Old 12-07-2012, 11:54 PM   #1
inner3
Default Aftermarket servos
Anyone find a direct replacement servo for the 300x yet? Just realized a servo did strip from the crash and I'd rather not buy another eflight servo.
Synergy E5 vBar-BLS255/256-CC120HV-Scorpion-Rail Blades,v400D02, DX7s, RF 6.5 HeliPack, Past helis: a lot of Blade and Walkera // //www.inner3.com
inner3 is offline        Reply With Quote
Old 12-08-2012, 12:52 AM   #2
65L88
You'll need to buy a set of three servos unless you replace it with a stock servo, otherwise your servos won't be in sync with each other. I put a set of Savox SH0257servos on my 300X and they're excellent. Also, they're just enough bigger than the stock servos that they fit tightly and help to stiffen the frame up. There are lots of servos out there that would serve you well. Here's a link that might help you out:
http://helifreak.com/showthread.php?t=439149
I know a few folks are using the Solar servos and liking them, for $9 a pop I'd give them a try if I were looking for servos. You'll have to mod the frame slightly to make them fit, but it's no big deal, plus a few are putting a small piece of foam under the servo motor to keep it from shifting under the loading a heli puts them through.
MARTY
Team Newb pilot
Trex 500 fbl -Tarot 450 Pro fbl- Trex250 DFC fbl - 300X - 130X X3- mCPX brushless X3
65L88 is offline        Reply With Quote
Old 12-08-2012, 12:44 PM   #3
petedee
There is plenty of options, be aware that you will have to redo some settings when you change servos, luckily it is quite easy, just make sure you adjust everything you need to do.
petedee is online now        Reply With Quote
Old 12-08-2012, 02:04 PM   #4
Drev
Replaced mine with Align DS415M on cyclic & DS425M on the tail.
They work great & aren't too expensive.
I did go thru the Bx programming & adjusted as nec.
CHAOS 600e,BW, BeastX,
300x,DX8,
Phoenix,& a couple 'planks'...
Drev is offline        Reply With Quote
Old 12-08-2012, 02:08 PM   #5
inner3
I'll probably just buy one stock servo for now, then in January update all three. About to start the E5 build in January and need to make sure I have enough cash for the electronics so don't want to spend too much on anything else other than Christmas shopping for now. Thanks for the great ideas!
Old 12-08-2012, 03:13 PM   #6
TomC
Save yourself more $'s and just buy the servo gearsets ($3-4 each). Only takes me ~5-10 minutes to replace these.
cheers,
TomC
Blade mCPX-BL,300x,450x,500x,550x(hc3sx)
Logo14, 550 blades
TT X50E, 10s, HC3-SX
TomC is online now        Reply With Quote
Old 12-08-2012, 05:14 PM   #7
Supertuna
Did the Align DS415M fit without and modification...?
Blade mCPx BL, Blade 130X, Align Trex 250 SE,Blade 300x,Align Trex 450 Sports!
Spectrum DX8
Supertuna is offline        Reply With Quote
Old 12-09-2012, 06:47 AM   #8
347mont
I replace my 450x servos with Hitec HS 5065mg
on the cyclics and the MSG-5084MG on the tail and
theyr'e great. I'm thinking if the 300x and 450x
share the same ds76 servos the Hi-tech will fit
the 300x, correct. That's what I'll be doing to my 300 in
the near future.
347mont is offline        Reply With Quote
Old 12-09-2012, 08:04 AM   #9
JustPlaneChris
cheers,
TomC
+1, no need to replace the entire servo unless you just want to have one entire unit to swap out while you replace gears in the spare.
-Chris
JustPlaneChris is offline        Reply With Quote
Old 12-09-2012, 11:12 AM   #10
whatevva
So, if money was NOT a concern, what servos would you guys put in this bird?
Butch
mCPX v2, 120SR, Rakon 120SR, 300X, 450-3D, DX8, (Retired Schluter Scout 60 and Junior 50)
whatevva is offline        Reply With Quote
Old 12-09-2012, 11:40 AM   #11
smrceo
Ds95 & ds95i seem to be best micro servos
Sent from my Galaxy SIII with Tapatalk...spelling will be bad
Steve
ALEES Rush 750 - Vbar Silverline -YGE160HV, Scorpion 4525-520
OUTRAGE Fusion 50 - Vbar Silverline, Jive 80HV, Quantum 4125-560
smrceo is online now        Reply With Quote
Old 12-09-2012, 09:40 PM   #12
Drev
Supertuna,
The lower servo on the back side of the frame (the 2 that are stacked) needs a tiny bit of the lower side of the mounting tab filed off to clear the little step on the frame at the boom mount.
