Old 12-11-2012, 06:27 AM   #21
mixfisto
Originally Posted by Supertuna View Post
Would you have a link to the Solar servos you are running.....
Strange...It looks like they might have discontinued the 654 and are selling the 658 in its place. Maybe look around, but this is the site where I got mine:
http://www.hobbypartz.com/33p-solarservo-d658.html
mixfisto is online now        Reply With Quote
Old 12-11-2012, 08:20 AM   #22
JustPlaneChris
The servo you linked there is a "mini" class, and is too large for the 300X. The 654 is still listed, and shows in stock.
http://www.hobbypartz.com/33p-solarservo-d654.html
-Chris
JustPlaneChris is offline        Reply With Quote
Old 12-11-2012, 02:03 PM   #23
mixfisto
Ah! Thanks Chris...for some reason I couldn't find it last night....late night web searching isn't the best way to do it
Yeah, the Solar 654 can't be beat as a replacement for the stockies in my book. pretty much the same, just with metal gears...and a touch heavier (and actually tighten up the rear servo area, eliminating the need for the shimming that some are doing back there
Old 12-11-2012, 04:03 PM   #24
Supertuna
Awesome thanks!
Blade mCPx BL, Blade 130X, Align Trex 250 SE,Blade 300x,Align Trex 450 Sports!
Spectrum DX8
Supertuna is offline        Reply With Quote
Old 12-15-2012, 11:16 AM   #25
spektrex
I have pretty good results with Align DS415m. Not too expensive, all metal gear and fast. It's a perfect fit, real tight so it also takes care of flexing to some extent.
spektrex is offline        Reply With Quote
Old 12-15-2012, 02:24 PM   #26
superjet112x
Just went to LHS and picked up 3 align 410m was wondering what your useing for a tail servo?
Trex 700n DFC Beast x...Trex 600n Beast x...
Trex 450 pro V2 DFC Beastx KDE XFC Ice lite 50
MCPXs'' HPO7..HPO5s..CO5m..V2 stock..Nano Cpx
Blade 300x Phoenix 25esc Park BEC Blade upgrades
Ducati Desmo 1/5 scale nitro superbike
superjet112x is offline        Reply With Quote
Old 12-15-2012, 04:43 PM   #27
TomC
The Align DS425M works great on the tail.
cheers,
TomC
Blade mCPX-BL,300x,450x,500x,550x(hc3sx)
Logo14, 550 blades
TT X50E, 10s, HC3-SX
TomC is offline        Reply With Quote
Old 12-15-2012, 05:16 PM   #28
spektrex
I use MKS DS95i for tail but I expect the Align DS425m to be good too. I had this one laying around so I figured why not just use it instead.
Old 12-15-2012, 05:37 PM   #29
65L88
I use the Hyperion ds11-gcb on mine. It's about as fast as you can get in the price range (with decent reliability) and has worked very well on all the helis I've used it on, including the 300X. Also, I'm not a fan of metal gears on tail servos, as the slop that inevitably develops in them has a much more detrimental effect on tail performance than it does on the cyclic.
MARTY
Team Newb pilot
Trex 500 fbl -Tarot 450 Pro fbl- Trex250 DFC fbl - 300X - 130X X3- mCPX brushless X3
65L88 is offline        Reply With Quote
Old 12-15-2012, 06:34 PM   #30
Chris Gardill
+1 on the DS11GCB. Loving that setup with the Spektrum H3000 servos on cyclic. No doubt the DS95i is a great tail servo and i love it on my 450X, but I thought it was a too heavy on the 300 to allow for proper balancing.
Team Newb Pilot
450X (6S Scorpion 2221-2010, Spektrum H3000, MKS DS95i, Ice Lite 50); 300X (Spektrum H3000, Hyperion DS11GCB, HiModel Cool 33A/Don's RC Wicked 4800kv); TRex 250 Pro DFC (250MX, MicroBeast, Phoenix 25); 130X HP10S; mCPX BL; NanoCPX.
Chris Gardill is offline        Reply With Quote
Old 12-19-2012, 09:37 AM   #31
meowguy
If you do want to change, I am personally running Spektrum H3000 cyclic servos on both my 450X and 300X and have been very happy with their performance and durability.
Did you also have to change the servo arms or do they work on the Spektrum H3000?
meowguy is offline        Reply With Quote
Old 12-19-2012, 07:07 PM   #32
Chris Gardill
Yes you do as the servo splines are a little bigger on the H3000 servos than they are on the stock servos. I use one of the 4 way servo arms and lined it up and selected the proper hole using the stock servo arms as a reference. It also takes a little bit of doing to get the servo linkage ball into those arms as the screw on the ball is a bit bigger than the hole on the servo arm. I widened mine a bit using a small phillips head screwdriver and then they went in with a minor amount of force. If you would like to see pictures of my particular setup (not that it's necessarily perfect but at least flies well), let me know.
Team Newb Pilot
Old 12-20-2012, 03:35 PM   #33
Kev Mallin
Managed to do a servo gear change without problems, so thanks again you experienced guys, I would have just gone out and purchased a new servo.
If I can do it then anyone can, didn’t even remove the zip ties on the wiring.
Blade MSR, NANO, MCPXv2, SR120, MQX, SR and 300x with a DX6i
Kev
Kev Mallin is offline        Reply With Quote
Old 12-21-2012, 06:00 AM   #34
Supertuna
I saw a guys yesterday who had fitted Hitec 5065MG into the Blade 300x without an issue....
Spectrum DX8
