Old 12-09-2012, 07:18 PM   #61
Helos4me
700e DFC / KDE 700XF-495 and mount
CC Ice2 HV120 / BEC Pro
Sk 720 Flybarless / Batt Bus
Helos4me is offline        Reply With Quote
Old 12-09-2012, 07:24 PM   #62
Sladex
Originally Posted by Helos4me View Post
Mmh.. Popcorn.
Trex 700E V2 - Canomod Phantom V2 Canopy, AR7200BX, CC BEC PRO
DX8!
Sladex is offline        Reply With Quote
Old 12-09-2012, 07:41 PM   #63
treotraveler
Originally Posted by Sladex View Post
Mmh.. Popcorn.
Yup, this is like a movie, I am going to start on some Ben and Jerry Peach Cobbler ice cream here, shortly....
Trex 500esp fbl dfc 6s
Trex 600cf fbl 5 blade Hughs 530f TT 6s x2
Trex 600efl Pro fbl 12s Trex 700e v2 12s
Chaos 600e fbl 4 blade Blackhawk 12s Chaos 600e fbl Airwolf 12s BeastX DX8 DX18QQ TX
treotraveler is offline        Reply With Quote
Old 12-10-2012, 08:08 AM   #64
Helos4me
Sladex, watch some of Finless Bobs build and set up videos. He does a pretty good job of explaining things.
http://www.helifreak.com/showthread.php?t=41692
Watch them and your knowledge will grow faster and less painfully.
And even though you didn't fly with that repaired link, even turning it up on the ground things can go bad wrong in a heart beat. Whether you are in the air or not, once those blades are spinning, you are flying. Too much stick will roll it right into the ground.Or something else.
Old 12-10-2012, 09:29 AM   #65
Sladex
Yep I watched em . Part is 20m away, should be here around noon
DX8!
Old 12-10-2012, 11:00 AM   #66
K2Freak
How much stick and sim time do you have in? How many other helis?
T-Rex 800E CHP DL / VBar / YGE 160HV / X-era 4030 470kv / MKS DS660A+ & DS760 / Align 780mm / Gryphon Quasar / KDE performance tail
K2Freak is offline        Reply With Quote
Old 12-10-2012, 05:32 PM   #67
Sladex
Atm 5 other helis and 2 planes. I have been flying for a year, and I fly about 5 Packs a day. Have about 2000 hours on the sim. I think.
DX8!
Old 12-10-2012, 05:36 PM   #68
Sladex
I've been busy lately and haven't flew for a week.
http://www.helifreak.com/showthread.php?t=478537
DX8!
Old 12-10-2012, 06:11 PM   #69
Sladex
MAIDEN IN 10 MINUTES. SO EXCITED!!!!!!
DX8!
Old 12-10-2012, 06:30 PM   #70
ddj74
So what time is the vigil ceremony?
T-REX 700 DFC v3, AR7200BX, ICE2 160HV,DC-UP MARK II
MKS HBL950 & MKS HBL980, GRYPHON EXTREME REGULATOR
POWERED BY THUNDER POWER LIPO'S
ddj74 is offline        Reply With Quote
Old 12-10-2012, 07:08 PM   #71
Sladex
Its over. Unfortuantly didnt turn out well. I aborted. The helicopter wants to spin vigirously to the left. I tried trimming and everything. I didnt get it off the ground due to this reason. It didnt tip over or anything luckily. So its in tip top shape.
DX8!
Old 12-10-2012, 07:27 PM   #72
DoctorJ
So, do you understand why?
It has nothing to do with trim. There are a number of things at play here.
Rate vs head hold, servo direction and gyro direction.
Here is how you test.
Give right rudder and note the direction of the tail blade, then move the heli to the left, the tail blade should move in the same direction as when you gave right rudder.
There is other setting still that could be wrong even if this test passes,
Goblin 700 - XF495 KDE - HC3SX - CC160
Trex 700 - 700 MX - HC3SX - CC120
Blade 450X - Scorpion 2221-6 - CC 50
Blade 130x - HP08 - CC ( many others )
DoctorJ is offline        Reply With Quote
Old 12-10-2012, 07:30 PM   #73
Bonkievan
DoctorJ is right Sladex. Sounds to me like you've your gyro reversed.
Bonkievan is offline        Reply With Quote
Old 12-10-2012, 07:38 PM   #74
Sladex
I know it had nothing to do with trim. I tried it anyhow. I first thought i might have put a gear on backwards causing the tail to run slower. But i dont think that is the problem. Ill try your test now. When i tried it it acted like it should but i noticed something. When i let go of thr rudder control it doesnt center.
DX8!
Old 12-10-2012, 07:40 PM   #75
Sladex
I noticed somethign very strange. When my helicopter is on normal mode, bx not on setup mode or anything, it has a full left rudder input. But when i got to the bx and hit tail center, it goes center.
DX8!
Old 12-10-2012, 07:54 PM   #76
DoctorJ
It's not suppose to center, once input is given it will continue to provide input till given trajectory is acquired or till other input is given.
Yes, in setup centering is acquired to help you setup.
Old 12-10-2012, 07:56 PM   #77
treotraveler
That's because you have gyro heading hold set up in your tx.
On your dx8, rate mode is 0 to -100. In rate mode, the tail will return to center position when you let go of stick. In gyro heading hold mode, the numbers go from 0 to +100, HH mode, the tail will sit in the last position you left your tx stick...
Old 12-10-2012, 07:56 PM   #78
Sladex
Fancy words.... Lol. So what can I do. It passed your test . And I have a lot of right trim in there to center the rudder, is that ok. Each side gets almost exactly the same amount of throw
DX8!
Old 12-10-2012, 07:56 PM   #79
DoctorJ
I sure hope your head setup doesn't have similar setup issues, it will go bad so fast.
Old 12-10-2012, 07:57 PM   #80
Sladex
Should I turn it off from hh mode
DX8!
