card and can be played back on your computer later.
You can check out the modules here at:http://circlecityhelis.com/radio-gea...nd-accessories
Lou
Old 12-10-2012, 12:43 AM   #4
lperagallo
Default Jeti Telemetry Modules now Listed
Jeti Telemetry Modules are now listed at http://circlecityhelis.com/radio-gea...nd-accessories
These can be used with the JETI Duplex system. I recommend that you get the expander so you can hook up 4 modules. This would cover just about anything you want to monitor on your helicopter.
The expander is found here:
http://circlecityhelis.com/radio-gea...expander-e4-ex
Lou
Old 02-16-2013, 07:26 AM   #5
lperagallo
Default On Screen Displays
Jeti is releasing the next improvement in telemetry. On screen displays will be available in the newest firmware release available Tuesday, 19 February. Telemetry will now be available on the display of both the DS and DC. Images are below.
This see more on this system at http://circlecityhelis.com/radio-gea...C%2016-DS%2016
Lou
ID:	394776   Click image for larger version
ID:	394777   Click image for larger version
ID:	394778   Click image for larger version
ID:	394779   Click image for larger version
Old 02-16-2013, 07:32 AM   #6
BustedRaptor77
Lou
Will there be an update to the Profi for this too?
BustedRaptor77 is online now        Reply With Quote
Old 02-16-2013, 07:47 AM   #7
lperagallo
I am not sure. I will see if I can find out for you.
Old 04-29-2013, 04:25 AM   #8
im4711
I am not sure if someone else posted something about it yet or not. On the German Jeti forum (from user TUxx) I found a telemetry SW tool to download and analyze the data from the Jeti radios.
Just installed it and think its pretty cool. His Website is in German only. The SW is self explaining and in English.
You need to download .Net Framework 4.0 and the "Telemetry Analyzer - Version 0.0.7 vom 19.01.2013" tool.
It is for Windows (since I am a Mac user I just run it under Parallels with Windows 7).
Cool thing -> you can combine or individually look at the data.
The link to his website is http://ta.familie-bauer.info/Download
Name:	Screen Shot 2013-04-29 at 5.26.57 AM.jpg
im4711 is offline        Reply With Quote
Old 04-29-2013, 04:46 AM   #9
im4711
Almost forgot to mention - in addition I also downloaded and installed the Flight Monitor SW from http://www.jetimodel.com/index.php?p...ds&category=81
That took me a while to figure out how to get the data imported. I have not figured out if its possible to scale the graphs different but looks promising as a analyzer SW too.
Old 05-04-2013, 01:19 PM   #10
im4711
Just as a info for those using Mac computers -> data explorer comes with standard interface settings that you can activate and directly load the log files for further processing.
http://www.nongnu.org/dataexplorer/index.html
Old 05-04-2013, 05:12 PM   #11
bobloblaw
Many thanks. Nice to have something native to play with as well.
SAB Goblin 500
SAB Goblin 700
Jeti DS-16
bobloblaw is online now        Reply With Quote
