Old 12-08-2012, 12:27 AM   #1
nicheuser
Default New DJI F550/Naza RTH - rough landing
Hi guys,
I just got my new F550 assembled, configured, and flying quite well, and I have a newbie question for anyone who's been there. I tested the return-to-home function for the first time today, and it works great, but I found the landing itself almost comical. It slowly lowered itself toward the ground and then "bounced" off the ground by smacking into the concrete and then flying back up to about 3 or 4 feet high, and it repeated this act around 5 or 6 times before finally landing and shutting off the motors. The GPS receiver was locked in on at least 6 satellites, but I would guess that GPS altitude accuracy was at least partly to blame. I'm curious whether this is normal, and whether anyone has any suggestions on how to make it land itself better than this. There was an altitude gain setting in the software that I didn't touch because I wasn't sure I needed to--could that be related? The 6-bounce landing was not a problem today because I don't yet have a gimbal with a camera installed, but when I do, I'll want a much more gentle landing. I'm asking only for demo purposes, because in reality, I would always switch back to manual control and land it myself. :-)
Ideas? Thanks!
--Kris
nicheuser is offline        Reply With Quote
Old 12-08-2012, 12:44 AM   #2
Wesley888
That bouncing is a very very very common problem. I did not follow those discussions to see how they fixed it though. Mine worked perfectly even the first time.
See if you can find anything in this monster thread: http://www.rcgroups.com/forums/showthread.php?t=1536553
Align 450 with NAZA-H, 450XL, XCell60, Align 700e, Skookum SK 720, SK-GPS, DX8. ArduPilot (APM 2). Talon 625 Hexa with NAZA-M.
Wesley888 is offline        Reply With Quote
Old 12-10-2012, 08:41 AM   #3
R_Lefebvre
Wesley, I didn't know the DJI had this problem? I thought it was only Arducopter?
Ground detection is a difficult thing without having an actual ground contact sensor.
-Rob
Ardupilot/Arducopter Developer
R_Lefebvre is offline        Reply With Quote
Old 12-10-2012, 10:40 AM   #4
Wesley888
My Hexa with DJI NAZA worked flawlessly right out of the box, so do many people that I've met in the forum. It detected ground very nicely and landed gracefully. Remember this?
It also worked great on hard ground in case you wonder. (You can hear it landed and shut off the motor even though you can't see it in the following video at the end)
Just that, every so often, I've saw forum thread about the same bouncy problem. It just happened to a few and nobody knew how to fix it at that time. I just briefly browsed those forums and don't see those problem being reported any more. Maybe people have found the solutions.
Old 12-10-2012, 03:12 PM   #5
Wesley888
I have an idea. Go to the Motor Mixer tab and change the Motor Idle Speed to the lower setting(s). Try different one out.
Another thing you can try is to temporary use some tapes to tape around the NAZA unit. Someone suspected that light or air (or some mysteries force) got into the NAZA unit and made it do that. Try that out as well.
Old 12-11-2012, 12:16 AM   #6
nicheuser
Hi Wesley,
Thanks for the suggestions. Two things I think I'll try: 1) launching from the grass so that it will return and land in the grass. When I tried it before, it was on pavement, so maybe that's part of the problem. 2) I'll play with the motor idle speed as you suggested. Right now, it's on the recommended middle setting. As I said, in the future, I will take over and land manually as soon as it gets close, but as an engineer, I'd like to find the cause and fix it anyway. :-)
--Kris
Old 12-11-2012, 11:19 PM   #7
pblgml
You may want to put a piece of black tape on the left side of the NAZI. Light will affect the barometer and give if a false indication of altitude. I have read this in several forums and noticed it one day while flying at about 60 feet it dropped quickly and then climbed back up just as quickly. I immediately turned the left side away from the sun and it stopped. I landed and placed a piece of black tape on the NAZI and went and attempted the same flight and never had the problem again.
T-Rex 450, Maxi Joker 2, and X-Cell Gasser w/MD500 fuse.
pblgml is offline        Reply With Quote
Old 12-11-2012, 11:22 PM   #8
Wesley888
I have read about that as well. Do try that out.
Old 12-12-2012, 12:07 AM   #9
nicheuser
Thanks guys, I feel like I've heard something like that before, so I'll definitely try it out. At the moment, my F550 is torn down while waiting for my LEDs to arrive, so as soon as I get those installed, I'll try these things and report back.
Old 12-18-2012, 12:39 AM   #10
nicheuser
Okay, I tried it again, but this time I'm landing in grass and I've got the black tape on the left (port) side of the Naza. It definitely worked better (
), but there was still a good bounce. I tried it again a couple hours later when it was much less sunny, and this time the bounce was much less pronounced (
), so maybe it has something to do with the bright sunlight. I dunno, I'm just happy that it can find its way home if it gets out of range--a perfect landing would just be gravy.
Old 12-18-2012, 02:54 AM   #11
Wesley888
Go to the Motor Mixer tab and change the Motor Idle Speed to the lower setting(s). See if that can eliminate that tiny bounce as well.
Old 12-18-2012, 08:30 AM   #12
R_Lefebvre
That looks pretty good to me!
-Rob
Old 12-18-2012, 08:41 AM   #13
Wesley888
Nah, only the one that has the bouncing problem would do that. Otherwise it should land picture perfect and not a hint of trying to get back up. Interesting thing is that majority of them never have this problem. Those who have this problem never figure out exactly what caused it.
Old 12-24-2012, 07:29 PM   #14
hareedy
some people are very demanding
a few years ago this technology was out of hand for the average man
now its sold every where with a friction of the cost of what its used to be
my advice for you
is to enjoy it the way it is cause there is a big chance you will mess up the settings sometimes and you are gonna end up crashing
i only use rth function when i am flying fpv and i get lost cause i am too high or too far
and i use it only to make it get near then i take over and land it my self
hareedy is offline        Reply With Quote
Old 12-31-2012, 11:47 PM   #15
z_man_95
How does light affect pressure?
z_man_95 is online now        Reply With Quote
Tags
dji f550, landing, naza, rth