Took about 10 seconds to file off. Hope that makes sense. Take a close look and you'll see what I'm trying to explain. Other than that they fell rite in.
Have fun,
Drev.
300x,DX8,
Old 12-10-2012, 12:03 AM   #13
petedee
Probably are but they are also probably the most expensive, other options work very well at a fraction of the cost.
Old 12-10-2012, 07:45 AM   #14
JustPlaneChris
Indeed. Plus, the old saying "That's like putting a $200 saddle on a $20 horse" comes to mind.
-Chris
Old 12-10-2012, 08:07 AM   #15
Chris Gardill
This comment by Pete and Chris on the cost are valid on these servos as there is clearly a buy-in cost for that performance. The other thing that is relevant on those particular servos is they're also MUCH heavier than the stock servos. I don't think you necessarily notice that weight on a 450 sized heli as I personally run a DS95i on the tail of my 450X and am happy with it there, but I think it would change how much the 300 floats by running these.
If you do want to change, I am personally running Spektrum H3000 cyclic servos on both my 450X and 300X and have been very happy with their performance and durability. They seem to be a nice, fairly reasonable, option for a higher performance cyclic servo that is metal geared and more durable and reliable than stock. I probably have over 350 flights since these upgrades on both my 300 and 450 and I have been happy with the choice. I am running a Hyperion DS11GCB for a tail servo on my 300X and have been very happy with it. It gets good reviews and is much lighter than the popular metal gear tail servo options. To Pete and Chris's point, too, it's also roughly 1/3 the cost of a DS95i, too. I would be lying, though, if I didn't say I wasn't thinking about going back and putting a stock set of cyclic servos back on my 300X to see how it performs with that lower weight with the Wicked Motor and HiModel ESC that I'm now running on mine. As always, just my thoughts and YMMV.
Team Newb Pilot
450X (6S Scorpion 2221-2010, Spektrum H3000, MKS DS95i, Ice Lite 50); 300X (Spektrum H3000, Hyperion DS11GCB, HiModel Cool 33A/Don's RC Wicked 4800kv); TRex 250 Pro DFC (250MX, MicroBeast, Phoenix 25); 130X HP10S; mCPX BL; NanoCPX.
Chris Gardill is offline        Reply With Quote
Old 12-10-2012, 12:41 PM   #16
petedee
Agree with all you say Chris, I am mindful that the complete original airframe with all electronics except for the AR7200BX is only worth about $80-100 so do like to keep the cost down a bit, that said I have swapped to alloy for some parts and the Astroid frame stiffener and am running 65HB servos on collective and TNG-306G on the tail and very pleased with the results. Just swapped to the MH CF blades after I damaged a blade after flying into the ground doing low level circles.....
Old 12-10-2012, 01:11 PM   #17
65L88
Have you flown the MH blades yet Pete? I'm curious what you think of them. I know, I know, off topic.....
MARTY
Team Newb pilot
Old 12-10-2012, 02:29 PM   #18
utahbmxer
cheers,
TomC
I have to +1 this as well. I bought 2 kits from my LHS for $2.99 each. Works like a charm except for one of the servos had a burned out motor. So far I've replaced that servo and fixed my servos 3 times with the 2 kits. Money well spent. Eventually I might go with nicer ones, but at my skill level it's easy to repair with all the crashin goin on around here.
120SR | SR | 300X | DX6i
utahbmxer is offline        Reply With Quote
Old 12-10-2012, 07:50 PM   #19
mixfisto
Hey, I'm still in my 'crashing all over the place' mode (working on inverted hovering ATM).
I put the Solar servos on just for that purpose (on both my 300x's)... they are metal geared, work great, and I have crashed like no one's business a TON of times and they are still going!!
They are only $9 each, so thats equal to 3 replacement gear sets per stock motor. Trust me, you WILL get tired of replacing gears after awhile..
I strongly suggest you go this route (if you don't wanna spend a lot of $ on upgraded servos). If you do, there are a couple things to look out for and I'll be happy to run them by you if you like
mixfisto is offline        Reply With Quote
Old 12-11-2012, 03:56 AM   #20
Supertuna
Would you have a link to the Solar servos you are running.....
Spectrum DX8
