Old 12-08-2012, 10:13 PM   #21
Sladex
Originally Posted by DoctorJ View Post
Well... Lets hear from ya. Did you maiden? Still kicking?
Part hasn't come yet.did a ton of spool ups and all good
Sladex is offline        Reply With Quote
Old 12-08-2012, 10:17 PM   #22
Bonkievan
good to hear
Bonkievan is offline        Reply With Quote
Old 12-08-2012, 10:28 PM   #23
ShaneJourdan
Yes, great to hear, keep us posted.
Goblin 700 - XF495 KDE - HC3SX - CC160
Trex 700 - 700 MX - HC3SX - CC120
Blade 450X - Scorpion 2221-6 - BD3sx -CC 50
Gaui X2 - BD3sx - Talon 25 - DS95i
ShaneJourdan is offline        Reply With Quote
Old 12-08-2012, 11:34 PM   #24
Sladex
I lost my canopy spacer thingy mabobs. :p What could I use as a replacement
Old 12-08-2012, 11:34 PM   #25
Sladex
Is tapatalk hd worth 4.99
Old 12-09-2012, 12:08 AM   #26
ShaneJourdan
Imop YES
Old 12-09-2012, 12:12 AM   #27
ShaneJourdan
not sure...
Old 12-09-2012, 12:21 AM   #28
blackout19
http://www.heliproz.com/prodinfo.asp?number=377078 perhaps? ...
SAB Goblin 500 Mini V-Bar | TBS Discovery PRO | TREX 450 Pro V2 3GX
blackout19 is offline        Reply With Quote
Old 12-09-2012, 12:23 AM   #29
Sladex
Originally Posted by blackout19 View Post
There on there way!!!
Old 12-09-2012, 02:32 PM   #30
Sladex
Got another problem . This is the first time i have used align servos. I heard there noisy, but mine are making weird noises, especially the pitch and aileron.
http://www.youtube.com/watch?v=xqMmv...ature=youtu.be
Old 12-09-2012, 02:53 PM   #31
Bonkievan
Probably not the best thing to do to your servos all the time there, Sladex.
Anyway, I thought I heard a clicking sound with the Ail?
BTW
The noise people are referring to are when the servos are 'live'.
Being digital they are always trying to correct to centre with minute changes which is why you hear 'buzzing'.
Some questions to ask yourself.....
Do they move 'smoothly' when powered eg no binding or rough, jumpy movement throughout throw range?
Do they 'sound' ok when powered eg. No clicking or notchy sounds through the throw range?
Old 12-09-2012, 03:09 PM   #32
Sladex
BTW
The servos work perfectly when its powered up. I can still here the clicking noise especially when i move the aileron all the way to the right.
Old 12-09-2012, 03:33 PM   #33
Bonkievan
Sounds as though you've perhaps got some broken gear teeth.
This could've happened when you got the swash links mixed up and broke your link.
Best to pull the case off the servo and check. It may work fine for a while but you defo don't want it locking inflight. Don't ask, I know!
Have a look on HF or google for tutorial on servos( ds610s right? )if you don't know how
Old 12-09-2012, 03:42 PM   #34
Sladex
Damn i just threadlocked the screws.
Old 12-09-2012, 03:48 PM   #35
Sladex
I checked the gears the seem all good. I think i might add some grease to em all
Old 12-09-2012, 03:55 PM   #36
Sladex
The aileron side seems ok. If i move the servo without the top on i cant hear the noise. Maybe i had a bad fitting?
Old 12-09-2012, 03:57 PM   #37
Sladex
Just did a power up test without the cover on the aileron side. Worked perfect. Didnt hear the noise no more. Onto the pitch side
Old 12-09-2012, 04:05 PM   #38
K2Freak
Every single time I blew 610 gears (and there were a number of them!) it was the main output gear - one with the bearing. It can look pretty subtle and still be able to slip, but if you don't feel anything when the are powered up and working against resistance, then you are probably OK.
VControl SAB Goblin 770C, BT 650, 570C, 420
#97
K2Freak is offline        Reply With Quote
Old 12-09-2012, 04:06 PM   #39
Sladex
Test video of aileron side
http://www.youtube.com/watch?v=bOSXF...ature=youtu.be
Old 12-09-2012, 04:06 PM   #40
Bonkievan
Cool.
You're doing the right thing. Just work through it methodically. Don't leave anything to chance.
